Question about Philips Magnavox MRD-250 System
Won't play dvd's
It will play music cd's all the time however it has a mind of it's own when it wants to lay dvd's. Sometimes the dvd will play other times it will take a long time to load then play for just a few seconds, stop, then an error display message "bad disc" will show even though it could be a new dvd. I read that someone else had the same problem but the only suggestion given was to make sure the data side of dvd is face down and wipe of any smudges off or take any stickers off of it. I've done all this. Any other suggestions than taking it will greatly be appreciated since taking it to Best Buy to get fixed is out of the option. This problem has been driving me crazy I just want to watch a dvd.
  • dajeepman Jan 01, 2008
    I do also have the same problem. It will play CD's most of the time and store dvd's some of the time. When I try to play home made dvd's it dont want to read them. I get bad disk error all the time. My moms 30$ dvd player plays all cd's and dvd's i dont know why this is having this problem.
Mine was having the same problem. I took the case off, blew some compressed dusting spray(the kind that doesn't leave a residue) across the lens and the problem went away. Often, when the lens on laser devices gets dirty, they have a difficult time reading. Try this with any laser device that is acting up.
Posted on Jun 15, 2008
  • 752 Answers
The DVD portion of the laser is failing. A replacement (if available) should be about $50-$80 and most shops would charge about $50-$75 to put it in.
Posted on Sep 14, 2007
Cd does not work. Will not show movie.Please replace
There is a difference between a CD "music usually or data" and "DVD". Some players/computers only play CD's. Some are DVD/CD players/writers. Which is yours. If you have a CD player, it will never play a movie. Put in #1.a CD and try. If it works good. Then put in #2. a DVD it might not be a DVD player. Past that it would be a defective player. Get a lense cleaner disk at y computer/variety store". Insert it in your computer and run the program.lay a movie. If it is scratched or dirty. Clean and try again. No luck, You have a bad player of software issue. The Disk player can be slid out and replaced at any computer store. $59? Good Luck. John
Feb 11, 2015 | Computers & Internet
Tip
How to Restore a Scratched DVD or CD
You can save a Lot of money when you restore a scratched DVD or CD.
  • Pour rubbing alcohol on to a clean dry cloth. Try to use a cloth like the ones used for cleaning eye glasses. You can also use a pretreated paper cloth like the ones used to clean glasses.
  • Lay the CD or DVD on a clean flat surface label side down. Use the cloth to gently buff the exposed side of the CD or DVD until all smudges and fingerprints are removed.
  • Test the CD or DVD by playing it in a player. If it still doesn’t play correctly, try repeating step 2. If it does play correctly, continue enjoying your music and movies.
    Cheers. :)
on Dec 14, 2009 | Audio Players & Recorders
Tip
Enjoy :)
on Dec 12, 2009 | Computers & Internet
My cd/dvd player when playing music the sound is not constant and start to play like it slow and the dvd does the same is thair a repair for this or do i need to purchase a new cd/dvd burner/player my...
Kindly check first your software of your system.. sometimes occurred due to low performance of a system (software). do one thing, if the music your playing is from the disk... try to copy all that music from the disk and paste temporary to your hard drive.. once your done coping.. try to play the music from you hard drive.... if still same operation of your complain, means that the problem was on software....
Jul 11, 2011 | HP Computers & Internet
My portable dvd player will not read any dvds
  • I would give it a good cleaning with a disk player cleaning. Those disks have little bristles on them that "sweep" the lens and clean it real well. Remember that if the lens is so dirty that it won't play any DVD you may need to run that cleaner disk a few times to get the lens back to normal working condition.
  • A lens cleaner disk should be ran one time a week to avoid problems with playing disks be it CD or DVD or Computer.
  • Sometimes players go bad so keep in mind this could be the problem as well but I have had the DVD player in my garage get so dirty I had to clean it a few times to get it to work normal.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Jul 11, 2011 | Sylvania SDVD8732 Player
I have just purchased an HP Desktop computer and when I burn a Cd for music, everyting seems to work ok but when I try to play that CD on another player in my home, it won't play. Is there a setting...
Check the type of the blank CD/DVD you are using. Certain players won't be able to play CD-RW for instance.
If that doesn't solve the problem you might try to slow down your burn speed for a better quality CD/DVD. Sometimes a faster burn speed will lower the quality and other devices can have trouble reading these.
May 10, 2011 | HP Computers & Internet
Will not play disk comes up no disk
With the power turned off, open the DVD Player, and then open the top where you load the DVD into the player. Locate the laser lens and notice that the laser is attached to a transport assembly that moves the laser diagonally outward in a slot. 1. Slide this assembly outward to the end of its track. 2. Slide the assembly back inward to the closest inward position. 3. Repeat the process of sliding the assembly outward and then back inward.4. Put in a music CD and let it play all the way through. This helps to calibrate the laser head assembly movement. When the music CD is finished playing. 5. Put in a DVD, and you should have a working unit again This is a factory solution from Mintek that was given to a customer who ask for help with the forever loading disc problems. This solution may work on other models of portable DVD players. Most portable DVD players use this type of transport mechanism. Try this solution it might work for you. I hope this information helps you with your problem.
Apr 12, 2009 | Mintek MDP-1770 Portable DVD Player
Disney dvd player wont play movies (dvd) but plays music (cd) fine
Might be the type of movie - some of them are only able to play "G" ratings. Try this: click <play> 1234 <play> It will likely unlock the dvd that is in and will begin to play. You will have to do the 'code' each time, or there's an unlock program you can purchase.
Aug 07, 2008 | Disney Princess DVD Player
Philips Magnavox MRD-250 System Logo
139 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
