Question about Toshiba 42HL67 42 in. LCD Television
Connecting a sony home theater system
I'm having trouble connecting my Toshiba 42HL67 to a sony home theater system.
When a DVD is played on our Sony (surround sound) player there is a pink cast to any color segment. Old black and white footage is OK.
Posted on Mar 27, 2008
Why is the t-con board in my Toshiba Reza 42HL67 LCD TV repeatedly dying?
Could be just bad luck! It seems unlikely to me that the power supply would take nearly a year to destroy the T-con board!
You could get in touch with Toshiba to see if there is some kind of problem that is cropping up on this model that might cause failure in on the T-con.
May 19, 2016 | Toshiba Regza 42hl67 42-inch 720p Lcd Hdtv
Volume not working
Audio Troubleshooting 101: Getting Your A/V System ... > Home Theater Setup > Home Theater Calibration
Jul 14, 2009 - We often get flooded with emails from readers attempting to troubleshoot why their home theater systems no longer work correctly.
Troubleshooting Your Home Theater System
You just finished setting up your home theater system and big-screen TV. ... that may get your system running, or determine what the actual problem is that ... video andaudio outputs routed through a Home Theater Receiver to the TV, make ...
How to troubleshoot low sound or no audio from the ... - SONY
Aug 15, 2015 - NOTE: Surround sound is not present at all times. During periods of mainly dialog, most of the sound may come from the center speaker only, ...
SONY ' eSupport - How to troubleshoot if there is no sound ...
Jan 20, 2016 | Audio Players & Recorders
Set won't turn on. Was working fine last evening. Now nothing.
Reciever RCA RT2500 ' Techlore
Aug 20, 2005 - 31 posts - ‎23 authors
hey ive got the rca RT2500 home theater system. .... won't power up) regardless of number of times I try to simulate a 120 V power flash (pulling plug .... My RCA receiverturns on but there is no sound...what can this mean?
Trouble getting sound from home theatre system with my ...
Mar 27, 2013 - TV: Sony Bravia KDL-60EX645 Home Theatre System:RCA RT2906 ...-I've set the television, per the manual's instruction, to "Audio System" and "Audio Out: Fixed." This should allow the TV to turn off its internal speakers and switch .... SolvedI have F & D home theatre system, my rear speakers won't work.
Problems connecting surround sound to LCD TV... - Forums - CNET > Forums > TVs & Home Theaters
CNETJul 30, 2006 - Hey I have a 26" LCD TV from Polaroid and a Philips DVD home theatersystem. ... the Audio setup on the tv and TELL it to output the sound via the RCAcables ... However, you would normally turn off the TV speakers with a menu ... I just can't figure out why the TV audio won't play on the surround sound. Anynet+ - Home theater won't turn on with tv
Jun 11, 2015
TV won't turn on
Jun 10, 2015
Audio Return Channel Problem
Aug 23, 2011
rca tv no sound?????
Jan 1, 2006
More results from
Jan 19, 2016 | RCA Audio Players & Recorders
Yes I have a sony home theaterand I'm trying to hook The insignia remote to it
Remote Control Codes for Home Audio - Page 35 ...
Jun 29, 2012 - Re: NSR2000 remote codes for Comcast Universal Remote .... I havetried to program my Direct TV remote (RC64R) using the codes on ... I'm hoping you guys have the code for the sony remote so that I can just use a ... Insignia Device: NS-H2002B Insignia 200W 5.1-Ch. Home Theater ... Connect With Us:.
BDP-S3200 issue not able to control TV with remote - Sony's ...
May 25, 2014 - Televisions & Home Theater .... how to connect blu-ray BDP-S790 and Xbox into 1 HD. .... Have you already tried the programming instructions on page 43 of the manual? .... My problem is the same as the BDP-S3200 but my tv is an INSIGNIAmade fot LG. i .... So is this a 'Guess I'm out of luck' situation?
Sony Home Theater System DAV-TZ140- Gaming console ...
Dec 19, 2015 | Sony Audio Players & Recorders
I have a home theater sony which the hdmi connection damaged, i went to the sony warranty, and the problem was solved (apparently), at home when i pluged the home teather to a SONY tv worked fine ! but in...
do you have anything that uses hdmi like a blue-ray player try using the output from a source like that to verify that that its the theater system and not HDMI cable
Jun 17, 2011 | Sony HOME THEATER SYSTEM System
I have a sony home theater sys. it played dvd with no trouble till last week now when i play a dvd the color is off (green faces) i had the sys. for a year & no trouble
get a DVD lens cleaning disc(kit).. and use it once in three months... use your player once in three days to maintain its fitness.. if you still have a problem in display drop a mail to
May 13, 2009 | Sony DAVHDX265 System
I have looked up the infomation on your TV I noticed that your TV has two HDMI input plugs. Since your SONY BRAVIA is hooked up to one port, you need to buy another HDMI cable for your PS3. On your tv remote you should have an option to switch from video 1 to video 2 so then you can switch from the SONY BRAVIA to the PS3 the problem is you will only hear your PS3 Sound from you TV. If you want to hear your PS3 sound from your SONY BRAVIA you need to buy an optical cable (also called TOSLINK) to connect from your PS3 to the SONY BRAVIA.
Hope that helps!
May 01, 2008 | Televison & Video
Home Theater - sound
If it is a new set up, make sure properall connector are properly connected. Have you tried removing the Bose just to isolate the trouble, just to pinpoint the source of that HUM. The sony is amplifying some unwanted signal.
Dec 21, 2007 | Samsung LN-T4665F 46 in. LCD Television
Sony HT-7000DH
Go to pg. 48 of Sony HT-7000Dh manual. Also I sogest to connect Coaxial Digital Audio Output from Toshiba TV to Sony receiver.
Mar 15, 2007 | Sony HT-7000DH System
Toshiba 42HL67 42 in. LCD Television Logo
93 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
