Question about Sony Handycam DCR-TRV250E Digital Camcorder
No power Sony Handycam Model CCD-FX620
Is there a fuse I need to check on the Sony Handycam Model CCD-FX620. I've replaced the CR2025 wafer battery and have a fully charged Duracell rechargable battery, but the camera is dead. No digital display no viewer, no door ejection, nothing at all.
  • lauriedevore Dec 02, 2008
    I have the same problem....is the camera worth trying to fix?
    Champion:
  • 287 Answers
There are fuses ,but they are small solder in types, all fx series camcorder have a common problem with the rear power board working it's way loose and unplugging itself from the main board. these units have alot of solder connection issue due to sony's use of poor solder back in the earily 90's
Posted on Sep 16, 2007
Bypass dell secure manager on latitude e6510
The previous owner has locked the laptop via the BIOS - you'll need to reset the BIOS to fix this - to reset the BIOS you will need to unplug, remove battery, open bottom of case remove the CR2025 (wafer type) battery and locate the small reset button, hold button down 20 seconds replace CR2025 battery (and recommend replace with new), hold reset button again for 20 seconds) - replace bottom cover. install battery and you should now be dealing with the not knowing the Windows Log In password (which I can't help you with).
Apr 05, 2013 | Dell Computers & Internet
How do you remove the 3V lithium battery (flat disc) from the Sony Handycam Video 8 model? The lens doesn't open when turned on, either on mains or battery power.
The battery is located on the side case where the LCD closes. To remove the battery just push down a little and pull out. Insert the new battery with the positive + side facing out. Replacement battery should be CR2025 or DL2025.
However, this battery is only for the date and time. It does not affect the operation of your camcorder. It sounds like you have an issue with either your lens or your main board. If the camcorder has been sitting unused for a long time, sometimes the surface mount capacitors will start leaking onto the main board. Still a good chance that it is a problem with your lens though. Your iris may be stuck in the closed position or the imager could be bad. Any of these problems would need to be repaired by an experienced technician. The only thing that you can try to do yourself is to "bump" the bottom of the camcorder (under the lens and around your lens) with the palm of your hand to see if you can get the iris to open up.
Hope this helps you.
www.austintelstarservices.com
Jul 22, 2011 | Sony Handycam CCD-TRV37 Camcorder
Hi how can i transfer my video files from my sony handycam vision video 8 XR model CCD-TRV57. I do not have drivers for the said unit to be transferred to my PC. Thank you and more power.
I have an old video camcorder. Sony SteadyShot Handycam Vision. Model CCD-TRV57. The screen flashes C 31:23. Can anyone help me with this problem?
Apr 02, 2010 | Sony Handycam CCD-TRV57 Camcorder
HANDYCAM USE
Go to any Sony dealer ask for NP-33 battery pack for your CAM
Cheers
Dec 08, 2008 | Sony Handycam CCD-TRV416 8mm Analog...
Sony Handycam CCD-TRV37 Error code C:32:20
1. I removed the battery. 2. With the power switch On position and holding the tape ejected I inserted the battery back on & it ejected the stuck tape.
Jul 24, 2008 | Sony Handycam CCD-TRV37 Camcorder
No power and does not indicate charging Problem
Sony camcorders C:31:23 error
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
good luck
please mark the post with a fixya
Mar 17, 2008 | Sony Handycam CCD-TRV68 Camcorder
Sony Handycam DCR-TRV250E Digital Camcorder Logo
734 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Jose Ma DM.
Jose Ma DM.
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
