Hi, No problems at all:I am positively impressed by the PANASONIC RQ-CR07V stereo cassette player. The sound is neat and full despite the device's small size. I would like to know what is the limit noise sensibility and the selectivity of the tuner, especially on MW. Such data are not shown in the product specs of this type, as a rule.
But the player's sound quality is clearly above the comparable products.
Thanks!
Boris Larin
Moscow
SOURCE: panasonic MW- Arcing
You're on the right track. That panel is the waveguide cover.
This is usually due to grease or food particles stuck to the inside of the oven or stuck on or behind the waveguide cover in the waveguide just out of sight.
It can be fragile, and the metal edges behind it can be sharp, so be careful!
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smmoth and clean.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart or Lowe's.
If your waveguide cover is burned, it will need to be replaced.
To order Panasonic parts see http://www.pasc.panasonic.com/epartr
SOURCE: Panasonic NV-EX1 Mini DV
There's a place to download UK manuals here:
http://www.panasonic.co.uk/customer-Support/download-centre.asp
SOURCE: connection problems
Yes you can by connecting a optical cable from bd35 to your systems optical in put,then select this in put on your sysyem and set sound to prologic2, you will not get HD MASTER or DOLBY TRUE HD audio but will get dolby digital and dts.
Hope this helps.
CABLE GUY.
SOURCE: tape ejects when inserting into video player
check the tab on the back side of the tape- make sure its intact- if tab is missing it will not let you record - i've sometimes added tape to replace the tab ,,
SOURCE: I need cables for a 1991 Panasonic shelf audio system
Hi Will, I searched for flat cables ,seem to no longer be stocked. If you are interested in selling the whole system let me know. I have one working condition with cables, would like to have spare units(parts). I will check one more site on cables for you.
Contact Gregg at: [email protected]
