Question about LG L194WT 19" LCD Monitor
Monitor resolution I am unable to get native resolution of 1440x900 on lg monitor model no. L194WT-BF (19 inch LCD) Mother board is gigabyte G31 Intel chipset I had updated bios and even drivers for chipset and even monitor I get 1440x900 resolution on motherboard with 945 intel chipset on the same monitor please somebody help solving the problem
  • parascho Apr 15, 2009
    1440x900 is supported by another motherboard
    the one I am using is unable to display 1440x900 mode
    Problem Solver:
  • 13 Answers
I get what you mean.. It has something to do with your monitor not being recognized by your computer. Reboot to safe mode (just go to safe mode you don't have to do anything) turn off your computer and wait some seconds and start your computer to normal mode. I hope this fix your problem... :)
Posted on Jan 20, 2012
    President:
  • 2,923 Answers
What do you mean that you were unable to get the native resolution of 1440x900? Are you saying that the resolution varries?
Since you mentioned that the mother board supports 1440x900, try to set the monitor resolution to that same resolution and then restart the computer.
If you will get the same problem, you have to make sure that the video card supports 1440x900 resolution.
Posted on Apr 15, 2009
My L194WT -SF WONT WORK NO POWER USED SAME POWER LEAD ON DIFFERENT MONITOR NO PROBLEM
Hello Steve,
The most common problem with the L194WT monitors is a failure of the power supply board. There are parts called capacitors that fail and can cause the issue you have. Sometimes the power light will just flash, sometimes it takes several minutes to display a picture or even a wavy picture, all of these issues indicate a failing power supply board. These boards can be repaired if you can do a little soldering. The L194WT uses the same power board as the L196WTQ and we have a step by step repair guide with dis-assembly instructions available at http://www.ccl-la.com/blog/index.php/lg-l196wtq-bf-lcd-monitor-repair/ Look over the guide and check your board to see if your capacitors have bulged and need to be replaced.
I hope this helps, if so please rate our solution.
BuddyMc
Aug 07, 2011 | LG L194WT 19" LCD Monitor
I have SAMSUNG LCD 943 MWX monitor which is 19"
This is not a monitor problem.This is a mother board problem, some mother boards are supporting this resolution.For this problem,you have to replace the mother board or put the graphics card on the same mother board.your problem will solve.
Feb 18, 2011 | Samsung 943NW Monitor
NOT SHOWS RESOLUTION 1360 by 768 IN 16" WIDE LG LCD MONITOR MY MOTHER BOARD IS GIGABYT INTEL CHIPSET 865, PLS GUIDE US
Hi!
Installing the video card driver can make use of its features of higher resolution support for your LCD monitor.
And also install the driver of your LCD monitor. This enable to use higher resolution that could provide with your computer video card as I have mentioned above.
Hope it helps..
Thank you for reaching Fixya.
Please leave comments for further assistance.
Apr 05, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
I recently purchased and installed the P191W monitor, and now my pictures are stretched. I was told I new to get a new graphics card. What card should I get? Or can I just update the driver? I am running...
Find your monitor's native resolution, in your case it's 1440x900. Go to display settings (usually right-click on desktop and choose properties), go to settings tab and move the resolution slider until it shows 1440x900. Confirm, the screen should flicker for a moment and adjust - and you should be fine.
If there is no 1440x900 resolution available, then installing a monitor .inf file that came on a disk accompanying the monitor might help.
Oct 24, 2009 | Acer AL1916W 19" LCD Monitor
Unable to attain 1440x900 screen resolution on my HP w1907v
Does the video card ,in the second machine, support 1400x900 resolution? I am running dual 7600 video cards and that optional resolution is not available to me. Will it change to any other resolution setting?
Nov 24, 2008 | Gateway FPD2275W LCD Monitor
Hannspree 19" Widescreen resolution available
I have the same problem. i downloaded a generic driver that allows 1600 X 900 resolution. this is better..things are taller rather than wider (with the 1280X1024 resolution). i dont understand why there isnt a 1440X900 driver available for XP systems.
Jul 30, 2008 | Hannspree 19" Widescreen LCD Flat Panel...
Distorted digital photos
Most likely the resolution of your desktop has and aspect ratio that in incorrect for your monitor. The native resolution of that monitor if 1440x900. Use the Windows (if using windows) desktop properties to set the desktop resolution to 1440x900.
Jun 09, 2008 | Acer AL1916W 19" LCD Monitor
1440x900 resolution required
check and make sure that you are using the Intel drivers and not the default windows xp drivers. The default drivers are very limited and only offer a few different resolutions to choose from.
Nov 20, 2007 | Intel D845GVSR Motherboard
LG L194WT 19" LCD Monitor Logo
1,508 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
