Question about Brother MFC 7420 All-In-One Laser Printer
Brother MFC 7420 Fax/Copier-Black copies
I am experiencing black copies emerging from this machine. I was told by a Brother tech to change the drum. Drum was changed and the problem is still ocurring.
What can I do?
thanks
  • Ray M. May 11, 2010
    does it also print black when you run any kind of internal report from control panel?
    razors
    Genius:
  • 1,198 Answers
Check your owner's manual, and there's one in the install disk. It will show you where there are electric contacts inside where the drum is. You may have to take the drum out to see them. You're supposed to clean them with isopropyl alcohol on a q-tip. Don't get alcohol on anything else.
Posted on Apr 27, 2009
My Brother MFC-7420 Printer always prints black lines and splotches down the left side of my paper. This happens whether I'm scanning or printing from my PC. When I looked at my drum, it appears a
If you are seeing vertical streaks/black lines your primary corona wire is dirty and or the fax scanner may be dirty.
1)To clean the corona wire you take the drum unit and toner cartridge and place it on disposable paper to avoid spilling.
2) Clean the primary corona wire inside the drum unit by sliding the blue tab from right to left several times.
3) Return the blue tab and snap it into the home position.
4) Reinstall the drum unit and toner cartridge.
5) Close the front cover.
Caution: if you do not return the blue tab to the home position it may repeat the black lines.
Nov 29, 2012 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC 7420 change drum soon light, did, still says change drum soon, how do I rest the drum, I cannot find my manual. Tks
Simply open the front cover.
Press the Options key on the control panel.
The display will show "REPLACE DRUM - 1.YES 2.NO".
Press 1 to reset the drum count.
This procedure wil work on the majority of the Brother MFC series of laser based Printer Scanner Fax Facsimile machines.
Good Luck and Thank You for using Fixya
WheatlandServices
Nov 05, 2010 | Brother MFC-7420 Printer
I have changed cartridge and drum in the printer
If the cartridge has irregularities on it you will get poor results. The large black roller should be smooth all the way around. Any bumps will cause lines and spots. It is not recommended but I have had luck cleaning that large black roller. Once smooth the lines went away.
May 18, 2010 | Brother MFC 7420 All-In-One Laser Printer
I am getting a light duplication on my copies half
The duplication problem can be either the drum or the fuser. Most likely your drum needs to be replaced. If you can measure the distance between the first print and its duplicate I might be able to help more.
thanks adi
Dec 15, 2009 | Brother MFC-7420 Printer
Copier, Printer black streaks on copy or all black page
Hello sir; Either drum cleaning blade or drum cartridge needto replace.
Aug 20, 2009 | Brother Office Equipment & Supplies
Mfc-7420 Black Line horizontal across paper in 3 places
try moving the small blue slider on top of the drum cartridge side to side 10 times.
Mar 10, 2009 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC-8820D Prints a COmpletely Black Page
You have a defective or disconnected SCANNER BLOCK
Mar 06, 2009 | Brother MFC 420CN All-In-One InkJet...
Brother MFC-7420 prints black pages
The drum is defective. The cleaning blade has failed.
Jan 31, 2009 | Brother HL-2040 Laser Printer
Brother MFC 7420 All-In-One Laser Printer Logo
119 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
