Question about Motorola Mobility RAZR V3
Learning to type a message
Having found the first letter to start the word I want to type, the next letter entered changes the previous letter. What am I doing wrong???
Mobile Dummy
  • 143 Answers
It must be on predictive text. Basically you type the numbers according to any of the letters that are there.
So for example, if you wanted to type "Hello"
It would be 4(H) 3(E) 5(L) 5(L) 6(O)
This will show a word it thinks it can make from these numbers, generally by pressing the star key, you can flick through the options of words. If your word isn't there, you will have the option to type it in manually. For this (using the same example) you would have to type
44(H)
33(E)
555(L)
wait for a bit for the cursor to move over
555(L)
666(O)
You can see that predicitve is much faster.
I hope i fix ya problem :)
Posted on Apr 15, 2009
Keypad displays wrong character when I try to send text or enter web addresses
visit nearest technician to remove and replace crystal that controls the keypad system
Jun 24, 2015 | Nokia Lumia 520 Windows Phone Black
Tip
INSTALL WINDOWS 7 USING USB PEN DRIVE !!!!!!!!
Requirements:
*USB Flash Drive (Minimum 4GB)
*Windows 7 or Vista installation files.
Follow the below steps to create bootable Windows 7/Vista USB drive using which you can install Windows 7/Vista easily.
1. Plug-in your USB flash drive to USB port and move all the contents from USB drive to a safe location on your system.
2. Open Command Prompt with admin rights. Use any of the below methods to open Command Prompt with admin rights.
*Type cmd in Start menu search box and hit Ctrl+ Shift+ Enter.
Or
*Go to Start menu > All programs > Accessories, right click on Command Prompt and select Run as administrator.
3. You need to know about the USB drive a little bit. Type in the following commands in the command prompt:
First type DISKPART and hit enter
Next type LIST DISK command and note down the Disk number (ex: Disk 1) of your USB flash drive. In the below screenshot my Flash Drive Disk no is Disk 1.
4. Next type all the below commands one by one. Here I assume that your disk drive no is “Disk 1”.If you have Disk 2 as your USB flash drive then use Disk 2.Refer the above step to confirm it.
So below are the commands you need to type and execute one by one:
SELECT DISK 1
CLEAN
CREATE PARTITION PRIMARY
SELECT PARTITION 1
ACTIVE
FORMAT FS=NTFS
(Format process may take few seconds)
ASSIGN
EXIT
Don’t close the command prompt as we need to execute one more command at the next step. Just minimize it.
5. Next insert your Windows7/Vista DVD into the optical drive and check the drive letter of the DVD drive. In this guide I will assume that your DVD drive letter is “D” and USB drive letter is “H” (open my computer to know about it).
6. Maximize the minimized Command Prompt in the 4th step.Type the following command now:
D: CD BOOT and hit enter.Where “D” is your DVD drive letter.
CD BOOT and hit enter to see the below message.
7. Type another command given below to update the USB drive with BOOTMGR compatible code.
BOOTSECT.EXE /NT60 H:
Where “H” is your USB drive letter. Once you enter the above command you will see the below message.
8. Copy your Windows 7/Vista DVD contents to the USB flash drive.
9. Your USB drive is ready to boot and install Windows 7/Vista. Only thing you need to change the boot priority at the BIOS to USB from the HDD or CD ROM drive. I won’t explain it as it’s just the matter the changing the boot priority or enabling the USB boot option in the BIOS.
Note: If you are not able to boot after following this guide means you haven’t set the BIOS priority to USB. If you got any problem in following this guide feel free to ask questions by leaving comment.
on Apr 02, 2010 | Computers & Internet
Tip
How to install windows 7 from pen drive
Its very difficult to install windows 7 if you are not having a DVD drive, Especially when you are planning to upgrade your windows xp system you would like to see how vista looks. So you need to install it and see. Requirements: USB pen drive 4GB or more
Windows 7 DVD
Step 1: Download HP USB storage format tool from here and install on your computer.
Step 2: Once you finish installation, double click on HP USB storage format tool and format your pen drive in NTFS
For this, select NTFS from File system option and Check quick format option and click on start.
While doing the format the data stored on your Pendrive will be lost. You keep a back if needed. Press YES on the warning message
Once the format finished you will get a message with the details and Click
on OK
Now insert Windows 7 DVD in to DVD Drive and go to command prompt.
For that go to start -> RUN and type CMD and press enter or OK
You will see the command prompt with black back ground
Now you need to change the directory to your DVD drive where you put the windows vista DVD.
For that type G: and press enter (here I am using G because in my system DVD drive letter is G. So you need to check your DVD drive letter and type accordingly)
So the directory will change to G:>
Now type cd boot and press enter
Now the interface will be like G:boot>
Then type bootsect.exe /nt60 h: (where h is the drive letter of your pen drive)
Now you will get a successful message like below
Now you can close the command prompt and copy all the contents from the windows 7 DVD to the pen drive
It will start copying now
Once it’s finished, you need to restart your pc and access the bios of your system and make first boot device as USB pen drive.
That’s it, now you can see installation starts from the USB pen drive.
on Mar 02, 2010 | Computers & Internet
SYSTEM PROBLEM FOUND
You need to update the toy. Connect it to your Learning Lodge Navigator. You should be prompted for an update.
Aug 03, 2013 | Vtech MobiGo 2 Touch Learning System -...
Tip
How to install vista from pendrive
Its very difficult to install windows vista if you are not having a DVD drive, Especially when you are planning to upgrade your windows xp system you would like to see how vista looks. So you need to install it and see. Requirements: USB pen drive 4GB or more
Windows vista DVD
While doing the format the data stored on your Pen drive will be lost. You keep a back if needed. Press YES on the warning message
on OK
Now insert Windows vista DVD in to DVD Drive and go to command prompt.
Now you can close the command prompt and copy all the contents from the windows vista DVD to the pen drive
on Mar 02, 2010 | Microsoft Windows Vista Ultimate Edition
How do I change the name on the phone from the previous employee to the new employee's name?
Programming is done on 7310, 7324 and 7316 type sets.
Enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow).
The display should now ask for an extension number.
Enter extension number you want to change the name on.
Press the show key (top right arrow)
The display should say LINE ACCESS
Press the next key (bottom right arrow) .
The display should say CAPABILITIES.
The display say Name.
press the Chng soft key.
use the dial pad to enter the name. advance using the arrow soft key to go to the next letter
ex. Bill = 2,2 -> 4,4,4 -> 5,5,5 -> 5,5,5
Press the next key (bottom right arrow) to enter the name.
Press the release key when finished
Nov 10, 2010 | Nortel Norstar 16-Line PBX Speakerphone
I have a T7316E Nortel phone and we have had a lot of employees chance. I need to change the display name for each phone. How do I do that?
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you want to change the name on.
Sep 16, 2010 | Nortel T7316E 2-Line Corded Phone
I am having problems texting faster on my tracfone, it is a w175g
If your Tracfone has an uparrow on the zero (0) key, after entering a character, IMMEDIATELY hit the 0 key.  The phone will change the case of the previously entered character AND change case for subsequent entries.
If you're too slow typing the 0 key, you'll get the characters assigned (0, +, etc.) to that key.
May 31, 2009 | Motorola Mobility TracFone w175 PayAsYouGo...
KeyboaRD ISSUES
replace your keyboard if possible
May 08, 2008 | Toshiba Portege 3500 Tablet PC
Motorola Mobility RAZR V3 Logo
199 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
D. E. Hev
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
