Question about Dell Dimension 3100 PC Desktop
My monitor says "opms going into off mode " as soon as I plug it into my computer. The light on the monitor is green and when I plug it into my computer is goes amber. It is a Dell dimension 8100 . I have tried several video cards and it is the same on each one of them. One I know worked in a different computer. I had just put a new operating system onto it and it worked fine. I vacumed it out while it was unpluged. When I tried to turn it on this happened. I now have a hard drive in it with no operating system on it and need the monitor to go on to load the new operating system and use the computer. Please, any ideas? kenneyg.
  • aaqquablue Apr 15, 2009
    This is kenney with the problem with my monitor.
    I would like to ad that this monitor works fine when on any other
    computer so it must not be the monitor. thanks for you help
  • Dick
    Dick May 11, 2010
    Either the computer is not functioning at all or your monitor is looking for a signal on the wrong input. There is no way to tell from your description of the problem.
  • 54 Answers
Hi from your description of the problem it sounds like the display settings on your computer are set wrongly for this monitor, i.e. 1280x800. If this is the case you need to change the settings, Obviously you cant do this with this monitor in ordinary boot but you can using F8 and safe mode, control panel, display settings, change to the ones that match this monitor. Is this a Dell monitor that came with your system? if so and you need info for it heres a link that may help.
http://support.euro.dell.com/support/systemsinfo/documentation.aspx?c=uk&cs=ukdhs1&l=en&s=dhs&~subcat=138&~cat=3
I hope this helps, if not let me know. Thanks
Posted on Apr 15, 2009
My dell gx260 ligth come green if i turn it on but for a few mins time it turn orange why
Do you mean the monitor's power light starts green and then turns orange when you turn it on? Most monitors will go to a power saving mode when they do not get a signal from the computer.
The Dell GX260 has a green power light when on. When the computer is off, the light is off. If it is green and blinking, then the computer is in a power saving mode.
Diagnosis: start with the obvious: is the monitor cable plugged into both the computer and the monitor (if not permanently connected to the monitor)? Are you connected to the active port? (You can add a video graphics card in most desktops. The motherboard video port usually needs to be disabled to use the card ports. If you plug in the monitor cable to the disabled port, it won't work.) Is the monitor set to the correct input? (This applies if the monitor has several ports. In that case, there will be a Source or Input button on the monitor.) Is the computer on? The GX260 has the power button on the front. (Other computers have the power button on the top.) There is also the power supply switch on the back which needs to be on.
Next try a different data cable between the monitor and the computer (if you can). Try a different monitor. If a second monitor works, than the monitor has a damaged main board. If the second monitor doesn't work, then the video graphics adapter has probably failed. Replace the add-on card, if in use, then boot in the safe mode to remove the old graphics driver. Then install the correct driver for the graphics adapter.
Note: the computer and the monitor should both be off when you connect the cables. Then turn on the monitor first and set it to the correct source before turning on the computer.)
I hope this helps.
Aug 21, 2011 | Dell OptiPlex GX260 PC Desktop
When i plug in the switch "on" my HP COmpaq LCD 15" monitor can not respond. black screen and the power putton light GREEN show but not display. after 1 minute the green light off. when i soon "on" monitor...
ysm7862001, Monitor has possible problem lighting-up cold cahtode fluorescent lamps that provide lcd panel with white light from rear(reverse side) of the panel. No white light= black or blank n black screen. Read my fixya profile for all options you might have open to you.
12fixlouie
Mar 01, 2010 | HP Compaq 1501 15" LCD Monitor
Blinking green light
this problem is adjust not screen resulation on your computer safe mode restert your computer and fress F5 go to safe mode
thanks Tareq
Sep 08, 2009 | ViewSonic VX922 19" Monitor Flat Panel
Dell E173FP Monitor requires unplugging/plugging back in to wake
Perhaps your computer is hibernating instead of going into standby which takes a little longer to wake up from. While you are playing plugs and cables it give it enough time to come out of hibernation.
When the computer is in this mode the USB ports turn off which disables keyboard and mouse so the only way to wake up the computer is to press the power button on the computer itself.
One tell tale sign a computer is in hibernation is that the power light on the computer will slowly blink.
I hope this helps.
Aug 08, 2009 | Dell Computers & Internet
My Dell E176FPc monitor seems to be stuck in power saver mode. There is no way to access the on screen menu. When the monitor is unplugged from the compouter, it shows a self test screen with 3 colored...
Try the monitor if you can on another computer and see if it stays in power save mode. If it does then the monitor is bad.
If you try the monitor on another computer and you get video then that means theres an issue with the original computer.
Aug 04, 2009 | Dell E176FPC Monitor
Monitor led light goes from green to orange will not respond
Your video card or on-board video is kaput. If it worked fine on the other system, but not working on this one ... then you've blow the video.
One note: When the computer is ON, do NOT unplug and re-plug in the monitor. You'll blow the video card.
Luckily, add-on video cards are cheap and readily available ...
Jun 12, 2009 | Compaq MV 540 15" CRT Monitor
Monitor rejects computer
I'm just guessing, but it could be that the resolution you are using on your MS-DOS monitor is not compliant with the new monitor you are trying to use. Check the supported resolutions of the monitor that you would like to use, and then make sure you set that resolution before switching monitors.
May 10, 2009 | Computers & Internet
First let me say that the monitor DOES work on other computers. Just not this one. So it isn't the monitor. My monitor light is green until I plug it into my computer. It then goes amber immediatly and...
Many people use a vacuum on their computers, and I always advise against it. A vacuum creates Static electricity. Static electricity, will silently fry out your delicate computer components. You may not see it or feel it.
To prove the vacuum/static statement, hold the wand tool above your head. Hold the plastic body of the wand tool, about an inch away from your hair. Hold the opening of the wand tool away from your head, so that there is no chance of a vacuum sucking your hair up. Now turn on, or have someone else turn on, the vacuum cleaner. Your hair will raise up. That is static electricity that does this.
Now you get to troubleshoot your computer, and see which hardware component may have failed.
Plus it makes it real tough that you do not have Integrated Graphics. (Also called On-Board)
You didn't have THE drivers for those graphics cards, so they weren't going to work, or work very well.
However, due to experience, I believe it comes down to the motherboard, ram memory, or the processor. I am leaning hard towards the processor, because it is the most susceptible hardware component, inside a computer for static shock. It will fry out in a New York minute!
Perhaps start with using one ram module, (Stick), that you know is good. Remove all the other ram modules, and insert this one known good one. It won't be one that is in the computer now. Make sure it is compatible with your computer.
Now, perhaps try the processor in another computer that operates. Make sure this processor is compatible with that computer.
Remove the harddrive, insert it in an external enclosure, set it as a Slave drive with it's jumper/s. External enclosures are cheap. They use a USB cable. You just plug it into another computers USB port. Go to Start>My Computer>and click on the Drive letter for the harddrive. (Example: Drive (F:)
If the harddrive checks out, the processor checks out, and you have used a known, compatible good stick of ram, then I suggest it's the motherboard. One or more chipsets, on the motherboard are fried out.
Apr 15, 2009 | Dell Dimension 8100 PC Desktop
No display
if your monitor is not connected to a pc, then it cannot find a vga signal input and therefore go into power saving mode, which is indicated by the orange light, but as soon as you connect to the pc and power on the light will go green and the monitor will power up.
May 07, 2007 | BenQ T701 TFT 17" LCD Monitor
Dell Dimension 3100 PC Desktop Logo
44 people viewed this question
Alun Cox
