Tv wont power up
I have an RCA P46734BA projection tv. My problem is this. When I push the power button the tv wants to turn on but it comes on then goes off right away. I took the back off and all I see is alot of wires and plenty of dust to go along with it. I have checked most of the capacitors and none are blown or swelled. The resistors look good also. What should I look for?
  • hrlydvdn Apr 15, 2009
    Thank you for responding. When I power up the tv, the power button light comes but then shuts off. It does that 3 times then nothing.
  • 11,896 Answers
It is most likely the capacitors in the power supply
Posted on Apr 15, 2009
  • Nate Stansfield
    Nate Stansfield Apr 15, 2009
    Possibly the projection bulb but you would probably get a flashing warning light on front of tv. The ballast also tends to go in these tv but is hard to test without ohm meter and schematic.
  • Nate Stansfield
    Than your power supply needs to be replaced unless you can replace the capacitors inside the power supply
My tv wont turn on when u push the power button no pic or volume comes on and the power button just blinks
Different possibilities:
1. Bad hv circuit (flyback)
2. Bad connections on flyback & the little fuse next to it
3. Bad fuse near tuner
4. Bad picture tube
This tv is known to have any of these problems.
Apr 28, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca big screen model # P52939
I had same problem on rca big screen M #p46734ba it was hi voltage splitter the part # for mine is 40431-090 GE/RCA splitter it was $36. online
Mar 12, 2009 | RCA Televison & Video
Power button malfunction
Sounds like a faulty power supply. Consult warranty guide if its still under warranty, if not, you really need to consider calling a repair technician
Feb 28, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv will not turn on
I turn on tv green light comes on and gos off and no picture.
Feb 04, 2009 | RCA D52W19 52" Rear Projection Television
Won't turn on
I have the same problem; I push the power button green light comes on tv clicks but doesn't come on.
Aug 19, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv wont power up
if you can not turn on TV set with the power button on the TV its not astandby problem as this would by pass the standby. Theres most protec,on a set of this age, top have a poiwer regulator,vertical,horzontal/chcroma problem and is goingto need a trained tech to assist you in this repair. www.afiata.com
Aug 01, 2008 | RCA D61W20 61" Rear Projection Television
Wont turn on
Check the solder connections on the flyback and also right next to the flyback there is a small white coil with copper wrapped around it that will sometimes arch causing the solder to need re-soldering
May 06, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca p52937sg
Try unpluging it for 15 min.and try it ,if it don't work it might have a leak in your button,it is a simple and cheap repair.I suggest to call your local repair shop.
Dec 23, 2007 | RCA P52937 52" Rear Projection Television
Televison & Video Logo
190 people viewed this question
Top Televison & Video Experts
Electro Med Services...
