Question about Philips GoGear HDD6330 MP3 Player
Screen goes blank or freezes until battery dies sometimes or randomly
I have tried to restart and reset, the computer doesn't recognize it all the time or will at first then say its an unrecognized device, was trying to plug it in to fix it, and it was working at first, which it does sometimes, then just froze, and froze the computer screen for a second too. can't get the music off of it to save it or any other music/photos on to it. HELP!
  • 8,596 Answers
Make sure you back up all songs on the GoGear before attempting this solution.
1) Back up all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard).
-Tha Mp3 Doctor
Posted on Feb 11, 2008
SOURCE:
How do I unfreeze the computer
In case your Android smartphone is complete frozen and not responding to you at all, the above restart method won't work for you! To unfreeze Android smartphone that is dead froze, force restart it by holding the Sleep / Power key and the Volume Down key simultaneously until your device's screen goes blank.
This force restart key combo varies from device to device, so it is advised to check your device manual for the right combo. If your Android device has a removable battery, you can remove it and put it again and it will restart the device.
Jan 19, 2015 | Tablets & eReaders
How to reset a windows phone
Try these fixes if, for example, your phone randomly reboots, freezes or does not switch on, if an app crashes, if you have sound problems, or if the screen is blank:
1. Restart your phone.
Press and hold the Power and Volume Down keys simultaneously for 10-15 seconds. Release and the phone will restart. After this operation, you may need to set the date and time on the phone.
If the problem persists, reset and restore your phone as instructed below.
2. Reset and restore your phone.
Important:
  • This erases all personal content on your phone and restores the factory settings.
  • Before continue with the reset, make sure your phone's battery level is above 50%. To check the remaining battery life, go to Settings > battery saver. If you are not able to check it, or the level is too low, charge your phone for at least 20 minutes.
Reset your phone by using the built-in option in the phone settings. Select Settings > About > Reset your phone.
However, if you cannot access the phone settings, follow the steps below:
a. Disconnect the charger. Press and hold the Power and Volume Down keys simultaneously. Release the pressed keys when phone vibrates and then immediately press and hold the volume down button until the phone displays an exclamation mark (!) on the screen. Release the volume down key.
b. Then press the volume and power keys in the following order: volume up, volume down, power, and volume down.
c. Wait for your phone to reset, during the reset you will see gears rotating on the screen for up to 5 minutes, after which the screen goes blank for ~30 seconds and then your phone will restart.
d. Go through the initial phone setup. Make sure that you have the date and time set correctly on your phone (Settings > date+time).
Sep 02, 2014 | Nokia Cell Phones
Sylvania Netbook 7
sounds like the bios battery is dead , it looks like a watch battery and may be soldered to the motherboard. I would trash it and get something newer. any new android phone or tablet would be better.I would suggest the 7 inch fire tablet for $50
Apr 21, 2017 | Sylvania G-Netbook
My forerunner 50 is randomly resetting itself. Sometimes it shows Lo Batt but then doesn't sometimes the screen goes blank but pressing any buttton a few times brings the display back at which point I have...
Remove the battery, clean the contacts with alcohol, and replace with fresh cr2032 battery. Instructions are here: http://gnjmch.com/public/tips/GarminF50.Battery.html
Mar 05, 2011 | Sport & Outdoor - Others
Iphone 3GS- only get the apple loading screen.
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least six seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 29, 2009 | Apple iPhone 3G
IBM T30 screen ramdomly goes blank and computer freezes.
Reset your bios settings to "Bios defaults", then disable power management.
In Windows, go to device manager and try to detect new hardware. Follows screen instructions.
Mar 27, 2009 | IBM ThinkPad T30 2366 Notebook
My ipod is on stuck? it is not workin just turne on n freezed like that, so what i have to do?
When it freezes like that, it has to be reset.
You reset the ipod by pressing and holding the center button and the up (menu) direction key at the same time for 5-15 seconds. Hold until the screen goes blank, then release. It will restart itself and show the apple logo while it reboots. If you are holding it for a while and nothing changes, you can also try plugging it into the computer to see if that resets it. Hope that helps!
Nov 27, 2008 | Apple iPod nano
Blank screen
if this goes blank randomly, it could be that there's something wrong with the monitor or its starting to die on you. if there's a factory reset button on the monitor, you can try doing it and if that is still not going to resolve the problem then just get it replaced if its still under warranty and if not then get another one.
Oct 07, 2008 | X2Gen MG19MY 19" LCD Monitor
Philips GoGear HDD6330 MP3 Player Logo
85 people viewed this question
Top Philips Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
