Monitor screen is blinking.
My monitor screen is blinking. sometimes it stays for 10-15 minutes and then screen is gone and indicator starts blinking. how can i solve this problem? Please help.
It's a Samsung 14" monitor 1999 model.
  • ravelonii Apr 15, 2009
    where can i find the fuse? i can open the monitor cover but don't know anything about inside parts
    Where can i find the fuse? I can open the monitor cover but don't know about inside parts.
    Sergeant:
  • 326 Answers
Check the fuse first
Posted on Apr 15, 2009
L246WH blinking light problem
Probably the power supply is failing but periodically recovers briefly.
Jan 05, 2014 | LG L246WH-BN Monitor
The power LED of my compaq monitor blinks when powered. Sometimes it works well but after 20 minutes display disappears and it blinks the power LED.
if the light blinks orange after a few minutes after use. The monitor would either require repair or replacement since the power board has gone bad.
Thanks
Proton
Nov 13, 2010 | Compaq Presario 5000 PC Desktop
My LG flatron monitor just blinking from wide screen then to a smaller screen then it stops for a while then after 5 minutes its gone my monitor doest show or the power does'nt show even if I keep on...
Hi it could be the video card in your computer is going bad slowly or your monitor has a faulty,you should try connect a different monitor to see if the problem id still there if still there this mean the video card is going bad
Aug 15, 2010 | LG W1934S-BN 19" Monitor
Was watching a movie on my computer last night and all the sudden the screen started turning off and on with no picture when it was on. Has the monitor gone bad or is it a video card issue?
The simple way to check if this is a Monitor issue or not, you can unplug the monitor from the Computer and connect it only to the power outlet. If it gives you a "No signal" screen or goes through any sort of other Self test, Your monitor is fine. You can also check if the power led is blinking Amber or Green. A blinking Amber LED while the monitor is only connected to the Wall outlet indicates the monitor is faulty.
Thank you for using Fixya
Oct 08, 2009 | Dell E173FP 17" LCD Monitor
Dell E173FP Screen blinking red, green, blue, white
The monitor is probably on protection.
To start unplug monitor from power and from computer and test computer with different monitor to find out if it is monitor or computer fault.
If it is computer fault and no video signal , then test:
  • Video cable.
  • Video adapter on PC (sometimes integrated on motherboard)
  • Motherboard.
If it is monitor fault , then the monitor is on protection.
When on protection you keep having a flashing led on front of the monitor , and monitor turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or a broken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the monitor will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, faulty inverter board, faulty input board, or a fault on LCD Digital Controller board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
Try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Apr 16, 2009 | Dell E173FP 17" LCD Monitor
LG 700E monitor's power LED blinking continueously, no display
  • Video cable.
  • Motherboard.
Common faults that can occurr are a blown capacitor on power board, faulty inverter board, faulty input board, or a fault on LCD Digital Controller board.
Apr 08, 2009 | LG 500LC Monitor
The monitor gone blank white light nothing else
Check this FixYa thread:
http://www.fixya.com/support/t1372203-white_screen
It might be a loose cable or perhaps the video controller is bad. If the unit is out of warranty, you might be able to try to fix the cable.
Jan 27, 2009 | Sceptre X9G-NagaIV 19" LCD Monitor
Blue blinking light
  • Video cable.
  • Motherboard.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing statebecause of the video cable.
Jan 10, 2009 | Samsung SyncMaster 930B 19" LCD Flat Panel...
Black screen, blinking power light, no signal
Hi...there,
It's seems you got a defective DVI card. Try using a VGA cable instead. Have nice day!
Aug 22, 2008 | ViewSonic VX924 19" LCD Monitor
Computers & Internet Logo
244 people viewed this question
David Payne
David Payne
