I have carefully followed the instructions several times but without success. Using the search method I managed once to get as far as getting the TV to turn off after about 100+ presses and then? nothing! The TV is a brand new one - model LG 22GL30** is there a code for it yet which I could try? Have you got any suggestions as to where I might be going wrong? The invalid lady for whom I am doing this is getting quite upset at all the bother I am having but I cannot see where I am going wrong ? if in fact I am going wrong. Any help would be appreciated. Thank you. Dennis
How to hack yahoo password
Posted on Apr 15, 2009
I just got windows 8 on a new laptop and the mouse pad quit working. I think I pressed the wrong set of keys and turned it off
Let us refer the following methods:
Method 1:
I would suggest you to run "Hardware and Devices" troubleshooter to diagnose the exact issue.
Follow these steps to run the troubleshooter:
a. Press "Windows key + W".
b. Type "Troubleshooting" without quotes in the Search box and hit enter.
c. Select "Hardware and Sound" from the Troubleshooter Window.
d. Select "Hardware and Devices" under Devices option.
e. Follow the On Screen instructions.
Method 2: Un-install and re-install touch pad drivers from the manufacturer's website and see if that helps:
Step 1: un-install the drivers:
Follow these steps:
a. Press "Windows Key + W" from the keyboard.
b. Type "device Manager" without quotes in the search box and hit enter.
c. Right click on the touchpad drivers and select "Uninstall".
d. Restart the computer once it is uninstalled.
Step 2: Download the latest touchpad drivers for "Windows 8" from manufacturer's website.
Regards,
Sean
Feb 17, 2013 | Acer Computers & Internet
Tip
Why Am I Unable To Program The RCA Remote Control To Operate My Components
Why am I unable to program the RCA remote control to operate a component? Why am I unable to program the RCA remote control to operate a component? If you are unable to program the remote control to operate a component, review the following information:
Compatibility
If none of the programming procedures work, the universal remote control may not be compatible with your components, based on the type of infrared technology and the age of the components. Some RCA universal remote controls will only work with components manufactured after 1990.
Distance
If you are testing the remote control after you have entered a code, you may be too far away from the component or you may not have the remote control aimed directly at the component. Because the remote control uses infrared (IR) technology to communicate with components, there must be an unobstructed path between the remote control and the IR sensor on the component.
Code Entry Methods
If the Direct Code Entry method was used to enter the codes for your brand and the unit is still not functioning properly, try one of the automatic code search methods instead. During automatic code search, the remote searches for the correct code to program.
Modes
For the remote control to know which component you wish to operate, you must put the remote control in the correct mode by pressing the corresponding component button.
Combo Units
To program the remote control to operate combo units, such as TV/VCR’s, TV/DVD’s, or TV/VCR/DVD’s, use the combo codes in the Code List to program the individual corresponding component buttons. Once programmed successfully, the TV button controls the TV functions on your unit, and the DVD or VCR button controls the DVD or VCR functions, respectively. The codes in the combo section should be tried first, using the Direct Code Entry method on the TV and DVD or VCR buttons. If this is unsuccessful, use one of the Code Search methods to program your combo unit.
Batteries
Make sure the batteries are new and properly installed.
on Jun 19, 2009 | RCA DIRECTV Satellite Remote Control
I cannot install the software on windows 7 for ce-250 i get an installation support file error access is denied. i cant get far enough to do the patch. what do i do now?
I've posted instructions that will help solve your problem for any machine, but especially for Singers. I've been using my CE250 for the last 4 months using the second method and my friend has successfully used the first for the past 9 months. Just follow the directions carefully and you should be fine.
Follow this link to the full instructions:
http://www.fixya.com/support/r8955271-use_machine_windows_7_or_vista
If you need any help, please leave me a comment back. I check back daily, so I'll be sure to get back to you within 24 hours. It's frustrating, I know. It drove me nuts until a guy who specializes in PC's and Windows helped me through a bunch of this!
May 31, 2011 | Singer CE250 Computerized Sewing Machine
Microsoft WPD FileSystem Volume Driver message Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. (Code 19)
Hello.
It seems you have a faulty driver.
Recommended resolutions
A registry problem was detected.
This can occur when more than one service is defined for a device, if there is a failure opening the service subkey, or if the driver name cannot be obtained from the service subkey. Here are some things that you can try to resolve this problem.
Method 1. Uninstall and reinstall the driver
Uninstall the driver from Device Manager and scan for new hardware to install the driver again. Here is how: First, please disconnect all USB devices and then perform the following steps:
1. Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
2. In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
3. Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
You may be prompted to provide the path of the driver. Windows may have the driver built-in, or may still have the driver files installed from the last time that you set up the device. However, sometimes, it will open the New Hardware Wizard which may ask for the driver. If you are asked for the driver and you do not have it, you can try to download the latest driver from the hardware vendor's Web site.
  1. On the device Properties dialog box, click the Driver tab, and then click Uninstall . Follow the instructions.
  2. Restart your computer.
  3. Open Device Manager, click Action , and then click Scan for hardware changes . Follow the instructions.
Method 2. Revert to the most recent successful registry configuration This content is designed for an advanced computer user.
The Last Known Good Configuration feature is a recovery option that you can use to start your computer by using the most recent settings that worked. The Last Known Good Configuration feature restores all the registry information and driver settings that were in effect the last time that the computer started successfully.
With regards FIXYA team **Please post your feedback and Vote if the problem resolved as per your satisfaction**
Sep 27, 2010 | Sony VAIO VGN-SZ440 Notebook
CANNOT SUCCESSFULLY HOOKUP A DVD/VHS TO MY VIZIO MODEL NOS. DVD-v2000 25W
I was the person chatting with you earlier on, before the chat was disconnected. My system went off and I'm sorry about that.
I'm responding here in order to make sure your problem is solved.
LAST QUESTION THIS IS A DVD/VHS DUAL UNIT AND IS CON NECTED WITH THE wHIT rED AND YELLOW TO FROM THE COMPONENT AREA TO THE BACK OF THE TV
You can do the connection by using two different methods: (a.) you can use the component method or (b.) you can use the AV method.
Using the Component method: The component is a combination of red, green and blue wire connection which brings video or display.This three must be connected for you to have a display of your unit on your TV.
Connect the Red, Blue and Green wires respectively to their appropriate places on the TV, then the other part on your DVD/VCR. Note that this connection will only bring a display and no audio. You will have to connect the red and white wire from audio out of the DVD to audio in on the TV.
Once you have successfully done the connection, put on the DVD/VCR and your TV, then press "source" on your TV remote and select component 1 or 2 for you to get a display.
B. Using the AV connection: The Av connection is using the RCA wires which is yellow white and red, just as we discussed while chatting. Connect the Yellow, white and red wires, from the TV to the DVD/VCR, the select AV on the TV remote.
Unlike the Component which its video connection is red, green and blue for display, the AV is only Yellow for display. I hope you under stand this.
Please try to follow my explanations and let me know, if you don't understand and I will explain further.
It was nice chatting with you.
Take care.
May 02, 2010 | Televison & Video
Sharper Image jumbo remote will not accept codes
Your best bet is to use the auto-search function of the remote to run through all the choices in the SAT category for the Direct TV box. I know it is more of a cable box, than a satellite box, but there are many code choices for direct TV under the satellite code listings. I think you will be out of luck for the Bose Cinewave. I am surprised that the Panasonic TV codes didn't work for you using the auto-search.
Here are the codes I have handy for Direct TV set-top boxes (SAT button) : 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216 & 217.
And for Panasonic TV's: 003, 054, 055, 062, 070, 148, 170 & 171.
And for Sony DVD's: 009 & 174.
To program your remote to the TV by entering a code, follow these steps:
  1. Turn on your TV.
  2. Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
  3. Press the TV button on the remote so that the LED blinks once and then remains solid red.
  4. Enter the first set of 3-digit codes from the list. The LED will blink once every keypress. After the 3rd digit, the red LED will turn off indicating that the code was recognized for the device. If the code was not compatible, the LED will flash several times and you need to return to step 2 to try that code again or to try the next code in the list.
  5. After the LED has turned off, aim the remote at the TV and press ON/OFF. If the device turns off, you have used the correct code and the remote was successfully programed. If the device does not power off, return to step 2 and try again with the next code in the list.
To have the remote try each TV code it knows one at a time, follow these steps:
  1. Turn on your TV.
  4. Press the ON/OFF button slowly and repeatedly until the TV turns off. The LED will blink once each time you press the ON/OFF button.
  5. Once the TV turns off, press the ENTER button to store the code and the LED will turn off.
As I mentioned, try substituting SAT for the Direct TV box, and of course DVD for the Sony player.
I hope that helps.
Dec 31, 2009 | Innovage Jumbo Remote Control
I have an innovage jumbo remote did not loose it!!! LOST THE DIRECTIONS TO PROGRAM IT.
You can program the Innovage Jumbo Remote by entering three digit codes, or by using the auto-search function.
To program your remote by entering a code, follow these steps:
  1. Turn on your TV.
  1. Turn on your TV.
To program the remote for your VCR, repeat this process starting with turning the VCR on, then follow the steps substituting the VCR button for the TV button.
I hope that helps.
Oct 31, 2009 | Innovage Jumbo Remote Control
I bought a universal jumbo remote and i followed instructions i to program it to my Jvc tv but it does not work can u help?
Make sure you try every code in the list for your JVC TV.
The codes for your Jumbo Universal Remote to control a JVC television are 013, 054, 055, 060, 065, 067, and 089.
  1. Turn on your TV.
  1. Turn on your TV.
I hope that helps.
Sep 24, 2009 | Innovage Jumbo Remote Control
Ipod cannot be restored unknown error has occured?
I have had some success with this problem, so far i have fixed 9 out of 20 with the method i'm going to explain. First off without knowing what generation Ipod you have or what version software your running, i'm going to give the the general idea. your going to go to you-tube and search for "How to jailbreak your Ipod touch @@@@@@" were @@@@@ is your generation Ipod ie;(1st or 2nd gen.) Now you will follow the instructions in the video and keep your fingers crossed that it works. From what i can figure out, something happens to the programming on the touch that gets weirded out and wont allow it to be restored via itunes. By jail breaking it you will basically reprogram the touch with the jail-broken software which has been written in a different way. If you are able to jailbreak it, then you should be able to then hook it up let itunes recognize it and then restore it. Like i said it's worked 9 out of 20 times for me so far, let me know if i can start saying 10 of 20 :) Cali
Aug 16, 2009 | Apple iPod touch
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
