Home | Dell | Dimension 8100 PC Desktop | First let me say tha...
Dell Dimension 8100 PC Desktop
Problem for Dell Dimension 8100 PC Desktop
First let me say that the monitor DOES work on
By aaqquablue on Apr 15, 2009
First let me say that the monitor DOES work on other computers. Just not this one. So it isn't the monitor.
My monitor light is green until I plug it into my computer. It then goes amber immediatly and stays amber. Even when the computer is unpluged.
If I turn the monitor off, plug it in , then turn the computer on,then turn monitor on, it starts out as green then says opms going into off mode and the light turns amber.
There is no monitor hook up from the mother board.
It has to plug into a video card. I have tried other video cards. Two didn't work which I thought had worked before. One other one didn't work that did work in another computer.
I first installed a new copy of XP on it. Everything worked great. Before I was going to close it up I vacumed the cat hair out of it.
The problem started after that.
I now have a formated hard drive in it that I want to install xp on but can't without a monitor.
The computer is a Dell Dimension 8100 Desktop.
I hope that helps to figure out my problem.
thank you so very much in advance.
Best Solution
posted on Apr 15, 2009
Helpful)
joecoolvette
Rank: Guru  Dell Expert Computer Hardware  Expert
Rating: 92%, 541 votes
Many people use a vacuum on their computers, and I always advise against it. A vacuum creates Static electricity. Static electricity, will silently fry out your delicate computer components. You may not see it or feel it.
To prove the vacuum/static statement, hold the wand tool above your head. Hold the plastic body of the wand tool, about an inch away from your hair. Hold the opening of the wand tool away from your head, so that there is no chance of a vacuum sucking your hair up. Now turn on, or have someone else turn on, the vacuum cleaner. Your hair will raise up. That is static electricity that does this.
Now you get to troubleshoot your computer, and see which hardware component may have failed.
Plus it makes it real tough that you do not have Integrated Graphics. (Also called On-Board)
You didn't have THE drivers for those graphics cards, so they weren't going to work, or work very well.
However, due to experience, I believe it comes down to the motherboard, ram memory, or the processor. I am leaning hard towards the processor, because it is the most susceptible hardware component, inside a computer for static shock. It will fry out in a New York minute!
Perhaps start with using one ram module, (Stick), that you know is good. Remove all the other ram modules, and insert this one known good one. It won't be one that is in the computer now. Make sure it is compatible with your computer.
Now, perhaps try the processor in another computer that operates. Make sure this processor is compatible with that computer.
Remove the harddrive, insert it in an external enclosure, set it as a Slave drive with it's jumper/s. External enclosures are cheap. They use a USB cable. You just plug it into another computers USB port. Go to Start>My Computer>and click on the Drive letter for the harddrive. (Example: Drive (F:)
If the harddrive checks out, the processor checks out, and you have used a known, compatible good stick of ram, then I suggest it's the motherboard. One or more chipsets, on the motherboard are fried out.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Dell Dimension 8100 PC Desktop
Questions and Unsolved Problems for Dell Dimension 8100 PC Desktop
Do you recommend Dell Dimension 8100 PC Desktop?
Answer
Answer
why cant i use my spellcheck? it tells me that it no longer has english
Answer
How do I connect hP e9240 to direct tv to use my multimedia software
Answer
Require Packard Bell Easynote R1938 disassembly instructions
Answer
How do I get my Namco all-stars pac-man game to use a gamepad instead of the key board? I can't get... (More)
Answer
GA-8TRC410MNF-RH Hello, I have given this motherboard and I know the position of the panel... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Dell Dimension 8100 PC Desktop:
Top PC Desktop Experts
Rank: Guru Guru
Solutions: 437
Experience: Experienced a lot in computer troubleshooting. Knowledgeable about cellular phones.
Ask Me
Find more PC Desktop Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
