Question about Tomtom ONE GPS Receiver
Tomtom one maps
Upon turning my tomtom one us - canada ,on it starts up and then the screen says no maps found.how do i get maps working or download the ones needed.It was suppose to have us and canada maps already preloaded.it connects to computer and tomtom home fine but no maps.
  • 2 more comments
  • huskys Nov 13, 2007
    my tomtom was working fine until i went to up date it on the pc and it then wiped all the maps from it's screen. how do i get my maps back on it.it just says when i turn it on on maps.looked on the internet a bit to see what i could do but had no joy can you help please.
  • Anonymous Nov 04, 2008
    unit displays no maps
  • Anonymous Mar 20, 2014
    NO MAPS FOUND
  • Anonymous Mar 26, 2014
    no maps found
I just had this same problem. Quite strange. I have a Tomtom One New Edition and connected to a Vista Ultimate computer. Here is what I did to fix the problem I was having.
Exited out of the Tomtom HOME application. Went to "Computer" and right clicked the Tomtom drive (was M: for me, could be different for you) with the Red Icon. Selected properties and click on tools. From there I selected "Error-Checking" and only checked "Automatically scan and fix errors for me". It said it found a couple errors and corrected it. I then doubled clicked the icon in the bottom right portion of my screen which looks like a USB plug with a green check mark on it. I selected the drive and clicked stop. I disconnected the usb plug and then used a small tack on the bottom of the Tomtom unit to reset the device. After that, I turned the unit on and all was fine and I could clearly see that an update was applied.
Good luck! They really should have a support bulletin for this as this is clearly a common issue.
Posted on Dec 27, 2007
SOURCE:
Screen reads"no maps found"
I found this article online, and it may work for you:
"Ok this has worked on at least four tomtom one’s
And one xl’s that i have tried,
First of all connect your tomtom to your computer.
making sure your online,Go to log on.
if you’ve not created an account create one now.
If you’ve had to create an account restart tomtom home.
You should have the tomtom home screen in front of you,
Now even if tomtom home is showing you logged in, ignore
this click your email adderss in the top right hand side of the screen
and log in again and click continue.
Then click Device/disconnect device.
Now your tomtom will update itself and your maps will be restored"
Jan 11, 2008 | Tomtom One Europe v2 GPS Receiver
Screen sais no map
If your tomtom gps is saying no map, the problem simply is that there is a problem on the gps device.
I have three suggestions for you to solve this problem. First, follow the step-by-step instructions for the "no maps found" situation in this link: http://us.support.tomtom.com/cgi-bin/tom…
If this doesn't work, follow the text instructions that I have written below. And as a final option, you can always call TomTom tech support at 866-486-6866 and they can help you out.
First of all, connect the device to your computer and close down TomTom Home software. (make sure it isn't even open in the system tray).
Now, open "my computer" and find the device. It will be labelled as a storage device (could be drive E:, drive F, etc. depending upon your computer). Open it up and find where the maps are saved to. Something like, North America, USA, or something similar relating the place you live. Once located, delete them manually.
Now, reopen TomTom Home software and go to "tools." Click ''use latest map guarantee''. It will then download the maps again and install them onto the device.
Next, disconnect using the option "disconnect device'' from the device menu.
Finally turn on your TomTom if it doesn't turn on automatically, and you should be back in business.
One additional tip: disable your anti-virus software before downloading & installing the updates. After this is complete, you can just restart you anti-virus.
Take care
Jul 02, 2010 | Tomtom ONE 3rd Edition GPS
Unable to find/use Canada Map on TomTom ONE 125
Nowadays TomTom provides all of its maps through TomTom Home desktop software.
You have to download and install that, and then connect you TomTom to your computer. Then you can browse through and purchase any of the available maps through the software providing you have room on your TomTom to hold the map.
Aug 02, 2009 | Tomtom ONE GPS Receiver
Down loading Europe on my TomTom 1/3
Yes you can I have europe and canada on mine.
just plug your tomtom into your computer and start tomtom home
On the computer screen for tomtom select ADD MAPS
Here you can select and buy the maps you need.
Once you have confirmed the purchase you will be given instructions on how to download etc
Some maps may take a little time to install to the tomtom itself.
you should also ensure there is enough space on your tomtom
If not you will have to get an SD memory card.
I use a 4gb one that still has lots of room to spare
Jun 07, 2009 | Tomtom ONE 3rd Edition GPS
Tomtom one 125 map
The reason the 125 is cheaper is because it only has the US map on it. Each map contains an activation file that prevents it from being used on different devices, so its doubtful that the other map will work for you. You can purchase the latest Canada/Alaska map from TomTom's site for $59.95.
Go to
http://www.tomtom.com/products/maps/
Select your device as the ONE 130 (since they don't have 125 on the site) and choose the Canada/Alaska map.
Jan 09, 2009 | Tomtom One Europe v2 GPS Receiver
No maps found
I had the same problem how ever after downloading all the software updates and pretty well evey thing that was available on the tomtom home sight suddenly the map was there. It could be a soft ware bug.
Mar 19, 2008 | Tomtom One XL GPS Receiver
Setting country on tomtom one
This TomTom comes loaded with 2 maps....Guam and the US with Canada. I too got stuck in Guam and it is not obvious how to get out of it. But here it is.
Go to Main Menu, then Change Preferences
Hit forward arrow twice
Go to Manage Maps
Hit forward arrow once and choose Switch Map
It should show you Guam and the US and Canada
Tap US and Canada and it should take you out of Guam!!
Mine did and I am now going to delete the Guam map.
Dec 28, 2007 | Tomtom ONE GPS Receiver
No maps found??
The problem is caused by a version mismatch between the Application version and the Map Version. They must both be the same. For example, if the TomTom has not had the application updated, but you updated the maps, the TomTom will not know how to read the file.
Make sure that if you are trying to use a version 815 map, that you are using a version 8.XXX application too. I had to upload two application version changes before I could read the new USA maps.
Dec 25, 2007 | Tomtom ONE GPS Receiver
Tomtom ONE GPS Receiver Logo
182 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Marvin
Marvin
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
