Question about Simer 3/4 Hp Stainless Steel Sump Pump
Hammering sound at shutdown
Why does my 1/2 hp simer submersable sump pump make a hammering sound when its done pumping water? from jj
  • 332 Answers
It has a check valve to keep the water from going back into the pit when it shuts off, depending on how high the pipe goes up when it stops pumping the water closes the check valve in which the noise, unfortuintly there is no quick fix, even changing the check valve it could still make the sound
Posted on Jun 23, 2009
  • gary miller
    gary miller Jun 30, 2009
    the checkl valve is shutting,, keeping the water from cumming back in thru the discharge line, sorry about the noise but this is typical with some pumps and check valves
I have a Simer 2305 and the pump will run but does not when the water is low?
Pumps such as the Simer 2305 do not pump water totally down to ground level. They are designed so they do not suck up debris , sediment, etc, which can clog and ruin the pump. So if your pump leaves an inch or so of water, that is normal.
Mar 15, 2014 | Simer 2305 Geyser II 1-4 HP Submersible...
How can I adjust the float?
You can't adjust the flost on those pumps... there is a magnetic switch that turns the pump on when the float gets to the top...
The only way to adjust the water level is to adjust the hieght of the whole pump...
heatman101
Feb 23, 2011 | Flotec Simer//Omni 2957 Submersible Sump...
WHY WILL MY FAN NOT TURN?
what fan, do you mean the empellor on bottom? How do you know its not, if you plug it in and hold it up in the air, it won't turn it needs to have water or it will burn up, if you have physically tried to turn the empellor and its locked the bearings went in it, replace, no good.
Aug 02, 2010 | Simer 2905 Mark I 14 HP Submersible...
My Simer 2300-03 has been great except that it overheats after awhile. Too little water??
Yes. I recently used a similar pump (Flotech 1/6 hp) running for about 24 hours - but it came with this warning "don't use continuously unless submerged in at least 4 inches of water". This is because it will easily overheat, as yours has been doing. Mine worked for pumping water out of my basement (not the speediest little pump), but only because there is a sump hole in the floor where the pump could remain submerged.
Mar 31, 2010 | Simer 1/6 Hp Submersible Utility Pump
I have a Campbell and Hausfeld submersible pump,and the pump comes on every 8 minutes, pumps out for 5 minutes, then shuts off. Trying to find out if the float switch is going bad before buying a new pump.
Is the pump pumping out water when it comes on? If it is than it may be running as it is designed and you may want to look in to why you are getting so much water in the sump. Once the sump is filled to high enough level it will run the pump until the water level is at a low enough level. In other words the ON level switch is much higher than the OFF level switch.
Nov 02, 2009 | Flotec Simer//Omni 2957 Submersible Sump...
Can hear pump running but no water comming out
pull pump out of crock and see if the bottom is clogged
Oct 04, 2009 | Simer 1/3 Hp Submersible Sump Pump
My simer model 3986 ocaisionally does not start, is there anything that needs to be cleanded or lubricated with the switch mechanism?
Does yours have a float or internal switch on the bottom to turn it on ...
If the switch is in the bottom, the hole that allows water in (to create pressure to activate the switch to turn on the pump is dirty and/or clogged) Clean it.
I hope this solves your trouble
a
Sep 27, 2009 | Simer 1/2 Hp Thermoplastic Submersible...
What kind of is used in a simer submersible
The Simer brand of submersible dewatering pumps rely on being fully submersed in water for proper cooling and for the seals to remain water tight and effective.
According to the manufacturer, there is no oil used in the pump, other than a very small amount that was used in assembling the pump at the factory, so you shouldn't oil the pump, but rather follow the recommendations as to making sure the pump is installed properly.
Here's the owners manual for your particular pump (Model #2300) so you can check the troubleshooting FAQ's and so you can also contact the manufacturer, should you need replacement parts or need to make a warranty claim, etc.
http://www.simerpumps.com/pdf/1000001370.pdf
Hope you find this Very Helpful and best regards!
Sep 17, 2009 | Simer Plumbing
I have a simer pump 120 volt 60 hz 1/2 hp ser #70285 and the flot is getting stuck on and the pump wont shut off what can I do and where would I get a nother flot at
take a tie strap and readjust the float,, lower the float so it won't let the float get to the top of the pump or zip tie it to the pipe away from the pump,, you don't need a new pump or switch
May 16, 2009 | Simer 1/2 Hp Thermoplastic Submersible...
How do you get it apart to install new electric cords?
Not 100% sure about this, but I think you'll find the answer is... you don't.  In all submersible pumps that I'm familiar with, the cable is part of a unit that's sealed during manufacture so that water can't get in to the electrics.  If your cable is damaged, I think you have to replace the whole unit. Sorry! Of course, if you just want to extend the cable, you can get a waterproof connector.
Apr 15, 2009 | Simer 1/3 Hp Submersible Sump Pump
Simer 3/4 Hp Stainless Steel Sump Pump Logo
241 people viewed this question
Top Simer Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Simer Garden Expert? Answer questions, earn points and help others
