Question about Manfrotto 679B Monopod
Head mount The exposed mounting screw has 2 sizes in one. The head must screw up or down to expose the smaller size, but that's the size I need most. How can I get it back since the head seems too tight to move. Thanks Carl
  • edfrompa Dec 07, 2008
    I need a replacement center bolt with the hole through it, it is stripped, and I need a replacement. I have it apart, ready to put the new bolt in.
2 Suggested Answers
SOURCE:
jessee007
  • 310 Answers
SOURCE: Manfrotto 681 problem
can youy turn it up side down and use gravity to you advanage?r
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Posted on Jan 01, 2008
Can my tv be wall mounted and is there a special kind of wall mount
Check Walmart , all types / sizes of Wall mounts available
Mar 16, 2015 | Televison & Video
What is the Head Bolt Torque specs for a 25HP Kohler Pro CV7308?
Heads Secured With Screws
1. Check to make sure there are no nicks or burrs on
sealing surfaces of cylinder head or crankcase.
2. Install a new cylinder head gasket (with printing up).
3. Install cylinder head and start four new hex flange
screws.
4. Torque screws in two increments; first to 22.6 N·m
(200 in. lb.), then finally to 41.8 N·m (370 in. lb.).
Heads Secured With Mounting Studs, Nuts, and
Washers
2. If all studs were left intact, go to Step 6. If any studs
were disturbed or removed, install new studs as
described in Step 3. Do not use/reinstall any
loosened or removed studs.
3. Install new mounting stud(s) into crankcase.
a. Thread and lock 2 mounting nuts together on
smaller diameter threads.
b. Thread opposite end of stud, with preapplied
locking compound, into crankcase, until specified
height from crankcase surface is achieved. When
threading in studs, use a steady tightening motion
without interruption until proper height is
obtained. Otherwise frictional heat from engaging
threads may cause locking compound to set up
prematurely.
Studs closest to lifters must have an exposed
height of 75 mm (2 15/16 in.).
Studs furthest from lifters must have an exposed
height of 68 mm (2 3/4 in.).
c. Remove nuts and repeat procedure as required.
4. Check that dowel pins are in place and install a new
cylinder head gasket (printing up).
5. Install cylinder head. Match numbers on cylinder
heads and crankcase. Make sure head is flat on
gasket and dowel pins.
6. Lightly lubricate exposed (upper) threads of studs
with engine oil. Install a flat washer and nut onto
each mounting stud. Torque hex nuts in two stages;
first to 16.9 N·m (150 in. lb.), then finally to 33.9 N·m
(300 in. lb.).
Aug 19, 2014 | Craftsman Garden
How do you mount the door handle on the summit swc530lbist?
Open the door on it. Gently pinch the seal and pull on it while giggling it and it will eventually come out to expose the Chanel with two holes that expose the screw heads. Simply tighten on the handle from the backside and push the seal back in place and your done.
Apr 15, 2012 | Summit Commercial Summit Professional Wine...
Trying to remove a ceiling fan Hampton Bay model C 542 MP (CH) PBL . its flush mounted and cant get to mounting bracket.
Look for 2 to 3 screws at the top edge of the fan's ceiling cowl. Remove those and the ceiling cowl can be sled down, which will expose the the ceiling mounting bracket . They are fairly small head screws, so look carefully for them.
Hope this helped you and thanks for choosing FixYa.
Aug 14, 2011 | Heating & Cooling
I have 32 in Vizio and am using a full motion wall mount. It is attached to the smaller inner mount. I would like to attach it to the larger outer mount but dont know the screw size. It is larger than...
To know the exact size of the screw, you have to get the circumference of the hole where you will insert the screw. If possible to bring with you the outer mounting in buying the screw to have a perfect fitting.
Nov 30, 2010 | Vizio L32 32 in. LCD HDTV
How do i change the brake light on jeep liberty 2006?
1) You will need to open the rear swing door.
2) On the inside jam there are two torx headed screws (T-15's if I remember correctly).
3) Unscrew the two torx screws.
4) The light is now held by two mounting tabs (small spherical headed plastic sets that go through a rubber grommet).
5) You will need to pry the light casing off (easy pressure with a good size flat head screw driver will do the trick).
6) The light bulbs are twist mount settings inside the light casing.
7) Twist out the mount setting, change the bulbs, and reset the light mountings.
8) To put the light casing push the light casing back on and put in the screws. Everything else will work in reverse when it comes to assembling the whole unit.
2006 Jeep Liberty Replacement Light Bulb Sizes
Low Beam Headlamp Bulb Size: 9007
High Beam Headlamp Bulb Size: 9007
Parking Light Bulb Size: 2825 or 3157
Front Turn Signal Light Bulb Size: 3157
Rear Turn Signal Light Bulb Size: 3757ALL
Tail Light Bulb Size: 3157
Stop Light Bulb Size: 3157
High Mount Stop Light Bulb Size: 921
Fog/Driving Light Bulb Size: 9145 or H3-55W
License Plate Light Bulb Size: 168
Back Up Light Bulb Size: 3157
Front Side Marker Light Bulb Size: 168
Ash Tray Light Bulb Size: 161
Map Light Bulb Size: 578
Dome Light Bulb Size: 578
Step/Courtesy Light Bulb Size: 906
Trunk/Cargo Area Light Bulb Size: 578
Thank you for using fixya, and good luck
May 08, 2010 | 2006 Jeep Liberty
How do I remove the stand to mount the TV on the
the TV will mount to the wall via the VESA screw mounts on the back of the LCD. If it is a smaller, monitor sized LCD then the screw pattern will be either 75x75mm or 100x100mm. On larger TVs is it usually 100x200mm. Sometimes the base is screwed into this mount and othertimes to the bottom. Simply unscrew it from the screen. Be sure that the wall mounting kit can handle your LCDs VESA screw pattern, screen size and screen weight.
Feb 07, 2010 | Televison & Video
Mounting bracket
added a spacer made from a truck inner tube. the screw from the tripod still has 2 full threads threading into the bracket on the telescope.
Sep 23, 2008 | Optics
Battery replace
Flip the unit over so it is resting on th screen with the on switch at the top you will see the reset and S/N tag. Pull this plastic tag off with twezzers or a knife. This will expose 2 torx screws size T-5. After removing the torx screws, right under the S/N plate sticker is a mount hole, locate this then pry apart with screw driver, be careful prying apart as there is a flex cable taped down to your pcb board. Remove the flex cable by opening the latch for it, there are 2 latches one small and one large and the cables are taped to the pcb board. Remove the speaker jack wire with tweezers.Next with a small jewlers screwdriver remove 3 phillips screws size ph00 from pcb board. Lift the pcb board out and disconnect the battery wire underneath. Next remove battery, it is stuck down with double sided tape and takes quite a bit of force to remove. It is a Garmin LI-ion 3.7v, 1.25 AH battery.
Aug 28, 2008 | Garmin nuvi 200W GPS Receiver
Dec 02, 2007 | Manfrotto 681 Monopod
Manfrotto 679B Monopod Logo
54 people viewed this question
Top Manfrotto Photography Experts
Tom Chichester
Harrie
Are you a Manfrotto Photography Expert? Answer questions, earn points and help others
