Question about Mitsuba DV55 Camcorder
SD card Once I insert the SD card and turn the power on, it will not leave the welcome screen.
  • 49 Answers
Try formatting the card first. You can use another camera, or a computer with card reader for this. On a pc right-click on the card in My Computer and choose format. On a Mac, hold control and click on the card in Finder and choose format. Try it in the camcorder again. Also, some card speeds or sizes might not work in your camera. ie - 1gig or higher. Try a smaller card. Check your manual, check the manufacturer's web site, or go to google groups.
Posted on Sep 14, 2007
I removed the sd card and lost it and now my kurio7s wont go any further than the grey screen with the small computer blinking at me, what do I do now?
Try to insert another sd card and then try to power on the computer again. If that does not work try to reset it by removing the battery for 5 minutes and then replace it and try to power -up again with the sd card inserted.
Dec 19, 2014 | Tablets & eReaders
How do you fix a white screen?
Not sure what you've tried so far, but have you downloaded and installed the firmware update? You will have to download it to a Micro SD card using a computer. Once you have it downloaded, insert the card in you tablet then to a hard start up. Do this by holding the power button and the volume down button at the same time. You will be asked what you would like to do. Select install upgrade from SD card. Once that is done, restart tablet. Good luck!
Jun 24, 2014 | Polaroid 7-in. Internet Tablet - Other
Tried the recovery software on a SD card but it did not open the software
If you made the SD recovery on your computer through a sd slot or card reader it should work. You can't make the recovery sd through your vreader. Put it in the vreader while it is turned off, power it on and the vreader should start reprogramming. Then it will tell you to shut off your vreader and restart but make sure you take the sd card back out before restarting or it will just reprogram again, lol.
Sep 09, 2012 | Vtech V.reader Animated E-book System
I have a vivitar camera from a friend and she took her memory card out then i bought my own brand new memory card with nothing on it and new batteries too. then when i try and take a picture it says memory...
From the manual:
http://static.infoteldistributors.com/pdf/VC8025%20User%20Manual.pdf
Installing SD Memory Card
Your camera has a memory card slot that enables you to insert any "SD" compatible memory card up to 8BG. Adding a memory card will allow you to increase the capacity of your camera before you have to transfer photos and videos to your PC. Install the SD memory card as below:
  1. Locate the Memory Card slot within the battery compartment.
  2. Insert the Memory card into the slot in the correct direction. (see the sketch below)
7
  1. Push the card in until you feel it "click" into position. The top of the card should be flushed with the surface of the camera. An icon will appear on the LCD screen after you turn on your camera.
  2. Once the external memory card is inserted into the camera all the images taken with the camera will be stored on the card.
Note:
  1. Limited internal memory is provided for test images. The image will be deleted when camera power is turned off. Please download the images before power off .SD memory card is required for normal use.
  2. An external memory card is required for normal use. Your camera supports any compatible SD memory card (up to 8GB).
  3. If there is a photo in the internal memory when you insert the card into your camera, a "Copy to card" message will appear on the LCD with Yes or No options. On selecting 'Yes' the photo will now be copied to your card.
  4. Formatting will delete all data on the SD memory card including protected data.
8
  1. Don't remove the SD card during formatting as this may damage the card and render it unusable.
  2. When your card is full, download the media on the SD card to your PC and delete the photos and videos from it in order to continue using your
Dec 24, 2010 | Vivitar ViviCam 8025 Digital Camera
It goes to a black screen with a yellow sign with a arrow on it pointing down, it also has a green, yellow, and red bar at the bottom.it stops at the red.
Had this same issue. Your probably trying to play either Crank2 or StarWars. Talked to Panasonic Tech Support and they said not enough memory to play disc and gave me these instructions:
"This movie title requires that an SD card of 128MB or larger to be inserted into the BluRay player prior to inserting the BD disc each time you watch this movie.
The SD card must be formatted in the BlRay player before use. (Do not format the SD card on your PC)
Formatting an SD card in the player:
-Insert an SD card (1GB or higher) into the SD slot of your BluRay
-Press [FUNCTIONS], select "other Functions" and press [OK]
-Select "Card Management" and press [OK], then follow the on-screen commands
Once formatting is complete, leave the SD card in the SD card slot. Insert the movie disc into the BluRay player and it should play normally."
Personal note, the bar graph that has always stopped at the red will hesitate for quite a while and then the rest of the bar will fill up and BD will begin to play.
Oct 04, 2009 | Panasonic DMP-BD30K Blu-Ray Player
Camera won't come on with new SD card inserted.
perhaps your card is Locked...there should be a white tab on the side of it. check to see if it is in the locked position.
Jun 26, 2009 | Vivitar DVR 530 Flash Media Camcorder
Route 66 stuck on the welcome screen (Route 66)
Get the update for Mini/Maxi route 66 from 183 Mb. Install this with card reader on the the SD card.
Then ,having the same problem, Route 66 will start up as usual.
Jan 11, 2009 | Route 66 MINI Handheld GPS Receiver
Power Acoustik PTID-4007
Ignore the above comment... SD cards and USB play fine on there (i have one).
Mine does the same, but leave it for 5-10 seconds after it says close and it loads it up!
Mar 29, 2008 | Power Acoustik PTID-4003TV Car Video...
Blank screen
To reset your TomTom device:
1. Charge your device.
Charge your device for at least 2 hours. Make sure the charging light on your device is on (except RIDER which has no charging light).
2. Remove the SD card.
If your device uses an SD card, remove it.
3. Reset your device.
Use a straightened paper clip, or something similar, to push the reset button. For a visual representation of the reset button, see below.
4. Turn your device on.
Press and hold the On/Off button for at least 4 full seconds.
5. Insert the SD card.
If your device uses an SD card, insert the SD card.
images of where to find the reset button can be found here.
Sep 04, 2007 | Tomtom ONE Regional Car GPS Receiver
Mitsuba DV55 Camcorder Logo
99 people viewed this question
Top Mitsuba Video Cameras Experts
Jose Ma DM.
Jose Ma DM.
Tom Chichester
Bill Boyd
Are you a Mitsuba Video Camera Expert? Answer questions, earn points and help others
