Question about Kyocera RI-3530 Black and White Copier
Light Copy Our machine is Sharp AL1000 digital copier, we are doing "QUALITY COPY". Our problem LIGHT COPY. We try to clean everything but no changes on copy. It's still LIGHT. Is there any adjustment or programming? Please help us. Thank you and more power!
    New Friend:
  • 120 Answers
Change the toner cartidge. it has developer and toner together
Posted on Jan 26, 2008
  • 62 Answers
Also press clear exposure select clear exposure the screen should go blank enter 46 print 19 print change from 2 to 1 this will turn off toner save mode.
Posted on Nov 12, 2007
  • 62 Answers
Also go into simiualtion clear/expsoure clear/expsoure in put 46 print key tnen 19 change it from 2 to1 this turn off toner save mode.
Posted on Oct 18, 2007
  • 163 Answers
First you press the exposure key and select the manual exposure mode then press and hold exposure key for 5 seconds when it blinks select the position to dark and press exposure key again,try to make the copy if no defrence ,select the photo mode and press and hold the exposure key again select the dark position by dark exposure key and press exposure key again.check the copy if again no difference change the DEVELOPER
Posted on Sep 16, 2007
Poor copy quality - smudgy copies - changed toner - still the same.
check your OPC drum life, if you have a poor quality with a new cartridge installed (light copy, dirty copy) the opc drum must be replaced, check you machine counter if you have reach 100k copies you need to replace the drum, if you are using a new OPC DRUM, you need to clean the machine, you have to call for service because there is many parts that muat removed to clean properly.
Dec 27, 2010 | Canon NP 7130 Black and White Copier
The red tringle light is on. What is wrong?
This triangle means that the toner supply is needed. It comes first as a steady triangle meaning toner is running low and eventually flashing triangle which means toner is completely empty and copy cannot run. There are two methods of replacing toner ;
Refilling and cartridge replacing.
  • You can refill by opening the waste container and then removing the lid on the unit. Use a sprout provided in Sharp Al1000 toner bottle or improvise by folding a paper into a funnel shape.
  • For cartridge , pullout the old cartridge and replace with a Sharp Al100td cartridge.
Nice time.
Dec 10, 2010 | Sharp AL 1631 Copier
After replacing the drum cartridge the copier still wont copy and the drum light is still on.
To reset the drum light on your AL1000 press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Press "C" then the far left key (exposure mode) then the "C" key then the far left again.
So in other words C, far left, C, far left
If done correctly the display should go blank.
Then key in 24 as if you were going to make 24 copies.
Now press the "print" button
Now key in 7 as if you were making 7 copies
Now press the print button again.
You should now be getting flashing zero's on the display.
Turn the machine off then on again and your drum light should be gone!
Good Luck and Thank You for using Fixya.
Sep 21, 2010 | Sharp AL-1000 Copier
Copy darkness problem canon image runner 2830
Did you try to clean beneath the copy glass?
On digital machines, when the copy glass or optics are dirty, copy becomes verry light.
How many copies do you have? pres 123 button.
It also could be that you need to change the toner station, by the book it goes 300000 copies.
But I bet on dirty copy glass and dirty scanner assy.Clean the glass with glass cleaner and polish it with dry cloth.
Jul 25, 2010 | Canon imageRUNNER 2870 Copier
In my ir3300 xerox in very light
That means that you have to clean copy glass , lenses, ccd,...maybe even laser unit if you know how.
On digital machines dirty optics means light copy, on analog oposite, dirty optics dark copies.
Just one more question how do you mean " charge toner"?
Jun 07, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
Sharp AR168D won't copy
There are small mirrors on the copy lamp, wipe with a clean dry soft cloth. Remove the drum unit and wipe upper part where the drum unit was and make sure the area is clean.
Mar 31, 2009 | Sharp AR-235 Copier
Sharp ar155n poor copy quality
Your machine is making an uneven copy, the cause of this problem sometimes is on the optics inside the platen mirror, try to clean the mirror and the lens with a dry soft cloth. With dusty environment optics is easily filled with dust making the copy very light on one side. But after you clean and still uneven copy occur , the problem is now on the laser scanning unit , the LSU is also dirty or dusty , you should call the authorized technician to clean the LSU , cleaning of LSU is not easy because it takes a lot of covers and units to be disassembly.
Jan 29, 2009 | Office Equipment & Supplies
Light Copies Canon imageCLASS D320
hi im jules_09,check the developer,if its past over 60,000 copies if its over 60,000 copies you need to change the developer along with the opc drum and cleaning blade or roller,all copiers need to be replaced with new developer,opc drum and cleanign blade or roller when it reach its copy life,that may be the cause of light copy of print
Nov 21, 2007 | Canon imageCLASS D320 Digital Copier
Copy quality always light
Are you using a genuine OEM Sharp toner and drum? The paper pick-up rollers could use a good cleaning. Try a little WD 40 on a cotton cloth and clean the d shaped rollers. Also the feed clutch could be sticking. You have to take the back covers off to see the clutch. Clean and put some light grease on it. Easy parts to order and not expensive.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Aug 02, 2007 | Sharp AL 1631 Copier
Kyocera RI-3530 Black and White Copier Logo
312 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Marvin
Marvin
George Mclaughlin
Ed
Ed
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
