Kyocera KM4035 Service Message C6050
I have received the following message on our Kyocera KM4035 machine: "System Error Call Service (picture of a telephone with *********) C6050". Can you tell me what is wrong with the machine? All the lights (copier, printer,scanner)are on. When you turn the machine off and then back on, the finisher portion makes a strange noise. Please help if you can!
  • Anonymous Nov 18, 2008
    i dont even know where the thermostart is. please help me. i use KM 2035
    Sniper:
  • 57 Answers
The above is incorrect, Kyocera made a mistake by having a thermistor that physically touches the upper heat roller/belt.. it has worn the roller to a point where it throws up the error.. you will have to install a new fixing unit.
I have done over 25 warranty replacements regarding the 4050/5050/2525 etc.
Posted on Oct 16, 2009
    New Friend:
Kyocira-4035 copier shows system error c6050 the copier is not working
Posted on Jan 11, 2013
  • justhappy_2
    justhappy_2 Jan 11, 2013
    kyocira-4035 copier shows system error c6050 the copier is not working
Clean the filters below the by pass unit and remove the fixing unit and opened hit the thermostat until i make rattling sound
Posted on Sep 14, 2007
What do I do with the error code of C6050 on a Kyocera KM-3035 machine
You need to go into simulation mode and enter U163.
This simulation number needs to be reset.
Nov 09, 2017 | Kyocera Office Equipment & Supplies
How to fix system error c6050 on my km-3035
It is a fixing assembly error code. The thermistor doesn't detect heat. Kyocera you replace the fixing assembly. You may be able to reset.1087 1087 gets u into served mode go to reset and activate.power off and on.
Feb 02, 2015 | Kyocera Mita Km 3035, 4035, 5035 Fs9120dn,...
Kyocera C6050 error
C6050 Error
Abnormally low fusing unit thermistor temperature
SIM 163 Reset (only do this one SIM, by doing others you could cause your machine to no longer function. Also see note at bottom.
Entering Simulation Mode
1. Press the system menu/counter key.
2. Select Service setting using the up/down cursor keys.
3. While pressing the start key and the # key, press the enter key. (Maintenance mode is entered.)
4. Select Maintenance mode using the up/down cursor keys.
5. Press the enter key.Enter the maintenance item (163 Resetting fuser problem) number using the up/down keys.
6. Go to step 1 under method below.
Resetting the fusing problem data Description
Resets the detection of a service call code indicating a problem in the fusing section.
When a service call concerning the fusing section occurs, turn the power switch off and open the front cover.
Then, turn the power switch on and press the system menu/counter key to enter the maintenance mode.
Purpose
To prevent accidents due to an abnormally high fusing temperature.
Method
1. Press the enter key. A selection item appears.
2. Select Execute using the up/down cursor keys.
3. Press the enter key. The fusing problem data is initialized. (Four service calls, namely C6000, C6020,C6050, and C6400 are reset.)
Completion
Press the back key. The indication for selecting a maintenance item No. appears.
Note:Sometimes in order to do the reset when the machine is in an error state you need to open the top cover (like to replace the toner) and leave it open until you have performed the reset
Jul 03, 2014 | Kyocera Office Equipment & Supplies
Forgot unlock code voicemail kyocera jax
Go to this link...
http://www.virginmobileusa.com/resources/phones/prepaid/manual/kyocera-aw-jax.pdf
DOWNLOAD THE MANUAL FOR FUTURE REFERENCE!! LOL
Scroll down to page #39 to where it says Use Voicemail and follow the instructions!! As per the service tech I spoke to on the phone to find this link, following these instructions will automatically erase your old voicemail unlock code as well as any as yet unheard messages.
Just in case anyone still has difficulty in finding the instructions.....
Set Up your VoicemailBefore your phone can receive voicemail messages, you must set up a 4-10 digit passcode and record a personal voicemail greeting.When you have set up your voicemail, all unanswered calls to your phone are automatically transferred to voicemail, even if your phone is in use or turned off.1. Press and hold the 1 key.2. Follow the system prompts to create a password and record a greeting.
Check your Voicemail
When you receive a voicemail message, a
notification with a voicemail message icon
appears at the top of your screen.
• At the voicemail notification, select Call to call
your voicemail number and follow the system
prompts to retrieve the message.
Select Ignore to clear the notification without
checking messages. The notification icon
remains on top of the screen until you listen to
the message
• When only the voicemail message icon
appears on top of the screen, select
Voicemailand follow the system prompts
Best of luck!!
Susan
Jan 27, 2012 | Kyocera Jax Cell Phone
MY COPIER (KYOCERA 1635) DISPLAS ERROR C6050. HOW
C6050 Abnormally low fuser unit thermistor temperature The fuser temperature remains below 90°C/194°F for 1 s. Poor contact in the thermistor connector terminals. Reinsert the connector. Also check for continuity within the connector cable. If none, remedy or replace the cable. Broken fuser thermistor wire. Measure the resistance. If it is ∞ ω, replace the fuser thermistor. Fuser thermistor installed incorrectly. Check and reinstall if necessary. Fuser thermostat triggered. Check for continuity. If none, replace the fuser thermostat. Fuser heater M or S installed incorrectly. Check and reinstall if necessary. Broken fuser heater M or S wire. Check for continuity. If none, replace the fuser heater M or S. Code Contents Remarks Causes Check procedures/corrective measures
Apr 09, 2010 | Copystar CS-1620 Copier
I have a kyocera cs-1650 with the error message FAX MODE ERROR. can you help?
It is problem Program not properly configure.set up fax program,Fax line type,Receiving mode,number of ring count.Other help follow your copier User Guide manual.If you do not fix your problem then you call a service technician. who support this machine.
Dec 02, 2009 | Kyocera Copystar CS-1820 Black and White...
Error Code C6050
First you must get into the service mode by keying in 10871087
The screen will start blinking - then key 163 and the screen should read cancel or execute -select execute
when it is complete turn unit off then back on and see if that worked, if not buy a new fuser unit. They cost around $150,00 to $200.00 depending on who you buy it from.
May 25, 2009 | Kyocera Mita KM-2050 Printer
C6000 Error message on Kyocera Mita KM-C3232 Printer
the c6000 error may be resettable.
the password will be 3200 or 6482.
once inside you need to be in copy mode and do the following
punch into the keybord 1087 1087
once you see 000 on the screen punch in 163 and hit the green button
you will then see the reset sequence, follow this and it should work.
please report if this works
Mar 20, 2009 | Kyocera Mita Office Equipment & Supplies
Sytem error C6050
This Code means low fixing unit temperature. If the power goes off and on, or Suzy Sec. has a space heater on the same circuit, this could be a false code.
Enter the service mode by keying in the numbers "10871087", on the key pad. enter the number 906, press start, press "execute"on the touch panel. The machine will reboot.
If the code comes back, you either have a bad thermistor, thermostat, or heater lamp. I have only had to replace the thermistor. The Fuser comes in the maint. kit ,so I always have some old ones laying around.
Jan 14, 2008 | Kyocera Mita KM-3035 All-In-One Laser...
2,266 people viewed this question
k24674
jasbo
jasbo
