Question about Kenmore 24.8 cu. ft. Trio French Door Bottom Freezer Refrigerator
Water not coming out of Fridge door dispenser- was working and seemed to freeze up at exit- still not working after clearing- buzzes so there is power
  • 122 Answers
Replace the switch on the door behind the lever that you push.
Posted on Apr 15, 2009
Water dispenser in door does not dispense
Had this happen on my LG side-by-side a few years back. It's a common part. Find the version for your make and model. Easy ti replace. It is located where the water suppy connects to the bottm refridge.
http://www.amazon.com/LG-Electronics-MJX41178908-Refrigerator-Water/dp/B00AUDAJ0I
Oct 25, 2015 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice and Water dispenser is inoperable.
I had a GE Fridge at one time and had issues like yours.
If you disconnected the connector at the door that supplies the dispenser with power, you would not measure any voltage on the dispenser side, only on the 'fridge' side. Measure the power with the connector connected, but that may not tell you a lot, unless you have the service manual.
If you push the water dispenser and you do not hear the little valve kick on behind the fridge, suspect a couple of things. A faulty inlet valve (usually located lower rear of fridge on backside). It may be disconnected. Had this happen once on a new fridge - it had been disconnected from the factory.
You may have one problem or two issues, but let's continue...
Do you push the ice dispensor and nothing happens? Or are you telling us that the dispenser works but there is no ice? The faulty valve mentioned above will prevent ice dispenser from filling to make ice.
Also, there is RESET button hidden in the freezer a well. I can't remember where it is but the little arm to make ice has to be in position to tell it to make ice, and you have to follow the procedure in yourf ridge manual to reset it. It's
Another problem I encountered, but this was just with the cold water dispenser, was that the water line would FREEZE in the fridge door, preventing water from getting to the dispenser and my cup. It wold make ice but no water. In that case I had to get a small squirt bottle with a long nose on it and shoot hot water up into the dispenser nozzle to clear the ice in the line. That only happened a couple tines a year, though.
Here's a video that may help: https://www.youtube.com/watch?v=fPeZ29XdX5U
Sep 05, 2015 | GE Monogram ZISS480DRSS Stainless Steel
Double door whirlpool refrigerator with ice and water dispenser on door. The problem is that the ice dispenser seems to freeze up and therefore does not come through door. Everything else works fine. Any...
yep that is a systemic problem with that fridge, you need to pull the ice bucket out about once a month or so, empty and clean. I suggest you do this just before you go to bed that way you have ice the next morning. this is just maint.
Sep 03, 2012 | Whirlpool 25.6 cu. ft. Side-by-Side...
My Amana french door/bottom freezer is leaking water. Did the procedure with hot water the drain in back of the freezer, although it seemed clear of ice. That didn't help. The leaking stops when I...
Two possibilities:
1. A cracked plastic tube. These will leak whenever there's a call for water - either the chilled water dispenser, or re-filling the icemaker tray (two seperate tubes). Pay particular attention to anywhere the tubes are clamped to the chassis; anywhere they're routed near or under the refrigeration unit; and near the solenoid valve - especially if there's a tight loop in the tube there.
2. A bad (leaking) connection where one of the tubes exits the water valve. Again, these will leak whenever the valve is activated.
Those plastic tubes don't last forever. I've replaced many of them for the same symptoms. They're known to simply deteriorate with age.
Manuf's make good money selling replacement tubing kits.
Aug 15, 2011 | Amana AFB2534DE Bottom Freezer French Door...
We have a Hotpoint side by side fridge. It always makes
check the door in the dispenser if moisture is condensing and freezing so that the door won't open try manually popping the door open just before you attempt to dispense ice, maybe you'll get lucky, otherwise your going to have to get a technician to come and check the micro-switch for the dispenser
Dec 05, 2009 | Refrigerators
Water does not dispense from door
I found that the door on the GE side by side doors are not accessable and cannot be repaired if a water line inside the door is defective. The entire door must be replaced at a cost of almost $370. The problem, which seems to be quite common relative to the lack of water at the dispenser, is the result of the water tube in the door freezing due to excess cold levels in the freezing compartment. This is probabley due to poor insulation around the water line as in exits near the ice dispenser gate. The solution is simple, lower the freezing level and use water frequently to keep it from freezing. Also, keep the lines clean by changing the filter often if the local water source is laden with particulates. I think GE should foot the bill for changing doors or re-engineer the doors to access the area where the water line makes contact with the cold surface of the inside panal.
Nov 11, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
No water from dispenser
Frig is set too low of temp Water is freezing in tubing chill coil
Jun 07, 2008 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Water dispenser : the water freeze
All,
I hve the same problem of the water not coming out. After reading this forum that suggested this is caused by a frozen line, I increased the temperature (less cold) of the fridge and freezer, and turned on the light (generates heat in the area). After a couple of days, the water worked.
Tom Z
Feb 04, 2008 | GE GSH25JFR Side by Side Refrigerator
Water dispenser in fridge door
Email me for the bulletin on water line freezing. Try turning on the dispenser light for 24 hours this should defrost the line.
amasuperbike@comcast.net
Jan 15, 2008 | Refrigerators
The water filter keeps freezing and food in door and on shelves keeps freezing.
clean lint from coils in back. could also be low on refrigerant (freon)
Jul 09, 2007 | Admiral 26 cu. ft. Side-By-Side...
Refrigerators Logo
374 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
