Question about Canon PIXMA MP830 All-In-One InkJet Printer
Canon Pixma MP830
Stating more than one color of the same ink is installed? Printer has been running fine prior and is less than a year old? Of course there isn't 2 ink cartridges installed of the same color and the cartridges used are brand new Canon brand. Please send any help, I really need to print my children's school reports!
  • 0828dawn Sep 15, 2007
    Aligning the cartridge has nothing to do with the problem of the u150 error that two of the same ink tank cartridges are installed. It's a defective chip in the ink cartridge, as soon as I placed a new cartridge in it worked like a charm. HOLD ON TO YOUR INK CARTRIDGE RECEIPTS, because if this happens to you and the cartridge is obviously new....the store of purchase should provide you with a replacement (+ if you don't want to make a 2nd trip, some stores have the mp830 on display and you can have them toss the cartridge in and check to make sure the chip is working properly). IF THE STORE WON'T REPLACE THE DEFECTIVE CARTRIDGE, contact CANON (USA 1-800-828-4040)and explain the problem & hopefully the will stand behind their product and replace the defective cartridge.
  • 163 Answers
Pleaz alihn the new cartridde by programing or change the ink ,it may be dry
Posted on Sep 14, 2007
SOURCE:
Canon mp830 printing pinkish instead of blue
Hi
You have stick residue in the print head. Just run the print nozzle for 2-3 times to get the correct color.
Also, be sure that all ink cartridges are full because if one of the color is empty, you cannot achieve the correct color when one ink color is missing.
Please let me know if you need more help
Mar 08, 2011 | Canon PIXMA MP830 All-In-One InkJet...
I have an error code 5B00 on my Canon MP830 printer. Can you help?
If you encounter "Error Code 5B00" it means that the Printer Counter Protection is Full and it required a reset and Ink wastepad replacement, if you want your printer to work again. There are two ways to reset the Canon MP830 printer, One is by using a Software tool and the other is manually resetting the EEPROM of the printer. Below is the step by step procedure on how to reset your Canon printer.
1. Using Mptool Software to reset Canon MP830 Printer
Turn of printer then run mptool software this software automatically detect the printer.
Click reset main and reset platen button in the waste ink counter section.
If you want to reset the cartridge ink level, click reset black and reset color in the ink counter section.
2. Manual Reset of the printer
Turn off the Printers.
Press and Hold the button Resume/Cancel then press POWER button.
Release the Resume/Cancel button while keeping POWER button on press.
Press Resume/Cancel 2 times and then release all the buttons.
When the indicator recorded GREEN - click Resume/Cancel 4 times!
Turn off and On the Canon Pixma MP Printers. And your done.
Jan 24, 2011 | Canon PIXMA MP830 All-In-One InkJet...
Have replaced cartridge with one of my refilled cartridges in a canon PIXMA MP830, and am getting an alarm U071,that reads "more than one ink tank of the following color is installed". This is of course...
Printers have a mechanism to detect refilled cartridges. By default it does not accept refilled ones. But there's a work around. Have a set of two (preferably 3) cartridges , refill and cycle them. This way the printer wont be able to detect that you have inserted a refilled cartridge.
Dec 03, 2009 | Canon PIXMA MP830 All-In-One InkJet...
The printer will print ok in color, but will not print black ink. No copy or printing.
My best guess without knowing more is that your printer has both a color print cartridge and a black ink print cartirdge. Replace the black ink cartridge and you should be fine. You might also find that replacing the entire printer is less expensive....All the best!
Nov 06, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Need to replace ink cartridge
http://reviews.cnet.com/multifunction-devices/pixma-mp830-office-all/4505-3181_7-31785803.html
Replacing the five ink tanks (cyan, yellow, magenta, black dye, and black pigment) is a simple task. The top of the printer flips up to reveal the ink tanks and the printheads, and by flipping a lever, you can pull out each tank individually. Being able to replace individual tanks is a boon, as you won't waste colors you use less frequently. Also, you won't need separate photo ink to print photos, which we appreciate. Canon ships the Pixma MP830 with full ink tanks. Replacement color and dye-based black ink tanks cost $14.25 apiece, while the pigment-based black ink tank costs $16.25. Canon estimates the cost per page for both black text and color text to be an inexpensive 2 cents.
May 31, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Pixma MP830 is printing things green that should be red
when you change all new cartridges (make sure all cartridge ok, and the cartridge pins connection ok) still red color lost, it is the trouble at print head ink chanel some of that is too dry for longer time less using , most CANON printer head is separated from the ink cartridge, two way you may try:
1) take out the ink cartridge, drop down a little the special cleaner (best clean tools buy from dealer), to the head ink chanel hole, then set back the ink cartridge and waiting minutes
2) try put the print head bottom surface touch a little cleaner or water 1-2 hrs, if you can take out the print head unit. still not fixed for some case that should change the print head unit.
Feb 06, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Printing Cartridge error
I've seen this problem before and it turned out to be a faulty chip on the cartridge as opposed to a problem with the printer. Canon should replace the cartridge free of charge if this happens.
Nov 26, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Trying to reset chip on refilled ink tank on CANON MP830
Looks like Fillserv.com has a chip resetter for the CLI8 color cartridges, but I don't know if that unit will reset the big black PGBK cartridge in the MP830.
I’m happy to assist further over the phone at https://www.6ya.com/expert/chad_65e28e99f5372e81
Nov 03, 2008 | Canon PIXMA MP780 All-In-One InkJet...
CANON MP830 PRINTER
Had the same problem - apparently a certain batch of these printer have a fault with the mainboard - mine was replaced under warranty and now the problem is solved.
Feb 05, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA MP830 All-In-One InkJet Printer Logo
101 people viewed this question
Clive
Clive
old marine
old marine
Ekse
