Question about Sony Handycam DCR-TRV30E Mini DV Digital Camcorder
SONY DCR-TRV30E not detected by my PC via IEEE1394 port. PC runs with Vista 32-bit Premium OS. 1) Turn on Mini DV 2) Set to VCR mode on DV 3) set to DV-OUT on DV 4) connect ieee1394 (4-pin) cable on DV 5) connect another end of ieee1394 (4-Pin)to my HP dv2726tx PC 6) my PC does not recognize the DV and no driver was installed 7) on PC found the ieee1394 port is active and in-use 8) and imaging device on Device Manager of PC does not find the DV device Can anyone kindly suggest any possible attempts to resolve this issue. Many thanks
Cant connect my dcr-hc24e to my windows vista 64 bit. Have my camera set to stream usb but drivers will not work with 64 bit os
upgrade the latest driver compad with vista 64 bit
here is the link to download it
http://www.sony.com.au/section/support?SR=Global%20Choice:Oceania:AU:Regionalsite:get_support
best of luck
Dec 28, 2010 | Sony Handycam DCR-HC24E Mini DV Digital...
Can transfer the data from dcr HC28 (mini dv) to a computer. If yes how.
You can transfer mini dv movie files through DV Link (iLink) on camcorder, plug DV / IEEE1394 cable in camcorder and computer to import camera movie files in computer. It is necessary that your computer should have IEEE1394 port.
Thanks
Jul 13, 2010 | Sony Handycam DCR-HC28 Mini DV Digital...
Sony Handycam DCR-TRV30E driver
Well Windows 7 has no camera drivers at all built-in, Sony are developing them I am told, if you use a Firewall cable to PC then no drivers are needed.
Jun 14, 2010 | Sony Handycam DCR-TRV30E Mini DV Digital...
I have windows vista and i cant install the usb driver and pixela programs for this handycam please help me.
the usb driver and pixela application is not compatible with windows vista. usb streaming is not supported by windows vista and 7 OS. however it would still be possible to transfer videos from your dv camcorder using the dv interface (ieee1394 or ilink) connection. you would need to have an ilink (ieee1394) card installed in your computer. you can check by going to device manager window. if you don't, try checking with your PC manufacturer recommendations for an ieee1394 chipset or card.if you do, all you need is an ilink cable (btw, the cam uses 4pin jack).get the correct cable for use with the PC and camcorder, and use windows moviemaker for your video capturing software.hope this helps.thanks :)
also, here's the support site for your unit:
http://support.sony-europe.com/dime/camcorders/dv/dv.aspx?site=odw_en_GB&m=DCR-PC101E
Mar 31, 2010 | Sony Handycam DCR-PC101E Mini DV Digital...
Sony Handycam DCR-HC42 Mini DV not recognized by Windows 7
win vista and win 7doesn't support usb streaming. the usb driver for this model would not be compatible with your computer's OS. although, you were able to download PMB still this wouldn't work, it's basically an alternative software that you can use with the newer OS. still the device driver would not be installed. and you would get a message that "ilink connection is not detected". the reason you get that is bec the camcorder and the software is intended for use with the dv (ilink or ieee1394) connection. so if your computer has an ieee1394 card and you have a compatible ilink cable,then your good to go,it should be a plug-and-play connection (no drivers required). all you need then would be a video capturing software (like win moviemaker) to transfer videos from tape to PC. hope this helps. thanks :)
Mar 28, 2010 | Sony Handycam DCR-HC42 Mini DV Digital...
Need the driver please
Follow the link and carefully read the download and install instructionsafter selecting the 32 bit tab. I have successfully installed on my Vista Home Premium 32 bit OS
http://www.microsoft.com/windows/compatibility/windows-vista/Details.aspx?type=Hardware&p=DCR-TRV33E&v=Sony&uid=dcr-trv33e&pf=0&pi=4&c=Cameras%20%26%20Photo&sc=Camcorders&os=64-bit
Oct 13, 2009 | Sony Handycam DCR-TRV33 Mini DV Digital...
Sony DCR HC 40 E driver
I had purchased the laptop with Window Vista Home Premium OS. I am unable to connect my Mini DV Sony DCR HC 40 E through firewire. the laptop doesn't recognise mini DV. Please suggest proper driver & solution
Aug 16, 2008 | Sony Handycam DCR-HC40E Mini DV Digital...
HOW TO CONVERT MINI DV INTO DVD ON WINDOW VISTA OS
Get a capture card( IEEE1394) or if your laptop has a firewire inlet you already have a built in capture card. Connect your camcorder via a firewire cable to your laptop. Nero, Windows xp has the step by step procedure making your own dvd copy.
Aug 31, 2007 | Sony Handycam DCR-TRV40 Mini DV Digital...
Sony Handycam DCR-TRV30E Mini DV Digital Camcorder Logo
194 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
