DIR-615 D-Link Router Problems...!
I just got a D-Link DIR-615 wireless n router and as i placed the disc in my comp and started installation i came across error 313 "multiple wired adapters detected" so i have tried many differant ways in connecting my router but still no sucsess can anybody help? p.s i am not very computer literate...
    Genius:
  • 1,269 Answers
Try to reset the router first by pressing the reset button at the back of the router for 20 seconds then power cycle it by unplugging the power for 30 seconds then plug it back in. Here's how to set it up
1. You don't need to use the setup CD that came with it.
2. Make sure you have the proper physical connection
3. From your modem, connect the ethernet to the Internet/WAN port of the Dlink, then your computer to port # 1.
4. Do a power cycle. Unplug power to router and modem. Wait for 30 seconds. Power on the modem first, wait for all the lights to steady then power on the router. You should be all set
Posted on Apr 15, 2009
I lost my installation cd for d-link dir-615 wireles router where can i download the same cd
Access the manufacturer's web-site:
ftp://ftp2.dlink.com/PRODUCTS/DIR-615/
Select the "Revision Level" of your router.
Then, download the software/quick-install-guide/manual for your router.
Apr 04, 2014 | D-Link DIR-615 Wireless Router
Computer says that the pin number is incorrect, please use no. on modem. modem nuber keeps coming up incorrect
You should refer to your wireless router setup manual for pin number....
you can also prefer this link to search modem pin no-http://www.dlink.com/uk/en/home-solutions/connect/routers/dir-615-wireless-n-300-router
Sep 03, 2012 | D-Link DIR-615 Wireless Router
D-Link DIR-615 Wireless Router not connecting with HP Network Printer
Please use the utility disc that comes with your printer. It will help you to connect your printer to your wifi router.
Or please check if you type the correct SSID of your wifi (Wifi Name). SSID are case sensitive.
Nov 04, 2011 | D-Link DIR-615 Wireless Router
I am connected to a DIR 615, it says I have wireless connection but it won't connect wireless, if I connect a cable it is fine??
Hi mike63771,
All you need to do is to set it up properly. Make sure that the router is connected to the computer using an ethernet cable so that the computer will be able to communicate with the router. Then open a browser type 192.168.0.1 on the address bar. The default username is admin and the password is blank. Go to the Wireless Settings Page then check the SSID or Network Name and the Network Key or Passphrase. Now try to connect to your computer. Click on Start then click on Connect To. Select your Network Name then if it ask you to enter a password enter the Network Key. You can personalize the network key on the router settings page.
Rate me if this helps so i can help other.
Thanks for using Fixya.
Feb 02, 2011 | D-Link DIR-615 Wireless Router
Cant remember wep key
In order to find the wireless security page of your Dlink wireless router DIR-615 , please follow these setps
1. Open up the internet explorer in the comp in which you are online and clear the address bar and type in the number 192.168.0.1 and hit enter.
2. You will be logged into the D-Link router setup page .
3. Under the SETUP tab, in the left hand side, click on WIRELESS SETTINGS? you will find Wireless security Mode under which you can find the password for the wireless settings.
Good Luck!
Thanks in Advance!
With Regards,
Prema.
Jan 11, 2011 | D-Link DIR-615 Wireless Router
How do I find out a password that has since been forgotten for the router?
Good Luck!
Thanks in Advance!
With Regards,
Prema
Dec 31, 2010 | D-Link DIR-615 Wireless Router
How do I reinstall a dlink 615 modem. mcafee syys a trojan has been identified each time I try the install disc. can I install without the disc and how?
I can help you with your DLink DIR-615 router problem.
You don't really need to run anything from the disc to install a router - there is no setup program on the dlink cd you are required to run. Routers operate independently of the computers they are plugged into.
The most useful thing on that disc is the user manual, which you can download direct from DLink here. Any other bits and pieces that are on the 'installation CD' are also available from their webpage.
I hope that helps.
Aug 28, 2010 | D-Link DIR-615 Wireless Router
My D-Link DIR-615 seems to drop the wireless connection often but the wired works fine. Any fix
1. Please check your D - Link router should be not placed in corner.
2. Please check your D - Link router is placed on some open place.
3. if your notbook and router is visibale to each other then you can get better wireless connection.
Mar 13, 2010 | D-Link DIR-615 Wireless Router
I have DI-604 in line between Windows Vista computer and cable modem. Works fine. Bought DIR-615 (wireless). Several places instructions say, ""Insert the DIR-615 CD into computer and click Install Router....
Contrary to the many warnings not to install the router before starting the installation with the CD, I got the installation to complete only AFTER I installed the router inline thusly:
1. Power everything off.
2. Remove DI-604.
2. Install and connect 615 router to computer and to modem.
3. Apply power to router and modem.
4. Apply power to computer and wait until Windows loads.
5. Insert 615 installation CD.
6. Follow the directions.
Nov 22, 2009 | D-Link DIR-615 Wireless Router
Computers & Internet Logo
961 people viewed this question
David Payne
David Payne
