Question about Toshiba 36A50 36" TV
36" toshiba suddenly turns off and the little red light flashes
My 36"36a50 suddenly will turn off and the little red light by the power button just flashes, cannot turn it back on until it is unplugged and plugged back in. in a few seconds after turning it back on it shuts off again. when it does come on its a red screen with lines through it. can this be fixed? i did take the back cover off and blew all the dust out, did not fix the problem
  • Anonymous May 05, 2009
    Same problem as discribed with others.Toshiba tv 36A50 suddenly turns off and red light flashes.Few hard hits sometimes fixis it.
Some el.components are loose on tv circuit board.I have removed the back cover,supported tv picture tube 45 deg.against wall.This tv is heavy!One screw on left holds the circuit board to bottom case.Removed and supported this board on few heavy books.Turned tv on and gently probed all the componets on top of the board with plastic drinking straw.In my case transistors Q-830 and Q-421 needed resolder loose joints.These components are mounted on flat aluminium heat sink strips located sligtly left of center of the circuit board.Also blobed bit of silicone into base hole and foot of alu.heat sink to support it.
Posted on May 14, 2009
1 vertical line across the screen maybe 1" tall. It appears to have the entire picture in that short little space.
tv turns its self off i unplug it plug it back in it will flash on not showing picture it u can her it flash on and right back of some times it will not flash in back of tv and i can hit power it will flash and go off every now and then it will come on show picture after being unplugged and plugged back but then shuts off
Jul 16, 2010 | Toshiba 36A50 36" TV
Blinking red light at power button if you slap the set it will come on but any movement will turn the picture off and the blinking light back on
this is a dry canaction problum in pcb do not slap tv.
* cont. tv tech. nr. at your home solve this problum in fuw mint. it is not expanciv but. if you slap tv then posibal spear damage in inside tv.set.and he is very expanciv.
Oct 31, 2009 | Toshiba 36A50 36" TV
The tv suddenly shuts off
flyback on the verge of giveing out on you.. needs a new flyback..
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Apr 21, 2009 | Toshiba CF36G40 36" TV
36A50 Digital ready?
Hi duce1500,
Unfortunately, the 36A50 is not HDTV-ready. That means you will need a converter box. Here is a link to the model's specs, which includes this information:
http://www.amazon.com/Toshiba-36A50-36-TV/dp/tech-data/B00004YMBV/ref=de_a_smtd
I should mention, however, that if it's connected to cable (or certain satellite services), you won't need a converter to watch the TV - you'll receive the digital signal (although you won't have the 1080-pixel HD resolution - the 36A50 only has 850 lines of resolution).
I hope this helps. Please let me know if I can be of any further assistance.
H2H
Dec 13, 2008 | Toshiba 36A50 36" TV
36" 36a50 tv won't turn on
My 36A50 suddenly shuts off losing audio and video. The red light on the on/off switch continues flashing until the set is unplugged.
Jul 16, 2008 | Toshiba 36A50 36" TV
Universal remote codes
Do you have code search Mode?....( before Turn on your tv with button front)..... Press code search while red light come on, release and press tv, and press repeatedly power, when tv go off, press enter and ready!!. I hope this woork. THank you
May 11, 2008 | Toshiba 36A50 36" TV
Toshiba 36zp18p/q
same problem for me too - just a red light showing and nothing else.. sometimes it works but only about 1 in 100 :(
Nov 03, 2007 | Toshiba 36A50 36" TV
Toshiba 36A50 Horizontal Line in the middle
  • the problem is most common & simple to repair at your home only at minimum cost by skilled technician.
  • as per problem is concern it is due to electrolytic capacitor failure in vertical output stage.
  • hope this will help
  • good luck.
Oct 21, 2007 | Toshiba 36A50 36" TV
Toshiba 36A50 36" TV Logo
238 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
