Question about Kenwood Car Audio & Video
Just stopped working
Just got some 10'' infinity's and a kenwood amp, everything has been working fine and one day it stopped the amp turns on just no output i checked all the wires everything is connected and nothing has been switched. i checked the audio cords from the head to the amp everything connected still.
  • bowenchick Apr 15, 2009
    the amp still comes on and yes all the fuses check out..all the lights and fans on the amp come on just no subs
  • bowenchick Apr 18, 2009
    ok ive isolated the issue..its definately the subs...but the weird thing is i know i didnt blow them or anything i checked the wires in the box they were fine, when i took the sub out and just tried to connect it directly from the sub itself to another known working amp it made abosolutely NO noise......very weird in my opinoin...even if i did blow them they should make a noise right?
  • 63 Answers
Please check if the supply is still present in your amp using a multimeter. if you dont have a multimeter, check the fuse that supply the amp. a broken fuse will not turn the amp. let us know.
Posted on Apr 15, 2009
  • cebuwano Apr 15, 2009
    Ok. Lets find out which block it fails.
    Check the sub speaker alone, sub amp and cd player source.
    1. check
      the sub speaker alone. Turn the unit off. Disconnect the sub speaker wire
      from your sub amp and connect any 1.5V
      battery (1 AA or 1 AAA size). If you hear any static when you spark the 1.5V battery, you sub speaker is
      good. Reconnect the sub speaker to your sub amp.
    2. check the sub amp. Find the audio input
      of your sub amp. Disconnect that line input wire. Turn the unit on then
      touch that input line of your sub amp, if you hear a 60Hz hum you sub amp
      is ok. Another way is to hook up another source into your sub amp input.
      If no sound, you may have to open the sub amp and look inside for open
      fuse if you have not done this yet but if you see lights on in your sub
      amp, you don’t need to do this.
    3. check
      the source. While your sub amp input is disconnected, the other wire is an
      output of your cd source. Hook up that wire directly to any availabale
      speaker. If you hear sound, that means your cd source is ok and your
      problem is on the sub amp section.
    Please put some electrical tapes
    for open wires to avoid short circuit.
    Let us know.
  • cebuwano Apr 18, 2009
    you did good. if the suppy fuse is blown, there is no noise as there is no supply going in. if the hybrid ic or solid state amplifier is blown and the fuse is OK, you may probably heard a noise.
    since you have found the issue next is to dig in whats goin on inside the sub amp. 2 things you should before handing to the specialist or deciding to buy one.
    check the following inside the subwoofer amplifier:
    1. verify that the power supply section is normal. voltage in is 11-15V and voltage out if its step up is 24 to 48v may be. the dc capacitor inside the circuit can give you hint on whats the output voltage after step up. should be lower than the rated voltage on cap. example, 16V or 25V on cap so supply is 12V.
    2. amplifier circuit that handles the amplification. if it is IC type, might me damaged. a helpful datasheet will help you find the supply input pin of that IC. also the input output of audio and the corresponding supply voltage of that components. http://www.datasheetarchive.com/
    let us know. thanks.
Kenwood KDC-BT558u drains 640 constantly from the Battery even when the unit is off!
check the wire harness connections, sounds like you have KOER power hooked to KOEO. Or in other words, you have power to the radio with the key off that should connected to key on power
Jan 06, 2015 | Kenwood Car Audio & Video
I just installed a kenwood dnx7140. Everything is
Have you checked to see if the sub amp is turning on. Check to make sure you have at least 12 volts on your power as well as your remote turn on (Blue/White on radio harness).
If everything is hooked up correctly, it is possible that the preout is turned off. Some headunits have selectable preouts. If so you should be able to turn the sub on and off in the menu.
Hope this helps
VOTE
Mar 08, 2010 | Kenwood DNX7140 Car GPS Receiver
My kenwood kfcw3011 stopped working. Amp indicator still on.
here is what you would do. the next time that your speakers cut out. leave everything running goto the speaker and slightly push on it. if the speaker starts to work again you have blown the coils loose and they are not making contact all of the time. you need to replace your speakers, or they could do more damage to your amp or head unit
if i have helped you in your issue, please leave a good rating. If you have further ?'s you can contact me at mega_muzik@yahoo.com
Oct 27, 2009 | Kenwood KFC-W3011 Car Subwoofer
Kenwood 9102d wont power on
YOu might have burned out the inner fuse. Better yet the source connect...
Nov 06, 2008 | Kenwood KAC-9102D Car Audio Amplifier
Kenwood head unit CD and AUX sound not working
I fixed the sound problem with tech support from Kenwood. I had the blue wire from the Kenwood which is the antennae turn on wired to the amp turn on for the vehicle (2001 Blazer with Bose factory stereo). This is how I was told to wire it from the installation tech where I purchased the wiring harness. The tuning played fine because the Bose amp turned on when I played the tuner but when I played the cd or aux the amp turned off, thus no sound. The kenwood tech toldd me to wire the blue/white wire to the amp turn on for the vehicle so the amp would be on when ever power to the Kenwood was on. I rewired this way and everything works great now.
Jun 09, 2008 | Kenwood KDC -X815
Car Audio & Video Logo
101 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
