Question about NetGear RangeMax WPN824 Router
WILL THIS NETGEAR ROUTER WORK WITH MY DELL LAPTOP?
IVE BEEN TRYING TO CONNECT MY DELL INSPIRON TO MY FIRST ROUTER AND GO WIRELESS.HOW DO I PAR TO MY LAPTOP? ...................THANKS IN ADVANCE!
  • 854 Answers
We'll start from the beginning;
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
Posted on Apr 15, 2009
Dell inspiron m5030 netgear router
Limited connectivity
If you get a 'Limited connectivity" on you wireless connection on your laptop, it means that the wireless card on your laptop probably did not get an IP address from the wireless router.
To fix this problem, right click on the wireless icon on the Task bar and then click Repair.
This will force the wireless router to issue a IP address to the wireless card on the laptop.
Jan 23, 2013 | Dell Inspiron Computers & Internet
Is my Dell Inspiron 580 desktop capable of wireless internet?
to no if you have wireless connection go control panel on your computer then find network and internet look for wireless connection click on it
Sep 22, 2012 | Dell Inspiron 1525 Laptop
I just bought a netgear wnr2000 router....cannot connect to a dell netbook (inspiron mimi) with a dell wireless 1397 WLAN mini card. I set the router up for WEP and it works great with all of my other...
Check the settings of the router.
For this you will need to open the router set up.
Make sure that the Wireless MAC filter is disabled on the router.
Click Here to know how to open the router set up.
Nov 26, 2009 | Computers & Internet
My daughter has an old Dell Inspiron and it works great with a Belkon router but when they got the netgear wireless router she gets a blue screen. What do I do?
Need to check for driver compatibility for the Netgear router . Contact Netgear for backwards compatibility or purchase a router that will be compatible with your PC.
Aug 04, 2009 | Dell Inspiron 1000 Notebook
Wireless connection
Did you change your wireless SSID and channel? Better to enable encryption too. If this problem never happens when you're connecting to other wireless networks you might as well update or reload the firmware/software of your router.
May 22, 2008 | NetGear DG834G 802.11G Wireless ADSL...
Server not found} NetGear WGR614 Wireless Router doesn't connect me to the internet.
Dear Loud Nouises,
Your router must be connected properly to the cable modem. This must be to the wan port on the router.
Next, the router must be set-up accordingly to recognize the modem's internet connections. Please ask for the IP address.. and other relevant informations from your internet provider.
Set -up your computer using the internet connections wizard on each of your respective computer.
This should work fine if all connections were correctly configured.
Sidlahora
Nov 27, 2007 | NetGear WGR614 Wireless Router
Wireless connection problem
Your buggered lol got same problem :( Ive looked into it got latest drivers and its netgears fault. Apprently you require their adapter for laptops etc exepct laptops connect because i dunno, but pda devices wont? Yeah i dunno its odd :S Im temp switching from wpa to wep for my pda that works :D
Sep 21, 2007 | Dell Axim X50 Pocket PC
NetGear RangeMax WPN824 Router Logo
66 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
