Question about Whirlpool LER5636P Electric Dryer
Dryer wont turn on
I set the dryer to dry. Ran for less than 5 minutes and then it shut off. i fiddled with the breaker.....nothing. pulled the dryer out from the wall and made sure dryer was plugged in...was. So now i dont know what to go. please help!
  • 4kidsolder Feb 09, 2009
    My dryer worked perfectly fine for almost 3 loads. Went to put load in before went to bed and woke up in morning and everything was still wet. Now dryer won't even turn on. Already checked lint and ducts and they are clear. Dryer is about 3 years old.
  • 5,911 Answers
This is usually a symptom of a thermal fuse that has blown. A blown thermal fuse is a symptom of other problems (usually). That is to say that they generally blow for a reason. The most common cause is a dirty dryer and/or clogged vent duct. If it's been a while since you've cleaned your dryer and/or the vent duct, you might want to do so BEFORE you replace a thermal fuse. Or, the problem will persist. If your heating element is in the rear of the dryer, the thermal fuse will be located on the blower fan housing on the left hand side of the dryer. It is white in color. If the heating element is located inside the dryer under the drum, the thermal fuse will be located on the blower fan housing right under the drum in the front of the dryer. The fuse should read a short. If it does not, you need to replace it. It is not resettable. Let me know if you have any further questions. I hope this helps you.
Posted on Sep 14, 2007
Dryer is a week old. ran a cycle and dryer turned off. didn't trip breaker. wouldnt turn back on. so turned breaker off for a while then turned it back on. now dryer powers on but for only like 10 seconds...
A week old dryer should have, in its warranty, a condition that you can get them to exchange this for an identical (hopefully working) model free. Do it now, that is a short time window. It's usually one month.
Nov 16, 2013 | Samsung DV50F9A8EVP 27" Electric Dryer...
Dryer turns on heats up, shuts down, starts again runs for a bit, then kicks off again
This is the device that keeps the motor from over loading/heating. It's a bi/mwetal strip. Maybe a good cleaning of dryer will help but also you did not say if the motor ran and the heat stopped which could be another type problem. Try different setting on timer such at timed or less dry/more dry.
Nov 02, 2010 | Kenmore 83142 Electric Dryer
I have a GE Dryer Profile Harmony. It is several years old. The dryer is not blowing air out the back ventilation so not drying. It is making a quiet odd sound as well. When I troubleshooted I shut the...
You vent is plugged very bad. Disconnect the vent tubing and thoroughly clean it out. It will heat and dry like new afterwards guaranteed. These dryers have sensors that shut the burner off if the exhaust is not venting properly. Once its cleared out it will run perfectly again
Apr 09, 2010 | GE Profile Harmony DPGT750EC Electric...
Amana model LGA30AW automatic setting doesn't shut the dryer off
You can make adjustments to your Automatic Cycles by adjusting the Factory Dryness Level:
Changing the Automatic Cycle settings to increase or decrease drying time:
If all your loads on all Automatic Cycles are consistently less dry or more dry than you would like, you may change the default settings to increase or decrease the default dryness
level.
Your automatic drying settings can be adjusted to adapt to different installations, environmental conditions, or personal preference. This change is retained and will affect all of your
Automatic Cycles, not just the current cycle/load. There are 5 drying settings, which are displayed using the time display:
0 Much wetter clothes, 30% less drying time.
1 Slightly wetter clothes, 15% less drying time.
2 Factory preset dryness level.
3 Slightly drier clothes, 15% more drying time.
4 Much drier clothes, 30% more drying time.
TO CHANGE THE DRYING SETTINGS: NOTE: The settings cannot be changed while the dryer is running or paused. The dryer must be in standby mode (power is off) to adjust the default settings.
  1. Before starting a cycle, touch and hold DRYNESS for 6 seconds.
  2. Touch DRYNESS to select the dryness level shown in the time display: 0, 1, 2, 3, or 4.
  3. Touch START/PAUSE to save the new dryness level setting.
Oct 05, 2017 | Amana ALG331RAW Gas Dryer
My Maytag dryer model number MDE5500AYW has lights on, but won't switch settings. It is stuck in time dry at 18 minutes. Yesterday it was on sensor dry 47 minutes. Do I need a new control board inside...
OK, your control board and LED are integrated, so you will need to just replace the control board. I would try a hard reset before replacing the board. Pull the plug or, shut down the appropriate breaker switch for 5 minutes. Re apply power after the 5 minutes are up. if you continue to experience this fault, replace the control board asap.
CONTROL PANEL(CLICK HERE TO ORDER)
Aug 28, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Whirlpool electric dryer not drying
If the drier drum is still turning I would suspect a separate fuse is open for the heating element. Checking this may require openning the back cover. It may also be a defective or open heating element.
Jan 28, 2009 | Whirlpool LER8648L Electric Dryer
Kenmore Elite HE4 electric dryer locked on express dry only......
Shut the breaker off for several hours. Turned it back on.
Nov 30, 2008 | Kenmore Elite HE4 Electric Dryer
Dryer shut off towels were not yet dry, turned dial to restart dryer acts as if it isn't getting power I closed door and pushed start button. Nothing! Checked breakers and power cord at outlet all checked...
Hello mdonettaYou said,
Dryer shut off towels were not yet dry, turned dial to restart dryer acts as if it isn't getting power I closed door and pushed start button. Nothing! Checked breakers and power cord at outlet all checked okay. Any ideas.
yes, try unplugging the power cord or turning off the breaker for 5 minutes. Either will due. Some times the system needs to be reset!
If this does not work there are internal fuses that can be replaced!
Let me know how it goes!
Huuum
Sep 19, 2008 | Dryers
Dryer wont turn on
The dryer has an overfill cutout if you start and hold in the start button you should hear the pump come on,and pump the water out. then the dryer will start.if it happens again you may have a blockage in the black drain hose take the top panel off and blow down it,or the pump itself could be faulty.(if the dryer is sitting on the floor you have to drain the water into the drawer, if its mounted ontop of a washing machine you can connect the long bkack hose to the sink.
Nov 19, 2007 | Asko T721 Electric Dryer
Whirlpool LER5636P Electric Dryer Logo
4,999 people viewed this question
Top Whirlpool Dryers Experts
Sal De
Craig Butler
Craig Butler
Marvin
Marvin
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
