Question about Grohe Home
I have agrohe shower fixture with poor pressure
I have a grohe shower fixture with poor pressure any suggestions
  • heatguy May 11, 2010
    dont know if this is new install but if so you may have debri in water lines that tends to end up in shower fittings grohe also has strainer in some fittings to catch debri also remove shower head and see how pressure is with out head installed
  • 74 Answers
If the shower head is clogged (even if it it is not I would still do this)
remove the head and soak in coke (yes, it works), CLR, vinegar or bleach and see if you can dissolve the debris. If that is not the culprit, check to see if there is access to a shut-off valve behind or below the shower. It will be inside of the wall and is only acessable through a hole in the wall.
If that is not the case, it is now time to consider replacing the shower body. This is an involved job but something very doable by a competent homeowner.
Hope this helped.
Posted on Apr 16, 2009
I can't get shower head pressure from the outer head of my new grohe freehander.
Everything you installed new. Please chack if not one of the gaskets came in a pipe or a line. I once had a rubber ring almost complete blocking the water flow.
Nov 01, 2014 | Grohe Shower Freehander 27 007 Chrome...
Not enough pressure
I would suggest not enough pressure. If the hand shower is connected to the taps then pressure would be the problem as the water comes from the tank in the loft fed by gravity. Solution is a power shower.
Jan 28, 2014 | Grohe Home
Brown water comes from tub faucet
it may not be your grohe valve it could be your hot water heater check a o smiths web site about rust color water its actually a bacteria
Feb 23, 2013 | Grohe Home
How to change spray hose on grohe kitchen sink ladylux model
I have the Ladylux plus. I was confused on how to remove this as well. There is a quick release plastic piece, just pull down on the yellow part on the connector under the sink. Disconnect the plastic connector from the hose and pull it right out of the faucet. Very easy to remove in this case.
Jul 07, 2010 | Grohe Model 28 206 OOO: Ladylux Plus...
Looking for tank psi trying to get better water psi out of the shower and taps
Every faucet and shower have a water saving restricter in them. Remove them from the shower head and end of the faucets.
They are about the size of a dime and with about 1/8" hole in them in which water flows out. So the flow is getting restricted from 1/2' flow to this giving you a water saving about a 1.5 gpm.
Below is some more information for the web site please check it out for further help.
http://www.inspectapedia.com/water/Poor-Water-Pressure-Diagnosis.htm
Poor water pressure just at certain plumbing fixtures? poor cold water pressure, hot water pressure, or both hot and cold water pressure or flow that is observed just at some plumbing fixtures in a building while flow and quantity are good at others suggests that the water flow or pressure problems are local to certain runs of supply piping or to the specific fixtures. Check the following first:
  1. Clogged aerator or strainer on sink faucets - clogging by dirt, debris, corrosion, can significantly reduce both hot and cold water flow at a sink where the strainer needs cleaning or replacement. Unscrew the strainer from the faucet and turn on the water - if the fixture pressure or flow is much better you've probably found the problem.
    Look at the aerator/strainer: inspect it, clean it, perhaps soaking it overnight in vinegar to remove corrosion and mineral build-up, or just install a new aerator/strainer.
Jun 04, 2010 | Plumbing
Leak where Grohe shower head attached to the threaded pipe
Hello, Many shower heads have similar problems. (Very frustrating as you now know) The problem is the threads at the end of the (cheap plastic) shower neck are not flat. They are tapered (has an edge) - so it does not seat flush with the base of the shower head. Actually cuts around the rubber washer causing a leak.
What to do about it?
File the end of the neck some to create a flat surface. However, go slow. Be sure you can still screw on the shower head. Add a flat rubber washer in the shower head and plumbers tape on neck threads too.
Or Purchase a new shower neck that has a better design. The neck should unscrew from the front. Check and make sure you have an access behind the shower just in case you need to access the plumbing.
I replace the shower neck myself if there is an access.
Rob
Jan 17, 2009 | Grohe 28.275.AV0 Relexa Plus Top 4 Spray...
Home Logo
719 people viewed this question
Top Grohe Home Experts
Mike
Oloyede Monsuru
Are you a Grohe Home Expert? Answer questions, earn points and help others
