Question about SanDisk Sansa e250 MP3 Player
Just Died!!!!!! I just went out and spent the money to get a micro SD card for my sansa, and I put a CD onto the card that had some sort of file protection on it and my Sansa FREAKED out and now it won't even turn on. HELP!!!!!!!!
  • 1 more comment
  • Yeagerbomb Sep 17, 2007
    It goes into recovery mode, but my dad has a lot of blocks on the computer so I can't download the firmware program. Can i do anythinbg without the program?
  • Yeagerbomb Sep 22, 2007
    thanks
  • Yeagerbomb Sep 26, 2007
    I Ran th firmware and the stupid thing still won't work. i really need help.
  • 626 Answers
Remove the card from the device. Put the device into recovery mode to verify that it still functions. Recovery mode - Turn the device off (hold power for 20 seconds) - Slide the hold switch into "hold" position. - Press and hold the "record" button If it does go into recovery mode, its not dead. Slide the hold switch back over, then turn the device off. Try turning it back on, if it functions, great. If not, reply with the message, or problem and ill go from there. Best of Luck.
Posted on Sep 14, 2007
  • Timothy D
    Timothy D Sep 17, 2007
    You can extract the files from the .exe file using WINRAR or similar.
    You can put the device into recovery mode and drag and drop the pp5022.mi4 and the sansa.fmt files onto the device while it is in recovery mode.
    Its kind of a daunting task. You may just ask your dad to use his account, for Administrator Rights, to run the file. It honestly takes less than 1 minute to run.
    Best of Luck.
  • Timothy D
    Timothy D Sep 26, 2007
    Sounds like you may need to call Technical Support. Its free, give them a call.
    SanDisk Technical Support 1-866-726-3475
    Best of Luck.
I cant files onto my sandisk micro sd card
your memory card is protected or damaged
Aug 14, 2009 | Electronics - Others
When i put my r4 into my ds its just says cant find menu?
hi it sounds like a software problem. follow the following instructions. Please can you try and reformat the 2gb micro sd card in your pc and copy firmware from the CD back onto the 2gb micro sd card following the instructions below. be warned that formating will remove even the games from the card so make sure you have a backup of the games saved to your computer. any saved games will also be erased.
To format the 2gb micro sd card
1. Insert sd card into usb stick and into usb port.
2. Close autoplay screen if it appears.
3. Right click on removeable drive. (Eg D, E, F or J etc) that appeared on screen in computer window.
4. Left click on format in menu and when format window appears, tick quick format box and select ok. This will erase all content on the sd card and remove any corrupt firmware.
To reload firmware
1. Insert cd into pc cd/dvd drive.
2. Open cd drive on screen and copy and paste the files and folders from the system/english 1.18 folder on the cd to the removeable drive that the usb and micro sd card are in. The folders that you will copy are "_system_" and "moonshl" and the files will be "menu.dat" and "mshl.nds".
3. Once copied, check removeable drive to ensure files and folders have copied over.
4. Remove usb stick from pc and insert sd card back into R4. R4 menu should appear on DS screen.
this normaly sorts this out. paul
Jul 07, 2009 | Nintendo DS Lite Console
How to sink micro sd card with player
You should probably just copy the mp3 files directly from their source folder over to the micro sd. To do this, put the micro sd into some type of adapter that will allow the computer to read/write to it. There are usb sticks that do this and there are SD adapters you put the micro into so you can use a media reader/writer with it. Once you have the card seen by the computer, just drag and drop your MP3's into the drive letter corresponding to the memory card. After that is done, put it back into the player and turn it on. I should find all your songs and make them available to you.
Mar 13, 2009 | SanDisk Sansa e260 MP3 Player
My sansa player does not recognize a micro sd when its inserted
Sorry, it doesn't work that way. You can use a separate card reader to put files onto the microSD card. When the card is installed into the Sansa, the Sansa will see the additional music.
Feb 03, 2009 | SanDisk Sansa e250 MP3 Player
Added 2GB micro SD to Sansa e280, computer doesn't recognize
There are 3 ways to solve your problem, but all of them are rather kludgy. This is an old player and the integration of the microSD card is not done very well. I believe with the newer players these sorts of issues are not problems. Anyway, here are your 3 possibilities:
1) You can load your music directly onto the card before you put it into the player. Most cards come with an adapter that lets them fit into slots that are for regular SD cards. So if your computer has a slot for an SD card (or if not, you can plug the card into a card reader and then plug the card reader into the USB port on your computer) then you can copy and paste mp3 files onto the card. This is a drag because you can't use Windows Media Player to do this, but instead need to open the folder where the MP3 files are and then copy and paste them onto the card. But it works
2) This is slightly easier. Before you connect the Sansa player to the computer go to the settings part of the main menu and then select mode. You should see two choices. One is MTP and this is the setting you want if you are using the player with Rhapsody service. The other setting is MSC and this lets your computer recognize the Sansa player AND the microSD card. Once you have selected the MSC mode, then you can connect the player to your computer. When you look at the drives on your computer, you'll see 2 new drives. One is the Sansa 280 and the other is the microSD card. Once you see those, you can copy and past MP3 files right onto the card (and/or onto the Sansa). Again, you have to go the folder where your MP3 files live and cannot use WMP to do this
3) I haven't tried this, but others say that a free program called rockbox (www.rockbox.org) let's all this work much better. It sounds complicated, as it puts kind of a new operating system on your Sansa and it may not be reversible, so proceed with caution, but some people love it.
Hope that helps
Dec 28, 2008 | Samsung YP-T8 Digital Media Player
I have a PNY MICRO SD 2GB for my Samsung Messenger. When I put the Adapter into the computer it showed some files. One named My_Music. I put a CD in and downloaded the Cd onto the My_Music file. It showed...
Hi. Well the problem is that your songs probably aren't recognized as mp3 files. I have a SanDisk micro SD and I downloaded a CD onto on a program such as RealPlayer or Windows Media Player first. Secondly, I dragged the files from there onto my SD. Try this but if this doesn't work then take out your micro SD and format it to your phone. This will end up erasing all that you have on there and possibly require you to do it many times just as I had to do, t eventually mine did work perfectly. I hope this works.
Dec 23, 2008 | PNY 2GB microSD Memory Card
PNY MICRO SD 2GB
Files must have the correct extension. i.e. .wav or .mp3 or whatever the music player requires. You may need to convert the sound file to a different type for the device to see it. It may show in one device and not another for this reason
Apr 09, 2017 | PNY 2GB microSD Memory Card
Sansa mp3 player could not detect micro sd add on card
Anything over 4GB is a Micro SDHC card, not a Micro SD card. It is a completely different type of card format on the inside, and despite the compatible size and shape, it will not work on devices labeled only as Micro SD card compatible. The Sansa e200 and up (e250, e260, ect.) are NOT COMPATIBLE WITH MICRO SDHC CARDS (Micro SD cards that exceed 2GB in capacity).
Dec 16, 2007 | SanDisk Sansa e260 MP3 Player
4 GB micro sd and the Sandisk Sansa e250R...
If the 4gb micro SD is a high capacity SD (it will say micro SDHC on it) your player may not be able to read SDHC cards, my sansa can't because it's the 'older version' it will read 2gb and below micro SD cards though (it sucked when I found out because I had just bought a 6gb micro SDHC)
Nov 22, 2007 | SanDisk Sansa e250 MP3 Player
Micro sd card
You can only see the card thru My Computer as a removable disk.
You can manually transfer the files thru My Computer by dragging & dropping then onto the card.
Best of Luck.
Oct 23, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
