Question about Gateway FPD2275W LCD Monitor
I recently bought an ASUS external monitor to use in parallel with my Gateway laptop. The external monitor will stop working (go blank, but remain on) after about 30 seconds when I plug it into my laptop's VGA port. The external monitor seems to work fine on other computers. Therefore, I am convinced that my VGA port is malfunctioning. What advice can you offer me?
    Sergeant:
  • 279 Answers
Is it a BRAND NEW monitor? The only way to be SURE your VGA port is bad really, is to see if it does the same thing with a completely different monitor. What I'm getting at is it could be the monitor itself. Maybe the monitor has some kind of "sleep" mode set? (There is such a thing as brand new AND defective. It's not common, but it does happen.) See if you can get the manual for the monitor, and read up on the different applications this one has. Most monitors have multiple ways to hook up. On the other hand, if your VGA port IS defective, it's probably safer to send out for repairs than replace the port yourself, unless you happen to be an accomplished solderer/electrician.
Hope this helps.
Posted on Mar 09, 2010
Black screen
Test it with an external monitor. If it does not work with an external monitor, then your motherboard is defective. If your laptop works good with an external monitor, then your screen need to be replaced.
Mar 05, 2014 | Gateway NV53A24u Laptop
Blank screen on laptop
Please test it:
1. Remove the hard drive and turn on the laptop. If the laptop display BIOS, then replace the hard drive with a good working hard drive,
If it the laptop screen does not display anything, then:
2. Test it using an external monitor.
- If the external monitor blank too, then there is something wrong with your laptop's GPU and or motherboard (you need to replace the motherboard)
Mar 05, 2014 | Gateway NV59C09U NV52 NV53 ......
I have a Gateway laptop whose screen just broken and is cracked. However, I also do have an external Gateway monitor, model NO: FPD1730. I hooked up the external monitor to the laptop and it only works in...
Excuse me if I'm talking below you level of expertise...
With an external monitor on a laptop you usually have to activate the plug where you've connected the external monitor cable . This requires pressing 2 keys in combination, usually a FUNCTION button + a specific function key. Yeah, they're named almost the same thing, but I'll try to keep it straight.
On your keyboard's function keys (above the numeric keys typically) should be small pictures besides the standard F1, F2, etc. which are usually in white. You're looking for the picture that resembles a monitor. On my Thinkpad the small pictures are colored blue, and the monitor is on the F7 key. It so happens that my FUNCTION button (different than the function keys we were just talking about) which is located in the lower left of my keyboard is also blue. Yours might be in a different position, but I'm giving you an idea when to look.
When you find the Function Button, press and hold this key and the correct Function key (F1, F2, whatever). You might need to press this 1 or 2 times to get the correct monitor setting. I'm not exactly sure of the order but you'll activate the external monitor, then another combination press will activate both displays, then a 3rd will do another setting, then back to the beginning. If you miss it the first time just slowly press the combination until you get what you're looking for. Be patient, and press once every 5 seconds or so, giving the computer enough time to change its settings.
Hope this helps!
Jul 27, 2010 | Gateway FPD 1730 17" Flat Panel LCD...
My laptop monitor goes out after windows loads.
Sounds like the backlight is broken If it works with an external monitor the backlight needs to be replaced will cost you about 100$ sorry
Nov 13, 2009 | Computers & Internet
Gateway model # CX 2618
First test if it works on an external monitor. If it does you will need to clear the CMOS. To clear it:
remove the battery, unplug the cord, and hold the ON button down for 30-60 seconds. Then turn it on. Thats how you clear it on most laptops.
If it does not work on the external monitor, you probally have a bad video card and need to replace the old one
May 26, 2009 | Gateway CX2618 Notebook
Screen remain black after switchin on the laptop
When you boot it up try to connect to external monitor, if you see something on that then it might be the backlight or inverter.
Jan 07, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
I flashed the bios on my gateway m675 and it stopped working. It turns on but screen is blank. If I hook it up to an external monitor I can get into bios. Is there anyway to get it back to the way it was?...
pls check the bios set up externally if you mistakenly turn the brightness down, and correct it
or see if ther is any brightness button you accidentally pushed on the top of your laptop
or ther could be some problem with your LCD inverter or the LCD itself.
Aug 08, 2008 | Gateway M675 Notebook
Dual Monitor Support for Gateway Laptop
Search on google for does gateway software support dual monitoring.
Jul 03, 2008 | Gateway 7330GZ Notebook
Asus Laptop Not Tunring On
Try using an external monitor to see if it's the laptop screen, if it works your screen or backlight is dead.
May 09, 2008 | ASUS Z71A Notebook
Gateway FPD2275W LCD Monitor Logo
171 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
