Question about ATI RADEON 9550 Graphic Card
Display i have an msi motherboard, pm8m-v with a via p4m800ce chipset, a celeron 2.5 ghz processor and 2 sticks of 512 ddr-sdram. I'm running windows xp. i also have an ati 9250 graphics card. from a clean windows install, does great. after sp2 and other windows "necessary updates" i end up with a screen flicker i can not get rid of unless i wipe my disk and start another clean install for it to happen all over again.
  • udreamibuild Sep 15, 2007
    dear pcexpert. thank you for the suggestion. unfortunatly i have already tried that and it did not work. any more ideas would be greatly appretiated. thank you
    Sergeant:
    Champion:
  • 293 Answers
Hi there What driver did you use? It seems to be a driver issue. Try using the generic driver of Windows and start a restore point from there. then use your CD Driver provided from the Card's Manufacturer. ============================== Hope this helps. Let me know OK?
Posted on Sep 14, 2007
SOURCE:
Can i chage my processor pentium 4 to core2duo my motherbourd is(MSI PM8M-V H (MS-7104 v2) thnkz
No, you cannot upgrade to a core 2 duo with that motherboard because it is a socket 478.
Jun 04, 2012 | MSI Computers & Internet
I have the hp pavilion 524w desktop computer and I was wanting to know if it is possible to insert a newer version of the processor. 1.73 ghz is not fast enough. Is there anything faster that will go with...
The compatibility isn't with the memory, it's with the motherboard and its chipset. In your case the motherboard is a FIC AM-37 which has an VIA KM266A chipset - an extremely old chipset . The only processors accepted are AMD Athlon XP of the first generation of which you already have the fastest version
http://en.wikipedia.org/wiki/AMD_Athlon(tm)_XP_3200%2B#Athlon_XP_.22Palomino.22_.28Model_6.2C_180_nm.29
So no, it's not possible to upgrade it. You will have to buy another motherboard-processor combo.
Aug 04, 2011 | HP Pavilion 524w (DB280AR#ABA) PC Desktop
Motherboard Name MSI PM8M-V H (MS-7104 v2) (3
MSI PM8M-V is a VIA UniChrome P4M800-based, PC motherboard. Form Factor: Micro ATX. Compatible with Intel P IV and Celeron. Maximum Bus speed would be 800MHz. Maximum RAM Supported is 2GB.
If the specifications differ please inform me.
Thanks for contacting Fixya! Please rate the answer if it solves your problem.
Jun 05, 2010 | Computers & Internet
Motherboard model number
you can see on the motherboard.watch carefully...
Mar 09, 2010 | Computers & Internet
Upgrade PCChips M925
According to PCChips, the maximum CPU & memory supported for all three is the Intel P4 Northwood (HT) 3.06 GHz 512K,533FSB,Socket 478 and 2GB (2 x 1GB) DDR 266.
Be sure you have the latest BIOS version for your motherbaord.
M925ALU (V7.3) must have BIOS : 030703s
M925G (V8.0) and M925G (V9.1b) must have BIOS : 050510s
Hope this helps you out.
Jan 09, 2010 | PC Chips (M925G) Motherboard
MSI PM8M-V Motherboard cpu support
Hi There
The list of compatible processors is here:
http://global.msi.eu/index.php?v=1&func=prodcpusupport&prod_no=205&maincat_no=1&cat2_no=&cat3_no=#menu
The E5200 is a WolfDale processor and unsupported.
Many of the supported CPUs are hard to find but Newegg has one here:
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116027
Aug 29, 2009 | MSI PM8M-V Motherboard
Installed new processor and computer doesnt turn on just flashes green steadily?
CPU • Supports 64-bit AMD® Athlon™ 64 processor (Socket 754) • Supports 2800+, 3000+, 3200+, 3400+, 3700+ • Supports Sempron 2600+, 2800+, 3000+, 3100+, 3300+ Chipset • VIA® K8M800-CE Chipset - HyperTransport connection to AMD Next Generation of CPU - 8 or 16 bit control/ address. data transfer both directions - 800/600/400/200MHz "Double Data Rate" operation both direction - AGP v3.0 compliant with 8X transfer mode - On-board Graphic shared up to 64MB • VIA® VT8237R Chipset - Ultra DMA 66/100/133 master mode EIDE controller - Integrated dual channel native Serial ATA/RAID controller that will supply 150MB/s and support RAID 0, RAID 1 - ACPI & PC2001 compliant enhanced power management - Supports 8 USB2.0 ports. (Rear x4/ Front x4) Main Memory • Supports two 184-pin DDR SDRAMs up to 2GB memory size • Supports DDR400*/DDR333/DDR266 DDR SDRAM (*Refer to MSI recommended modules) • Note: PC3200 (DDR400) maximum 4 banks (2 double-sided) only
I can't seem to find any usefull information as to why there may be a LED flashing on the motherboard. Re-check the memory speed, and configuration, as well as the CPU that it is supported. This seems to be a fairly new motherboard, it may still be under warranty, contact MSI and request an RMA if you feel the motherboard is faulty.
May 31, 2009 | MSI K8MM-V Motherboard
Intel celeron 2.13 GHz 64kb L1 128 kb L2 cache. sis FX661 agp. FSB 533MHZ. DDR400. Strangely enough, the memory seem to be under performing greatly.pc3200 mem reports to be working at 2100 speeds. Switch...
to get the full performance out of 533 fsb, you need the next speed up from ddr400. since your ram cant run at 533mhz, it cuts the frequency down to 1/2 of 533, which is 266.
May 08, 2009 | MSI Pentium 4 , Pentium 4, Celeron-D - SiS...
Computer starts up then shuts off
make sure you pushed the ram ships in all the way.also make sure that you didnt unhook anything from the mobo when you opened your computer.
Feb 19, 2009 | MSI P4MAM2-V Motherboard
Does msi motherboard P4M900M3 support this cpu Intel Celeron D CPU 3.20GHZ 512 Socket 775
MSI has two boards P4M900M3-F, P4M900M3-L.
Both of this will support your CPU
Nov 26, 2008 | MSI Computers & Internet
ATI RADEON 9550 Graphic Card Logo
115 people viewed this question
Top ATI Computers & Internet Experts
Ekse
Alun Cox
Thomas F. Schneider
Are you an ATI Computer and Internet Expert? Answer questions, earn points and help others
