Question about Fujitsu LifeBook T3010D Tablet PC
Fujitsu lifebook Won't start up
Won't start up at all. Battery indicator shows adapter is giving the unit power but it won't start up at all.
  • Fujitsu Master
  • 13,434 Answers
Please take the laptop to a repair shop for analysis. Possibly faulty motherboard or other parts. Repair price may be high.
Posted on Feb 11, 2008
SOURCE:
Forgot password Fujitsu LifeBook T4220 Tablet PC
Good day! What password are you refering to? Is it the one used for logging into the unit itself?
You can try the work around below.
- You can try to restore the unit back to it's factory settings if you don't have any important files in the hard drive.
Regards,
Meir
Nov 02, 2011 | Fujitsu LifeBook T4220 Tablet PC
AC adapter/charger is attached, but the battery will not charge. it doesnt even show that the battery is there
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jun 21, 2011 | Toshiba Portege M200-S838 Tablet PC
Fujitsu nseries won't power on at all
check ur laptop battery and charger are okay. try to on it with direct adapter power if it will be on so replace ur battery
May 02, 2010 | Fujitsu LifeBook T3010D Tablet PC
Fujistsu T4215 no POST, numlock blinks
You need to send it to Memphis, Tn for a factory reset, call the Fujitsu 800 number on there web site and have your serial number handy.
Don't disassemble a Fujitsu!! Ever!
They automatically lockup as a security precaution, aren't you glad you saved some money?
Oct 07, 2009 | Fujitsu LifeBook T4215 Tablet PC
Not used for 1year will not charge up
It is possible that the battery of your Tablet is dead, Still you can try to connect the Tablet PC Directly with the AC adapter.
For you reference you can download the Manual From the following link
http://www.retrevo.com/d/df/P1510D_06SPR_USERSGUIDE.PDF?doc=9388c66467ea4385d3e5c4b5df5cbd28&ts=1254481117154
Oct 02, 2009 | Fujitsu Siemens LIFEBOOK P1510D Tablet PC
The T4010 does not power on. The battery or power cable icon blinks every 3 seconds. Appreciate any help. Thanks
The blinking light usually means the battery is dead and can't power on the laptop. If the charger is bad and won't charge the battery you will have that type of error. Get a multitester and check the voltage coming from the ac adapter. Put the meter on voltage, now put the red lead on the center pin and the black lead to the outside metal contact. You should get a reading of 18 to about 26 volts. My guess is the adapter has a short and can't power the unit. You should be able to get a replacement adapter from Ebay.com
I hope my solution works, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Jul 08, 2009 | Fujitsu Siemens LIFEBOOK T4010D Tablet PC
Resetting Security Panel Password
Its by virus problem. scan your computer by antivirus with update then try again.
Sep 20, 2008 | Fujitsu LifeBook T4220 Tablet PC
Fujitsu Lifebook T Series wont power on at all
1) Remove battery and power cord  2) press power button several times  3) Whack laptop on the bottom center 2 or 3 good times with the palm of your hand  4) Replace battery and plug  5) Power it up (may have to hold the power button several seconds)
Aug 06, 2008 | Fujitsu LifeBook T3010D Tablet PC
Fujitsu LifeBook T3010D Tablet PC Logo
977 people viewed this question
Top Fujitsu Tablets & eReaders Experts
k24674
Rachid Mekrob
Rachid Mekrob
Level 1 Expert
Tony Raia
Are you a Fujitsu Tablet and eReader Expert? Answer questions, earn points and help others
