Question about Microsoft Windows XP Home Edition
I need to reinstall UXCore.dll as my computer can not find it when I try to open an attached picture in my inbox of Outlook mailer. How do I do that? I am using windows XP media. When I download UXCore.dll from the net to a temp file it is not an .EXC file. It is a 822 KB application Extension.Help Murray
  • 2 more comments
  • murpeg Apr 16, 2009
    The attachment is not blocked, I just can not open it by clicking on it. If I save the attachment to a temp file and then go to that saved file attachment, it opens just fine, so the attachment is coming through. I want, and used to be able to do, just click on the attachment in the e-mails I recieve and have them open instade of getting the current error message coming up "This application has failed to start because UXCore.dll was not found. Re-installing the application may fix this problem." Then I click OK and I get "Error loading C:\Program Files\Windows Live\Photo Gallery\WLX PhotoViewer.dll The specified module could not be found."
    Murray
    Try to open Outlook in Start > Run > Outlook /safe
    I did and it does not change anything ie the attachment gets the same error message.
    I do not have windows desktop search.
    Realize the attachment saved by me can then be opened by me. It is just how can I get UXCore.dll to be found so that the attachment can be opened right at the e-mail without me saving it?
    Thanks for trying to help.
    Murray
    Your uninstalling instructions worked fine but the problem is still the same,not fixed, when I try to open an attached incoming e-mail file. Thanks for trying to help. What else can I try?
    Murray
  • murpeg Apr 17, 2009
    I tried regsvr32 UXCore.dll and got this message "LoadLibrary (UXCore.dll ) failed - The specified module could not be found."
    What about if I delete, using Add or Remove,
    Windows Live essentials
    " " Favorities for Windows Live Toolbar
    " " Sign-in Assistant
    " " Sync
    " " Upload Tool
    as I do not use Windows Live, anyways. Would this maybe cure the problem?
    Murray
http://www.fix-all-dll-errors.com/uxcore.dll/
You can get that dll from here... :)
Posted on Mar 02, 2011
  • 3 Answers
This is because you are missing a file.
Step 1. You can download uxcore.dll here:
http://dllcentral.com/uxcore.dll/12.0.1111.1005/
Step 2. Paste this file into your system32 and system folder. Also putit in your syswow
Step 3. Navigate to your System32(32Bit OS) or SyWOW64(64Bit OS) Folder.
Note: The location of System32 or SyWOW64 is C:WindowsSystem32 (If you are using 32BitWindows)
C:WindowsSysWOW64 (if you are using 64Bit Windows) Step 4. Pastethe uxcore.dll into this folder.
Step 5. Run the game. It might work now. b>
Posted on Jun 28, 2011
    Champion:
  • 205 Answers
TRY THIS
To provide enhanced security, Microsoft Office Outlook 2003 is designed to prevent you from unblocking attachments.
Because Outlook is so widely used, it has been the target of several virus attacks in the past that have affected millions of people. Microsoft has acted to protect people from files, such as .exe and .bat files, that are often used to run malicious scripts when opened. Unfortunately this makes file sharing less convenient for many people, but security must take precedence.
Microsoft Office 2003 file types most commonly shared between people, such as .doc, .xls, and .ppt files, are not blocked.
If you need to share files that have file types blocked by this feature, you have several options, including the following:
  • Rename the files to include a temporary file type that is not on the list of blocked file types. For example, you might rename MyFile.exe to MyFile.exe_EXTRA, and then attach the file to the e-mail message. You can include instructions in the message to save the file with the correct name, for example, MyFile.exe, when the recipients save the file to their computers.
  • Use a program, such as WinZip, to package files before you attach them to your e-mail message. In your message, you can include instructions explaining how to extract the files from the package to make it easy for recipients to access the files.
  • Post the files to a secure network share. In your message, you can include a link to the share that you have given the recipients access to.
If your organization uses Microsoft Exchange Server, your e-mail administrator can control which file types are blocked. For more information, contact your administrator. If you are the e-mail administrator, you can learn more about configuring blocked attachment behavior in Outlook by referencing the Microsoft Office 2003 Editions Resource Kit in the online Deployment Center. See
Posted on Apr 15, 2009
  • 2 more comments
  • Rayan Tellis Apr 15, 2009
    Try This
    http://www.hanselman.com/blog/Unblocking...
  • Rayan Tellis Apr 16, 2009
    Do you you have Windows Desktop search ?
    Check if you are able to open the attachments
    Try stopping windows desktop services from Start > Run > Services.msc and do right click and click on stop. and then try opening the attachments
    If you have windows desktop search try uninstalling from add and remove programs > Restart your computer
    Then try..............
    Try uninstalling
    Windows Live Photo Gallery using windows clean up utility
    http://support.microsoft.com/kb/290301
    after installing WICU from MS website : Click Start > all Programs > Windows installer clean up utility > Select Windows Live Photo Gallery and click on remove
    Smartray83
    Try registering using the following command Go to start - run - type:- regsvr32 UXCore.dll make sure the file name is correct
    smartray83
I need to be able to send pictures again as i was up untill approx two or three weeks ago. About then out of the blue microsoft office email progam appears when i try to send a picture but i canot send...
When in IE > Tools > Internet Options > Programs tab > In Internet Programs section what do you have as Email program?
Can you select "Outlook Express" in Drop-down menu of Email option?
Try setting OE and score this solution.
Nov 15, 2010 | Microsoft Office Outlook 2003 for PC
I need to reinstall UXCore.dll file
Nov 09, 2010 | HP Pavilion dv6000z Notebook
How can i réinstall uxcore.dll as my computer
get it from this link below. make sure to follow instructions carefully and also create system restore point on your computer just to be sure:
Aug 05, 2010 | Microsoft Windows XP Home Edition
I have an EMail with 16 photos attached - it will not "go" nor can I delete it. How can I get rid of it?
Disconnect the network-cable from your computer, to block Internet access.
Start Outlook Express.
Instead of selecting the "Inbox" mail-folder,
select the "Outbox" folder.
Click once to select the E-mail message.
Use your mouse to "drag-and-drop" the message to your "Inbox" folder.
Close Outlook Express.
Reconnect the network-cable.
Open Outlook Express.
Check your "Inbox" for that "undeliverable" message.
Open the message, or delete the message.
Nov 05, 2009 | Microsoft Outlook Express
0x72ea54ab how to fix please
Just follow this repair link (http://www.corruptedfilerepair.com/File-Information/UXCore.dll-Windows-Live-Client-UX-Microsoft-Corporation.asp) and download the file named UXcore.dll
To download and install a DLL file, you will first need to download the DLL file and register it on your computer.
Oct 08, 2009 | Microsoft Windows XP Home Edition
Attachment fail to open in Outlook Express 6, and
go to extra and the options tab
then you go to security and remove the V out the box picture downloaden then you have acces to the attachment and you can open or save to hd
Sep 27, 2009 | Microsoft Outlook Express
Cannot use my pictures folder in windows XP, error reads Uxcore.d
Try re-installing uxcore.dll file.
To re-install UXCore.dll
Steps:
1. Download the DLL file from the download link on this page and save the file to one of the folders as seen in step 3. .EXE files do not need to be manually registered.
2. Backup the old version of the DLL file.
3. Click Start > Run and type in the following command:
Windows 95, 98, or Me:
regsvr32 \windows\system\UXCore.dll
Windows NT or 2000:
regsvr32 \WINNT\system32\UXCore.dll
Windows XP or Vista or Windows 7:
regsvr32 \windows\system32\UXCore.dll
Download File UXCore.dll
EXE (Executable) Files:
Steps:
1. Download the file to a folder on your computer
2. Scan the .EXE file using an Anti-Virus Scanner.
3. Run the .EXE file by double-clicking the file
ZIP/RAR Archives:
You will need to uncompress the files in the archive using WinRAR or WinZip first.
Nore : Default Location - c:\program files\windows live\installer\uxcore.dll
Jul 17, 2009 | Microsoft Windows XP Home Edition
Outlook Inbox items are being automatically deleted
hi,try uninstalling the security s/w and reinstall it.it should fix it.or google the outlook inbox repair tool...and should workout...
Feb 19, 2009 | Microsoft Office Standard for PC
Outlook express
dear fando,
This is usually down to a corrupt or over-full email inbox. Outlook Express is not very good at holding large amounts of emails especially if they have large attachments. I had a user this morning with a 2.5 GB inbox.
Backup/rename Inbox (C:\Documents and Settings\(User)\Local Settings\Application Data\Identities\{GIU}\Microsoft\Outlook Express\inbox.dbx -> inboxbak.dbx).
Outlook Express will have created a whole new Inbox.
Your email should now work.
Best wishes.
Jan 04, 2008 | Audio Players & Recorders
Microsoft Windows XP Home Edition Logo
7,788 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
