Error occur during compiling,unable to open a header file
While compiling a program the compiler is giving an error -"unable to open "iostream.h" what does it means and how it can be rectify
  • manu_dave May 11, 2010
    first of all tell me what program you have run and what the task is don by that program?
  • 489 Answers
The compiler is attempting to access the iostream header file and it either cannot find the file (not in the default location or it has been told to look in another location where it doesn't exist), or the file security is set so the current user does not have read access to the file.
Posted on May 26, 2009
Linker error:Unable to open file 'TCLASSS.LIB'
this is the basic lib class required by the compiler make sure your libs variable to pointing to the correct location the the libraries required by the compiler.
Sep 25, 2012 | Borland Turbo C++ 3.0 Full Version...
Can you give an example of compiler using vb?
Dim parameters As New CompilerParameters() Dim results As CompilerResults parameters.GenerateExecutable = True parameters.OutputAssembly = Output results = icc.CompileAssemblyFromSource(parameters, SourceText)
The code above uses the CompilerParameters object to tell the compiler that you want to generate an executable file (as opposed to a DLL) and that you want to output the resulting assembly to disk. The call to CompileAssemblyFromSource is where your assembly gets compiled. This method takes your parameters object and the source code, which is a string. Once you compile your code you can check to see if there were any compilation errors. We use the return value from CompileAssemblyFromSource, which is a CompilerResults object. This object contains an errors collection, which contains any errors that occurred during the compile.
There are other options for compiling, such as compiling from a file. You can also batch compile, which means you can compile multiple files or sources at the same time. Additional information on these classes is available on MSDN Online:
Feb 17, 2011 | Microsoft Visual Basic 6.0 for PC
I want to prepare a letter head on plain paper, how I put my company logo & name, as well address on it, What I mean is how to put header & footer on paper?
Letter head on Plain Paper
Step1: Open a Microsoft Word Document File
Usually word creates a new document when the program is opened.
Step 2: Inserting Header and Footer in Word Document
Click on view and then Header and Footer.
Step 3: In a Microsoft Word document, choose Insert > Picture > From File… After selecting file, it will give you a browse file option, where you have to specify the location of the logo file you have created with desired resolution and size.
Step 5: Control-click on the placed image and choose Format Picture from the pop-up menu.
Step 6: Inserting text into the Header and Footer
To insert text into your letterhead, simply select the font style and size of the text you require, then enter the text into the header and footer box.
May 18, 2010 | Microsoft Computers & Internet
How to run digital fortran 6 on windows vista
Here is what I did. Open the DVD (right click and select Open), and then open the X86 folder. Run the Setup.exe file from there and it should install and work fine. I had an error during install near the end, but it seems to have done no harm. I compiled one of my old Fortran apps and it works fine.
Dec 15, 2009 | Compaq Digital Visual Fortran Professional...
Can you correct my error message? command line option SYNTAX ERROR I get this message when I try to open a pps file. I have Microsoft Power Point installed on the computer. Thea.
In computer science a syntax error ( IPA: /ˈsɪntæks ɛrə(ɹ)/ ) refers to an error in the syntax of a sequence of characters or tokens that is intended to be written in a particular programming language.
For compiled languages syntax errors occur strictly at compile-time. A program will not compile until all syntax errors are corrected. For interpreted languages however syntax errors cannot be detected until runtime and it is not necessarily simple to differentiate a syntax error from a semantic error.
A syntax error may also occur when an invalid equation is entered into a calculator. This can be caused, for instance, by opening brackets without closing them, or less commonly, entering several decimal points in one number.
copy and paste this link in your internet address bar for more information:
http://www.google.com/search?q=SYNTAX+ERROR&ie=utf-8&oe=utf-8&aq=t&rls=org.mozilla:en-US:official&client=firefox-a
feel free to ask any other questions
Oct 13, 2009 | Microsoft Windows Vista Home Premium with...
Can anyone tell how run java program in cmd prompt???
You need to type:
If it's a program.class
java program
or of it's a program.jar
java -jar program.jar
regards
Apr 03, 2009 | Sun Java Programming Language (cdj-275)
Programing
it is an api used to create windows at runtime
that is just an include file. at the beginning of the programing you are telling the compiler that i m going to inclued windows header file.
Mar 21, 2009 | Gimpel Software PC-lint for C/C++ 8.0...
Compilation error in Turbo c++ 3.0
#include <stdio.h>
The above line should be at or near the beginning of your program source file. If that doesn't work, you can try:
#include "stdio.h"
Of course make sure all the standard libraries and include
files have been installed. Otherwise you have a broken installation and virtually nothing will work.
Mar 07, 2009 | Microsoft Computers & Internet
Looking for a vista compatible c/c++ compiler
You can try MS Visual C++ 2008 Express which you can download free here:
http://www.microsoft.com/express/vc/
or there's the Open Source GNU /C++ suite:
http://gcc.gnu.org/
May 16, 2008 | HP Pavilion dv6000z Notebook
Can send your program to me i will try to clear it
Feb 22, 2008 | Borland Turbo C++ Suite 1.0...
Computers & Internet Logo
85 people viewed this question
David Payne
David Payne
