Question about Panasonic KX-TGA450B Cordless Expansion Handset
Handset won't stay on. Keeps blinking on and off and beeping while in the charge cradle. Bought a new battery - still does the same thing. Can it be reset or fixed in some way?
I sent the handsets in to Panasonic for repair or replacement.
Posted on Apr 15, 2009
Can't seem to deregister the used HS I bought on Ebay since I don't have it's base.
1. To de-register the orphaned handsets from their old base:
When the orphaned handset says "Connecting..." or "Out of..."
enter *331734 [menu]
and it will soon beep and display "Not registered"
2. To register the new handset to your base:
press the "Handset Locator" button on the base and hold
it until the "in use" light comes on ( ~ 4 seconds ),
then release the button and set the new handset into
the base phone cradle. After ~ 30 seconds it will beep
and display "Handset #" (next in sequence).
3: Note: the base handles a maximum of 12 handsets.
If your system was fully populated ( ie, a handset is
already # 12 ) you will have to clear all the handsets
from the base and re-register them all in sequence.
( it is the only way to 'rescue' the places occupied
by the lost handsets ).
To clear the base of all registrations:
1. Press and hold the the "Handset Locator" button
until the "in use" light lights and then starts to blink
( ~ 10 seconds ), release the button --
then press it again briefly while the "in use" light
is still blinking.
2. The base will beep and all handsets that were registered
will display "Not Registered"
3. Follow the instructions above for each handset
in turn to re-register them:
press "Handset Locator" ~ 4sec ( in-use light on ),
set handset into the base cradle, etc.
The manual is available from: www.manualslib.com
but does not fully describe these procedures.
Good luck !
Nov 27, 2015 | AT&T DECT 6.0 Expansion Accessory Handset...
At&T EL52300--one phone reads 'out of range-move closer to base.' I did--it doesn't help. Battery OK---What do I do?
It appears that the one handset has become orphaned and
must be de-registered and then re-registered.
1. To de-register the orphaned handset from the old base:
is still blinking.
Good luck !
Oct 17, 2014 | AT&T El52300 Cordless Phone
Deregister procedure for at&t el52400 handsets
is still blinking.
Good luck !
Mar 21, 2013 | AT&T Lands Phones
Base el5200 will not reconize new hand set
To deregister the new handsets from their old bases and re-register
them to your base, try this for each new handset...
1. When the new handset says "Connecting..." and goes nowhere
else, enter *331734 [menu] and it will soon beep and display
"Not registered"
2. To register the new handset to your base: on the base press
the "Handset Locator" button and hold it until the "in use" light
comes on ( ~ 4 seconds ), then release the button and set the
new handset into the base phone cradle. After ~ 30 seconds
it will beep and display its "Handset #" (next in sequence).
3: Note: the base has a limit to how many handsets it can handle,
I believe it is five handsets maximum for the EL52300.
If your system was fully populated ( ie, a handset is already # 5 )
you will have to clear all the handsets from the base and
re-register them in sequence ( it is the only way to 'rescue' the
places occupied by the lost handsets ).
1. Press and hold the the "Handset Locator" button until the
"in use" light lights and then starts to blink ( ~ 10 seconds ),
release the button -- then press it again briefly while the "in use"
light is still blinking.
2. The base will beep and all handsets will display
"Not Registered"
3. Follow the instructions above for each handset in turn: press
"Handset Locator" ~ 4sec ( in-use light on ), set handset into
but does not describe these procedures.
Good luck !
Mar 01, 2013 | AT&T ATT EL52500 DECT 6.0 5-Handset...
New out of the box wont power on
Hi.. Let me try to help you if I can... I'd like you to check a few things,
1) Open battery cover on handset & make sure that the battery pack is installed correctly, and not upside down. Also make sure the little wires that come from battery pack are plugged into the tiny jacks of the phone (usualy red & black wires) in handset is fully attached & pushed snuggly into the handset... and if No wires, check to ensure the part that does connect the battery to handset is not covered with a plastic film of tape or paper as right from a manufacturer they sometimes do that to preserve length of battery until product is sold to you..
2) Check the bottom of the handset phone, that sit in the cradle of the electric part of the recharger, and make sure there is nothing like plastic or paper covering the connections between the bottom of the handset and the charger. Make sure there is a full on connection for a full charge to the handset. As with some cordelss phones Ive had the red LED light will not come on if there is something blocking a full connection for a charge.. The red LED light on base, only comes on when the electricity is flowing into the handset. The slightest tilt not allowing handset a full charge, wont give it a FULL charge.
3) You say " NEW. Out Of The Box" I hope when you connected the battery pack into the handset, and made sure it was connected right, you then allowed handset to charge at least a FULL 12 -24 hours before trying to use your new cordless phone. as the batteries right out of the box, are rarely already fully charged when any cordless phone is bought and then it does need 12 - 24 hours for a FIRST FULL CHARGE...
If you can check all 3 of these questions, and let me know how things are back on this posting, if you stilll can not solve the problem after a full charge to battery, I may have some other ideas that can help.
Good Luck
Stevie
Feb 14, 2010 | Uniden Cordless Phone
Hi My phone battery died and I recharged it. Now it is not recognizing the base and keeps searching.
Press and hold the end key, then while holding the end key, press and hold the # key. After 3 or 4 seconds the handset will beep and ask if you want to deregister the handset, select "Base unavailible" and confirm. Then the handset should read "Handset not registered". Place it on the base charging cradle and it should register.
Jul 08, 2009 | Uniden DECT 6.0 Cordless Telephone...
VTECH VT9121
voice message light keeps blinking
Aug 25, 2008 | Vtech 9009111 Cordless Phone
Handset has No link to base
I was having the same problem with the same model phone, and fixed the problem by rebooting the phone – unplugging the AC and phone cord from the base station and plugging both back it, then removing and replacing the handset to regenerate the security code.
Nov 17, 2007 | Xact Communication XG2200 Cordless Phone
Handset No Link To Base error and no dial tone
I have the problem. I think it is because the battery i have in it was a Ni-MH and it should be a Ni-Cd. I am now looking for the right baterry Good luck Frank wolfgang24@verizon.net
Jan 27, 2007 | GE 900 MHz Phone
Handset ?No Link To Base? error and no dial tone
2/29 Have you registered or re-registered the handset?
"No link" can mean handset is not accepting radio wave of base unit. At Mfgr website pull-down operator's manual and look for registration instructions. Some sequence of buttons will create a radio signal from base (have handset off base) then another sequence of buttons on handset will accept radio signal. If handset has "menu" button, try "menu", then "00" (zero zero) then select an accept or "OK" button. Good luck.
Jan 14, 2007 | Xact Communication XG2200 Cordless Phone
Panasonic KX-TGA450B Cordless Expansion Handset Logo
720 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
