Question about Jenn-Air JBL2086HES Bottom Freezer Refrigerator
Fridge got wet, now it sparks and shorts power
I recently moved, it was pooring with rain and the fridge got wet during transportation. At the new destination I plugged in the fridge and it worked for a few hours. Then it started making a funny noise and then a spark came out of the back, the power shorted and the fridge stopped working. I turned the power back on and retried it after a couple of hours. It did the same again only this time it only worked for 10 mins.
  • 122 Answers
It sounds like the thermocouple is either faulty or incorrectly installed. In other words the sensor bulb may be very slightly to far away from the flame to get sufficient temperature to keep the gas flowing. This is a safety device to cut off gas supply should the flame blow out. But if you are parked at a bit of an angle, the flame will also angle away from the sensor, causing it to shut off gas supply. With regards the freezer being temperamental, this is a strange one, because on this model of fridge/freezer, the actual cooling starts from the freezer coil and ends in the fridge. Try to check the thermocouple first. Also be sure there is nothing obstructing the flame
Posted on Apr 15, 2009
  • 400 Answers
I suggest you unplug the fridge. If possible you can then open the wiring connection cover on the compressor (where the supply cable connects) and check what is causing the short circuit. Probably when moist there was a short circuit due to water but this may have burned some of the wiring. This will be quite visible and easy to repair with a bit of insulation tape.
KitchenAid KBRA22KL Moved houses and now fridge and freezer will not cool. Lights work. Here fridge has power but not kicking in the condenser. Is there a reset somewhere or is it fried. Pls help!
you must have laid the refrigerator down during transport. compressor oil is now blocking the capillary tube. just keep trying by plugging in for a few minutes every couple hours until the oil finally clears the capillary tube
APPLIANCE 911
Jul 24, 2016 | KitchenAid Refrigerators
Refrigerator was bought 5yrs ago(brand new)it worked perfectly until then....put it in storage 4 six months...when i moved it into my house i plugged it up...can hear it on but yet to get cold....left it...
Hi
Is your fridge compressor motor working and can you hear it turn on and off every hour or so. Not to be confused with the sound coming from the fan inside the fridge.
If the motor is working but neither the fridge or freezer compartment are getting cold, then there may have been a rupture during transport and gas has escaped.
Ash
Sep 02, 2011 | Hotpoint Refrigerators
I am moving home and would like to know if I can place my whirlpool fridge freezer on its side in the removal van, willthis cause any damage?
No, it won't be harmfull if you be patient when you get it there. When you get the refrigerator set back up make sure that you wait at least a few hours before plugging it back in. This gives the oil in the system time to run back into the compressor before you run it. Have a good time moving I sure am gald that it is not me. It is a lot of work!!
Nov 19, 2009 | Refrigerators
Can I transport a whirpool side by side refrigerator / freezer, laying it down on it's side for 5 hours?If when I reach my destination I stand it upright for 48 hrs. before I plug it in.
The short answer is yes, but the key is to make certain not to plug in and start the fridge for at least 24 hours once it is upright and in the final location.
The reasons manufacturers caution against transporting/moving a fridge on it's side also has to do with the possibility of damaging the doors and hinge plates. The big reason is because people tend to want to start filling up their new fridge with food right away, so they plug it in once it's in their house.
If a fridge has been shipped on its' side, the compressor oil tends to wick/flow into the piping and can cause a failure, if not allowed to drain back into the compressor when the fridge is placed back upright.
Although not the best way to transport, you can do it if you allow time for things to settle back before powering it up.
Jul 17, 2009 | Dometic RM2193 Compact Refrigerator With...
When moving the fridge with a built in door dispenser do I need to plug something first before the move? Do I need new lines after the move?
You can cover the lines to prevent any contamination but it is not necessary, the main thing in moving a refrigerator is to keep it upright during the move. If this is not possible and you have to lay it on its side, wait for at least 12 to 24 hours before plugging it in when you arrive at your new home.
If it is transported on its side and you plug it in too soon you can get liquid refrigerent in the compressor, which will knock it out leading to costly repair and replacment.
Jun 07, 2009 | GE Profile PSI23NCR Side by Side...
Freezer in my kenmore refrigerator isn't cold
Make sure the freezer fan motor is running. The wires may have come off when it fell.
Mar 08, 2009 | Kenmore Refrigerators
Transported a fridge on its side, waited 24hrs, plugged in.
Transporting frig on side probably damaged the compressor due to the oil inside draining from bottom. Do you know if the bulbs were working before you purchased? If they were you may have damaged the door switch, easy fix, just replace. Compressor replacement should be left to a pro. Probably looking at a couple hundred. One other thought is you might have caused a gas leak during transporting, another job for a pro.
Feb 23, 2009 | Frigidaire FRT18G4A Top Freezer...
Kenmore fidge not getting cold
transporting fridge items on the side mixes up the oil and the gas together, inside the compressor bottle at the back, this should never be mixed, when you move fridge appliances you should always stand appliance where it is going to be for 24 hours before switching back on to allow the gas and oil to settle and separate back apart again. many engineers may tell you this does not matter and you can lay items down etc, this is absolute bull and must not be done as for allowing it to stand 24 hours, the opinion is mixed, but common sense tell you, if you move something, let it settle afterwards, and the longer you give it to do so the better OBVIOUSLY sorry there is no diy repair
Oct 04, 2007 | Kenmore 50522 / 50524 Side by Side...
Food is defrosting in my hotpoint frost free fridge/freezer
Can you hear the compressor running? Is the fan inside the freezer running? It could be that a wire connection has come loose during the move. Was the fridge laid on it's side during the move? If so you probably have compressor oil restricting the refrigerant system. If compressor and fan are running you will probably need a qualified refrigeration tech to check it out.
Oct 03, 2007 | Hotpoint FFA60 Bottom Freezer Refrigerator
Jenn-Air JBL2086HES Bottom Freezer Refrigerator Logo
1,675 people viewed this question
Top Jenn-Air Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
john h
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
