Question about Fuji FinePix F700 Digital Camera
Screwdriver tools where do you get one of those three edge screwdrivers.
For Digital Camera's you need a #0 Tri-wing screwdriver. Try Micro-Tools.com
Posted on Apr 03, 2008
  • 752 Answers
Its a Tri-Wing bit. Just google "security bit" and you'll find hundreds of vendors.
Posted on Sep 14, 2007
How to disassemble?
Apr 02, 2015 | Dryers
How to remove the drivers door panel on a 1991 honda accord lx
Instructions
    • Insert the narrow edge of the flat head screwdriver behind the edge of the plastic screw covers located on the door pull as well as the rear of the door panel. Remove the Phillips screws located behind the covers with the Phillips screwdriver.
    • 2Insert your flat head screwdriver behind the plastic screw cover located behind the door release. Remove the Phillips screw from behind the cover with the Phillips screwdriver, then slide the door release handle forward and remove it.
    • 3Insert the panel tool behind the front of the door's upper edge to pry out the triangular piece of plastic located there.
    • 4Pry around the edges of the door panel with the panel tool until the panel is loose.
    • 5Lift upwards on the door panel to slide it off the door. Unplug any electrical connectors that are plugged into the back.
Oct 01, 2012 | Cars & Trucks
How to replace a bulb
Hello
To replace bulb in RCA rear projection TVs follow this.
Turn the lamp assembly so that the front of the bulb faces downward
Locate two clips approximately three inches apart along the back edge of the rear lamp cover. Depress the clips with your thumbs and pull upward on the rear lamp cover to disengage it. Move the rear lamp cover so that you can see the head of the bulb. Note that the rear lamp cover still connects to the base of the bulb by a cable.
Locate the three hex screws around the head of the bulb that, in a triangle formation, secure the bulb to the assembly. Remove the screws with a hex screwdriver.
Pull the bulb and rear lamp cover upward to remove them.
Remove the nut that connects the cable from the rear lamp cover to the base of the bulb with a wrench. Disconnect the cable from the old bulb and discard the old bulb.
Reattach the cable from the rear lamp cover to the base of a new bulb and install the nut. Tighten the nut with a wrench
Install the bulb face down into the lamp assembly. Install the three hex screws into the tabs along the edge of the bulb and tighten with a hex screwdriver.
Reinstall the rear lamp cover onto the lamp assembly and line up the tabs with the holes along the side of the assembly. Press downward until the cover snaps into place.
Reinstall the lamp assembly into the back of the television, facing the bulb towards the center of the TV set. Tighten the screws securing the assembly and reinstall the lamp access door. Tighten the screw on the lamp access door.
Mar 22, 2011 | RCA D61W20 61" Rear Projection Television
How do I re-install the idler pulley belt on the drum?
Instructions
Things You'll Need:
* Duct tape
* Putty knife
* Phillips-head screwdriver
1 Unplug the LG dryer power cord from the dryer outlet. Pull the dryer out two feet from the back wall so that there is room to raise the top panel.
2. Place duct tape over the edges of a putty knife blade. This protects the finish of your dryer while using the putty knife. Insert the putty knife blade in between the front and top panels, three inches from the right corner. Feel for the spring clip with the blade, and lift up on the right corner as you slide the blade over the spring clip. Repeat the process three inches from the left corner. Lift the front of the top panel straight back toward the rear wall.
3. Open the dryer door and remove the two screws on the lower lip of the dryer door opening with a Phillips-head screwdriver.
4. Remove the two screws on the top edge of the dryer front panel with the Phillips-head screwdriver. Pull the front panel away from the dryer enough that you can access the door switch wiring harness on the left side of the cabinet by the door.
5. Grasp the white wiring harness connecting to the door switch on the inside of the front panel with your fingers. Squeeze the locking tabs together and pull the harness away from the door switch. Pull the front panel off the dryer.
Feb 22, 2011 | Maytag PYE2300AY Electric Dryer
How can I remove the whole radio assembly on my BMW K1100LT?
If you want to remove it permanently, you need to use three small flat blade screwdrivers inserted into the three small semicircles around the edge of the radio mounting plate to release the clips. Once released, lift the entire radio and mounting plate out of the box. Now you can disconnect all the power leads etc and pull the speaker leads through or you can merely tape them out if the way under the fairing.
Feb 21, 2011 | 1997 BMW K 1100 LT
Bulb replacment headlights
headlights image by Gudellaphoto from Fotolia.com
When GM introduced its Saturn Aura in late 2006, the design changes were not quite solidified. The 2007 model requires more than a simple twist and pull to remove it's headlights. Whether it be an entire headlamp replacement, wiring repair or merely replacement of a burned out bulb, the double wall construction has the component you seek well tucked away. You will even be asking yourself "why would they design it this way?" The reason is usually for safety of the occupants. It is much better to have a safer, well protected vehicle than one with easy to replace parts.
  • 1/4" Drive metric socket set
  • Wide blade screwdriver or panel clip removal tool
  • Plastic or rubber hammer
  1. replace-2007-saturn-aura-headlight-1.1-120x120.jpg socket wrench image by Jim Mills from Fotolia.com Socket wrench needed here Remove the five, 10mm bolts and two spring clips securing the top grill shield above the radiator.
  2. 2 replace-2007-saturn-aura-headlight-1.2-120x120.jpg Screw driver and spanner kit image by Dmitry Rukhlenko from Fotolia.com A job for a nut driver or small socket Remove two, 7mm screws holding the top of the headlight down and one holding the top of the bumper cover to the headlight.
  3. replace-2007-saturn-aura-headlight-1.3-120x120.jpg screwdrivers image by Christopher Dodge from Fotolia.com Use a screwdriver or perhaps a small putty knife to remove the push clips. Pry out three or four of the plastic push clips along the outside edge of the wheel well liner using a small screwdriver or putty knife. Remove the push clips and two screws along the bottom of the liner.
  4. replace-2007-saturn-aura-headlight-1.4-120x120.jpg Screwdriver image by Yuri Tuchkov from Fotolia.com Back to the nut driver or socket set Remove four screws securing the font edge of the gravel shield to the bumper cover underneath
  • socket set wrench image by Christopher Dodge from Fotolia.com
  • Dec 12, 2010 | 2007 Saturn Aura XR Sedan
    Need to replace asus A3F keyboard
    Push in the four tabs at the top of the keyboard with a small flat screwdriver and prise out the keyboard, there are no sercuring screws behind.
    Feb 18, 2010 | ASUS Laptop Keyboard for Asus A3, A6, A9,...
    I need to remove a gateway convertible cx2610 case to replace the motherboard.
    Removing the casing of a notebook is a tough job. Even after removing the screws, the covers won't come out. The reason being the clip locks aroung the edge.
    Slowly pull apart the two sides (top and bottom) from one place and push a screwdriver through the opening. (Don't push it too far or you will damage the circuitry). Push another flat screwdriver inside close to the first one. Slowly drag the second one along the edge. If the casing resists opening at one place that means there is a clip lock there. Slowly push the screwdriver handle downwards. If you are lucky, the lock will open. If it doesn't work push the screwdriver handle upwards. (I've not opened this particular type of computer, so you have to check and see). Once a lock opens insert the first screwdriver there to prevent it from closing again.
    Slowly work around the edge to open all locks.
    Apr 30, 2009 | Computers & Internet
    Taking off shell of washing machine
    Remove the shell:
    nplug the machine. Remove the end caps on both sides of the console by putting a flat screwdriver in the top of the end caps from the back and gently prying up. Remove the two Phillips screws holding the corners of the console down. Lift the console and gently fold back. Unplug the lid switch. That's the 3-wire quick disconnect below the timer. (If you have a high price model, you'll have three hoses under a plastic cover on the left. disconnect those hoses before going further.)
    Using a flat screwdriver remove the gold clips holding the cabinet to the back. Place the blade of the screwdriver in the indentation closest to you and tilt the handle of the screwdriver back.
    Open the lid. Lift and tilt the entire cabinet toward you. Look down through the hole to the front bottom edge of the cabinet. It is hooked under the front edge of the washer frame. Remove the cabinet and place it aside.
    Replacing the shell:
    Pick up the cabinet, hook it under the front of the frame, and tilt it back into place. Push the sides of the cabinet in as you are tilting it back to make sure the hooks in the frame (back, sides) line up with the cabinet. You can know it's in place when the edges of the cabinet line up evenly with the edges of the back.
    Re-install the gold clips. Hook them into the back panel, put them into the slots in the cabinet, and push down until they snap into place. Re-connect the lid switch. Lower the console. Replace the screws. Replace the end caps - bottom first, then snap them in at the top.
    Happy washing!
    Mar 11, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
    Whirlpool
    If the motor makes no noise in the spin cycle only, it sounds like you need a lid switch.
    Unplug the machine. Remove the end caps on both sides of the console by putting a flat screwdriver in the top of the end caps from the back and gently prying up. Remove the two Phillips screws holding the corners of the console down. Lift the console and gently fold back. Unplug the lid switch. That's the 3-wire quick disconnect below the timer. (If you have a high price model, you'll have three hoses under a plastic cover on the left. disconnect those hoses before going further.)
    Open the lid. Lift and tilt the entire cabinet toward you. Look down through the hole to the front bottom edge of the cabinet. It is hooked under the front edge of the washer frame. Remove the cabinet and place it in a position you can work under it.
    The lid switch is held in lpace with two Phillips screws on the right edge of the hole. There is also a 5/16 in ***** holding the ground wire to the cabinet. Install the new switch using all the clips and screws that were holding the old switch in place.
    Happy washing!
    Fuji FinePix F700 Digital Camera Logo
    91 people viewed this question
    Top Fuji Cameras Experts
    Steven Wander
    Steven Wander
    Parshiv Luthra
    Are you a Fuji Camera Expert? Answer questions, earn points and help others
