Verizon's DSL modem, Westell 6100, has only one ethernet jack. I'd like to connect two Windows XP computers to the modem. Do I need a hub, a router, or something else?
-   I have 2 pc. I want to hook them both to the westell 6100. would it be possible to hook 1 up as ethernet and the other usb, without conflict. The westell 6100 is a modem/ router and since they are not laptops I was thinking I dn't need a router. Any help would be nice.
-   minigamer38
Feb 04, 2009
-   i want to add a super g wireless router but theres onev ethernet connection-   Guest
Jan 04, 2009
-   need a updated driver for my westell 6100 modem any help?? -   Guest
Oct 16, 2008
-   Trying to setup a simple security camera over web, using Swann PC DVR-4 and I do have a static IP. I still cannot connect to the camera. Someone plz help...-   darkcavallin
well depends on if you want to hookup wirelessly with one or not. If the modem has a USB connection as well as ethernet, then you can hook up 1 computer to usb and 1 to ethernet with no problems. If you do want a wireless hookup then yes, you need a wireless router. I would just go with a router because of the convenience of being able to go wireless if you decide to. I would suggest a Linksys WRT-54GL with a 3rd party firmware (DD,-WRT, Tomato, etc.) Hope this helps.
This solves and avoids the networking configuration dilema and problem of putting the Westell 6100 in bridge mode and all the anxiety that arises from that exercise and experiment in networking.
JJ,
Yea, isn't that annoying! Took me like 15 - 20 min to figure out you just leave it blank and click ok or apply whatever it is and you're golden. I'll post seperate here for a full set of bridging instructions.
Comments:
Oct 10, 2008
Step by step instructions for Bridging a Westell 6100F Model F90-6100... (Carrier Verizon)
1. Plug in straight to the modem. (If your doing more than one of these i suggest statically assigning your computer an IP such as 192.168.1.10 but this is not completely necessary.
2. Start -> Run -> http://192.168.1.1/verizon/redirect.htm
3. Sign in. Username: admin Password: Admin
4. Cuss ths sh&* outa your computer when it decides to randomly bluescreen and restart on you... ole lappy's seen better days...
5. Click the disable button at the bottom of this "Warning!! Restricted Page"
6. Click Cancel for the Detect WAV config status.
7. Click OK to reboot modem
8. Click the "My Network" Icon across the top.
9. You may get a User Settings Page asking to change password. don't change it, it won't do ne good... just click apply and ok.
10. Once on the Network tab click on the Network Connection link on the left under Main, and Network Status.
11. Click on the Broadband Connection (DSL) link.
12. Click Edit for the VC (currently set to PPPoE)
13. Select Bridge under the Protocol dropdown box and click apply. Click ok to reboot when prompted.
14. Once it reloads click back into the My Network page and Network connections again.
15. Click on LAN and uncheck the box for "Private LAN DHCP Server Enable."
16. Click apply
17. Viola you're done!
Note: if you ever need to access the modem again you'll need to set your computer manually to a 192.168.1.x ip 255.255.255.0 subnet and 192.168.1.1 gateway.
Oct 13, 2008
- hey folks, just noticed i had the password down as Admin... it's lowercase... admin
Oct 13, 2008
- actually... wrong again... password is just password
so I have a westell modem, but how do I make it bridge so i can use my linksys router to it... I tried connecting to westell odem and it just wolt let me in, everytime I access it the log in window apears asking for username and password....admin, password... I am directed to a Verizon window that is is asking me to change user name and password and it doesnt go anywhere else after that, it keeps asking me to change un/password...no matter what I do it does the same.
AT&T Westell modem keeps dropping internet and i have to unplug power cord and reconnect to...
(More)
AT&T Westell modem keeps dropping internet and i have to unplug power cord and reconnect to regain connection at least twice an hour
Experienced slight power outage last week. Ordered new modem, model E90-610014-06. All cords are...
(More)
Experienced slight power outage last week. Ordered new modem, model E90-610014-06. All cords are connected properly, modem lights working properly. Home page to IE http://www.yahoo.com/. When trying to open IE message appears . . . IE cannot display the web page. Checked internet options, everything appears to be okay there. Your assistance would be greatly appreciated.
I used a shiro ethernet modem And a aztech HL 109 RN wireless/wired router with Homeplug function....
(More)
I used a shiro ethernet modem And a aztech HL 109 RN wireless/wired router with Homeplug function. after surfing the net for a while i will not be able to connect up the net. I will have to shut down my modem for a couple of minute then on it again in order to regain connection. I have change a couple of modem already but same problem re-surface. Please advice.
i have a Westell VersaLink Model 327W and the light for the ethernet cable keeps blinking...
(More)
i have a Westell VersaLink Model 327W and the light for the ethernet cable keeps blinking && my computer doesn't connect to the internet. i tired putting the ethernet cable into the other jacks on the modem but it keeps blinking and still doesn't let me connect to the internet. i also tried using a different cable && i still have the same problem. someone helppppp!!! O_O.
If you connect 1 usb and the other ethernet, only one cpu at a time can access the internet. Is there another inexpensive way to have it so it can access at the same time?
