No audio I have an olevia 232 and no matter what combo i use for my video/audio input I get no sound, just picture. How can I fix this or where can I find the correct user manual so I have a diagram to follow?
    Novelist:
  • 159 Answers
Do this option: (second chance)
go to menu
find audio
  • double check the spearkers option if is ON (if the option is available in that tv. "some tv's have it some other doesnt have it")
Posted on Apr 15, 2009
I have an Olevia 32 inch, LCD HD model 232-S13, with a great picture and no sound. Any suggestions?
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Jan 16, 2016 | Olevia Televison & Video
Hooking up my ps3 using HDMI cord to my olevia 232-S13 and it says invalid format
Setting up your HDMI cable on your PS3 games console
1: Turn on your TV and set its input to HDMI.
2: Make sure your PS3 is connected via a HDMI cable.
3: Power on your PS3 and press and hold the power button for approx. 5 seconds, you will hear the PS3 start to beep, release the power button after the second beep.
4: Your PS3 should automatically configure itself for HDMI video and Audio output.
Jun 28, 2015 | Olevia Televison & Video
I have a olevia model 232-s12 tv has sound but no pics I checked power supply all checked ok I turn tv on sometimes picture would work image may be very cracky so I assumed it was a tcon board replaced...
Good day.
If you already replaced a new inverter board and T-con board and the problem is still there.Try to play the video on the DVD,if the video is OK check the cable connection and try to run auto scan.
If the problem is still there check the input supply of the system board or main board it should have 5vdc and 12vdc,if it is OK replace the system board.
Review this manual page 4-1 abnormal display http://www.scribd.com/doc/36875894/Olevia-232-S12-SM
I hope this solution will be helpful.Thank you for using FixYa.
Apr 17, 2011 | Televison & Video
Want to connect my thinkpad to the Olevia 532-B12 CD TV. Cables I have found show 15pin conenctors for the video and signle RCA plugs for audio. The back of the TV indicates it needs an audio splitter...
what connections to you have on your computer? because it is best to match connections with tv to computer. s video? hdmi? they sell av or color stream cables with a splitter to connect to computer color stream is just for picture av (RCA input) is for both video and sound.
Jan 31, 2011 | Olevia Televison & Video
Sound but no picture
Either your voltage is low or your panel is bad. You have to call a service shop in order to have them dissect the problem
Apr 07, 2010 | Olevia LT37HVS 37 in. LCD HDTV
g
OK,you need 3 leads,(A/V leads),normally red white and yellow.
So yellow is for Picture (video).go from video OUT (combo) to TV video IN.
Then red and white .... Audio OUT of combo into Audio IN on TV
TV must then be set to AV1 or AV2 depending on which AV inputs you used..
Rod
May 04, 2009 | Televison & Video
Setup
I went to 'S' video for that function and use the external audio inputs for L/R. This path is slightly superior for video but carries no audio signal.
Check to see if they both have it.
The yellow cable is normally a 'composite' video cable which carries video and sync info.
The red and white are pretty standard for audio with red=right and white=left.
May 25, 2008 | Olevia LT32HVM 32 in. LCD Television
Olevia 32" LCD HD TV model 232-S13
I have had the same problem with my daughters Olevia...232-S13 out of the blue ti just decides to not turn on...blue light lit where the on/off button located but no sound and no picture....i guess the saying "you get what you pay for" stands clear here.......very upsetting.....
Jan 12, 2008 | Olevia LT32HVE 32 in. LCD Television
Brand new TV and it has a beautiful picture but no sound any suggestions?
S-video does NOT carry audio.
You'll have to get some RCA audio cable and connect them to the audio in ports associated with the S-Video input.
Nov 21, 2007 | Olevia LT32HVM 32 in. LCD Television
DVD VHS recorder
It sounds like your cables are connceted ok, but what you neede to do is to be able the switch from one video mode to the other so lets go through the cable and vrc conncetions again just to make sure. From your cable set top box connect your component video (RGB) video out to your TV (RGB) video in via the (RGB)cables. From your VCR connect your composite video (yellow) out to your TV composite video in withe the composite video (yellow) cable. From your VCR (Left & Right audio out)connect your left and right audio connections (White and Red) to the Audio in of the TV (Left and Right). Whith this setup you should be able to use the TV to switch between the two A/V inputs using the remote control.
Sep 03, 2007 | Philips Magnavox 27MS343S 27" TV
Televison & Video Logo
89 people viewed this question
Top Televison & Video Experts
Electro Med Services...
