Question about IBM RADIO S115 80G2715 Wireless Adapter
A B181F7BB reference code occured in the beginning loading pSeries type 9110-510 server. The system console is not available,control panel is faulty (there is no indication, the buttons does not works). I have a PC and can attach to one of the HMC ports and launch a browser, then work at the Advanced System Management Interface (ASMI)/ What I can do to solve this problem. please help me out
  • 3 Answers
SOURCE: wont print on line
You may need to have some driver installed on your PC, that can be downloaded from some IBM printer web site, such as this one:
http://www.infoprintsolutionscompany.com/internet/wwsites.nsf/vwWebPublished/supportdownloads_ww
IBM does not manufacture printers any more, they outsourced that to other places like Lexmark & ProPrinter, so we have to figure out which outsource place is relevant & what name they have for whatever corresponds to 6400 driver.
Posted on Nov 12, 2008
SOURCE: ibm audio driver
THank for programs
Posted on Apr 27, 2009
SOURCE: need ethernet controller driver for ibm pc
http://www-307.ibm.com/pc/support/site.wss/MIGR-55830.html
all drivers manuals
Posted on May 02, 2010
nonontech
  • 4737 Answers
SOURCE: module: x3200m3 type:7328 i7s server how many lan (RJ45) ports
Only two ethernet ports onboard. You can configure or add cards as per your requirement...
Please refer the graphic below;
Ibm System x3200 M2 server motherboard
Good luck.
Thanks for using FixYa.
Posted on Jun 28, 2010
SOURCE: i have updated drivers of
I have the same problem after installing updates with UpdateXpress...
Do have yor problem solved?
Posted on Feb 12, 2011
I have a 2005 Buick Terraza. When I put in gear and drive it starts dinging and indicates that a side door is not closed. They are and I have cleaned the contact plate.
This warning indicator is controlled by the BCM - body control module . You cant turn it off , you need to fix the faulty input switch that signals the BCM that the door is open .
Body Control Module
The various body control module (BCM) input and output circuits are described in the corresponding functional areas indicated on the BCM electrical schematics. The BCM functions include the following:
• Battery rundown protection--Inadvertent power--Refer to Interior Lighting Systems Description and Operation in Lighting Systems.
• BTSI/automatic transmission shift lock control--Refer to Automatic Transmission Shift Lock Control Description and Operation in Automatic Transaxle - 4T65-E.
• Bulb check--Refer to Instrument Cluster Description and Operation in Instrument Panel, Gages, and Console.
• Chimes--Refer to Audible Warnings Description and Operation in Instrument Panel, Gages, and Console.
- Check gages
- Content theft deterrent
- Door ajar warning
- Headlamps ON
- Key-in-ignition
- Oil reset
- Park brake warning
- Seat belt not fastened
- Turn signal ON
- Vehicle theft deterrent
• Door lock interface--Refer to Power Door Locks Description and Operation in Doors.
• Exterior and interior lighting control--Refer to Exterior Lighting Systems Description and Operation in Lighting Systems.
- Automatic lighting control
- Backup lamps
- Daytime running lights (DRL)
- Fog lamps
- High/low beam head lamps
- Park brake lights
- Turn hazard lamps
• Gage control--Refer to Instrument Cluster Description and Operation in Instrument Panel, Gages, and Console.
• Heated seats--Refer to Heated Seats Description and Operation in Seats.
• Horn interface--Refer to Horns System Description and Operation in Horns.
• Instrument cluster indicator control--Refer to Instrument Cluster Description and Operation in Instrument Panel, Gages, and Console.
• Interior lighting--Refer to Interior Lighting Systems Description and Operation in Lighting Systems.
• Key-in-ignition sensing--Refer to Audible Warnings Description and Operation in Instrument Panel, Gages, and Console.
• Parking brake state sensing--Refer to Brake Warning System Description and Operation in Hydraulic Brakes.
• Retained accessory power (RAP)--Refer to Retained Accessory Power (RAP) Description and Operation in Retained Accessory Power.
• Rear compartment interface--Refer to Power Door Locks Description and Operation in Doors.
• Rear defogger--Refer to Rear Window Defogger Description and Operation in Stationary Windows.
• Remote function control--Refer to Keyless Entry System Description and Operation in Keyless Entry.
• RFA communication link--Refer to Keyless Entry System Description and Operation in Keyless Entry.
• Seat belt use sensing--Refer to Seat Belt System Description and Operation in Seat Belts.
• Theft deterrent vehicle/content--Refer to Theft Systems Description and Operation in Theft Deterrent.
• Washer solvent level sensing--Refer to Wiper/Washer System Description and Operation in Wipers/Washer Systems.
• Wiper/washer--Refer to Wiper/Washer System Description and Operation in Wipers/Washer Systems.
As far as the sliding doors , pull the fuse's
Jan 12, 2018 | Buick Cars & Trucks
1998 chevy cavalier where is the BCM (body control module) located?
You have no idea what your messing with . Theft light on , DTC'S - diagnostic trouble codes stored . Before you start replacing BCM an making matters worse ,do yourself a favor an take it to a qualified repair shop .
The powertrain control module (PCM) communicates with the instrument cluster using serial data over the UART serial data bus, CKT 800. When the instrument cluster determines a Pass Theft condition, the instrument cluster sends a coded password to the PCM. When the instrument cluster receives the correct password, the PCM enables the fuel injection system in order to allow the vehicle to operate normally. The PCM may allow the vehicle to start and stall quickly during a failed theft condition.
The Passlock™ lock cylinder is a locking cylinder that turns a rotating magnet past a stationary hall effect sensor. The rotating magnet creates a resistance code (R-Code) that the cylinder sends to the instrument cluster. The Passlock™ lock cylinder interfaces with the instrument cluster through a 3 wire connection. The 3 wires have the following functions:
• Power
• Ground
• Data
The THEFT SYSTEM indicator will not light under any circumstances.
Replace the instrument cluster.
For Chevrolet vehicles, refer to Instrument Cluster Replacement .
For Pontiac vehicles, refer to Instrument Cluster Replacement .
Multiple indicators light continuously.
Test for a loss of serial data. Refer to Data Link Communications System Check .
Instrument cluster DTC B1021 sets.
The DTC indicates a loss of powertrain control module (PCM) serial data. Refer to Data Link Communications System Check .
Instrument cluster DTC B1022 sets.
The DTC indicates a loss of SIR serial data. Refer to Data Link Communications System Check .
Instrument cluster DTC B1023 sets.
The DTC indicates a loss of ABS serial data. Refer to Data Link Communications System Check .
Instrument cluster DTC B1011 sets.
Refer to DTC B1011 Passlock Cyl Data Shorted This Ign Cycle in Instrument Panel, Gauges and Console.
Instrument cluster DTC B1012 sets.
Refer to DTC B1012 Passlock Bad R-code This Ignition Cycle in Instrument Panel, Gauges and Console.
Instrument cluster DTC B1013 sets.
Refer to DTC B1013 Passlock Bad Timing This Ignition Cycle in Instrument Panel, Gauges and Console.
Instrument cluster DTC B1014 sets.
Refer to DTC B1014 Passlock R-code Unprogrammed in Instrument Panel, Gauges and Console.
Instrument cluster DTC B1015 sets.
Refer to DTC B1015 Passlock Cluster Fail Enabled in Instrument Panel, Gauges and Console.
Instrument cluster DTC B1017 sets.
Refer to DTC B1017 Passlock R-code Learn Failed in Instrument Panel, Gauges and Console.
The indicator flashes and no instrument cluster codes are set.
So , do yourself a favor an have a qualified repair shop check it out .
Jul 22, 2016 | Cars & Trucks
Service engine soon light is staying on and computer is not showing a code
How does the vehicle run ?
Malfunction Indicator Lamp (MIL) Always On
Circuit Description
Ignition voltage is supplied to the malfunction indicator lamp (MIL). The powertrain control module (PCM) turns the MIL ON by grounding the MIL control circuit.
MIL Operation
The MIL is located on the instrument panel (IPC).
MIL Function ?€¢
The MIL informs the driver that a malfunction has occurred and the vehicle should be taken in for service as soon as possible.
The MIL illuminates during a bulb test and a system test.
A DTC will be stored if a MIL is requested by the diagnostic.
You could have a bad instrument cluster ! Here is part of diagnostic flow chart for your vehicle !
Did you perform the Diagnostic System Check-Engine Controls?
Go to Step 2
Go to Diagnostic System Check - Engine Controls
  1. Turn OFF the ignition.
  2. Disconnect the PCM.
  3. Turn ON the ignition, with the engine OFF.
  4. Observe the MIL.
Is the MIL illuminated?
Go to Step 3
Go to Step 5
  1. Remove the instrument panel cluster (IPC). Refer to Instrument Cluster Replacement in Instrument Panel, Gages, and Console.
  2. Test the MIL control circuit for a short to ground. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Did you find and correct the condition?
Go to Step 6
Go to Step 4
Replace the IPC. Refer to Instrument Cluster Replacement in Instrument Panel, Gages, and Console.
Did you complete the replacement?
Go to Step 6
5
Replace the PCM. Refer to Powertrain Control Module Replacement .
Go to Step 6
Jul 09, 2015 | 2004 Pontiac Aztek
Maytag neptune mah8700aww has an error tE, lower case t and upper case E.
"te" error code is caused by a faulty thermistor; likey cause is:
a. Loose wiring at the control panel (directly behind the cycle selector knob)
b. Broken wire at the thermistor (located at the bottom/front of the tub)
To access the wire plug connectors at the control pannel, remove the top cover of the washer. Stand in front of the washer and look for the plug connectors behind the control panel. Pull apart the plugs and re-install.
Test the washer. If the "te" error still occurs it will be neccesary to remove the front panel as well (two sets of special plier-type tools are needed).
Inspect the thermistor closely, with good lighting. If there's a break in the wire it will be at or near the black sheathing / heat shrink material.
Just like a reference guide, this service manual could helpful: MAH9700AW
Hope this helps.
Oct 07, 2011 | Maytag Neptune MAH5500B Front Load Washer
Getting an error an error has occured you have been signed out of ps network 80710A06
You are not the first to complain about this today. This is a general problem at the moment, so don't fret.....
The error code as to do with a network/server problem......
Usually, when PSN server is down, it makes this type of error to occur. I believe they are working on the servers.
There is no easy fix to this, you just have to wait for an unknown amount of time till the network server comes back again.
You can reset your network and try again. Or If you have a friend that uses PS, check if that of your friend has this same error........
Regards.
Apr 21, 2011 | Sony Playstation 3 (PS3) Console
PS3 sign in..unable to sign in .Error code..80710A06. Phone number leads Nowhere and Website link website won't load
Welcome to Fixya. The PlayStation Network is down at the moment. Sony Entertainment is working on this. The code is from Sony and nothing to do with you system. you can refer to http://blog.us.playstation.com/2011/04/21/latest-update-on-psn-outage
Thanks for using Fixya.
Hey my Ps3 can't log on psn what shall i do ?? it said a code and i tryed to search the problem on google and I found out that i had to reset my hold system then I did that... and now it says An error...
You are not the first to complain about this today. This is a general problem at the moment....
Regards...
Module: x3200m3 type:7328 i7s server how many lan (RJ45) ports
Good luck.
Jun 28, 2010 | IBM System x3200 M2 Server
Unix
Improving UNIX server performance NOTES.INI settings Most NOTES.INI settings that affect IBM® Lotus® Domino® server performance apply to all UNIX® platforms.
NSF_Buffer_Pool_Size_MB Many machines that run UNIX have very large amounts of physical RAM. Use the parameters NSF_Buffer_Pool_Size_MB or PercentSysAvailable Resources to control how much memory Domino is allowed to use. Each Domino instance on a UNIX machine can reference a maximum of 4GB of RAM.
Disk and memory requirements When a UNIX system runs Domino server software, the server must have enough disk space for program and data files and enough memory to handle swapping and the number of processes. You can also change several system parameters to improve server performance.
Disk I/O tuning Maintaining multiple file systems for operating system files, swap space, transaction logs, and data improves overall server performance.
Use RAID 0+1 hardware for the disk drives on which the data files reside. Use multiple smaller disk drives instead of a few large disk drives for Domino data. Domino does not perform simple predictable sequential reads; therefore, disable Read Ahead Cache and enable Write Cache.
Keeping swap space on its own separate striped volumes improves server performance at high loads. The transaction logs should always be on the most reliable and highest performing disk subsystem available to the system hosting the Domino server. Transaction logging must be on its own disk drives for improved server restart time, reliability, and availability. The logged transactions are written to disk as fast serial writes to a sequential file that is of configurable size in 4K blocks.
Console and database logging To improve server performance, limit the amount of information that is logged to the log file (LOG.NSF) and the console.
Feb 21, 2009 | Computers & Internet
Debian on p655
Are you over thinking this? Have you checked the source and target media's file systems for 1: errors and 2: suitability of file system format? Have you confirmed the integrity of the source files? Questions like this can seem simplistic but when diagnosing any problem always start at the beginning. You are using an distro installer that is suitable for an IBM p655's architecture.
Aug 29, 2007 | IBM pSeries p655 Server
Computers & Internet Logo
984 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
