Question about Kirby G6 Bagged Upright Vacuum
G6 cutting out
My G6 keeps cutting out when you move the upright handle and it seems to be very loud I stopped using it as I didnt want to have it burn out, just incase there was a short or crossed wires or the like can you please help I miss my cleaner.
  • 357 Answers
I agree with Chris... DEFINATELY the power cord! Visit my troubleshooting guide if you have any more problems....
http://reviews.ebay.com/COMMON-PROBLEMS-WITH-THE-KIRBY-VACUUM-TROUBLESHOOTING_W0QQugidZ10000000003800312
Marci
Posted on Oct 23, 2007
    Problem Solver:
  • 7 Answers
Hi There, If it keeps cutting out when you move the handle it's usually the cable that has gone. Turn the machine on and waggle the cable if it cuts in and out then you can confirm it's the cable. Many Thanks Chris www.elidistribution.co.uk
Posted on Sep 14, 2007
SOURCE:
When handle is in lock postion the brushes are spinning and when yu move the handle down the brushes stop spinning ( HELP ) Thank you Morgan Yochem
seems like theres a bad contact there must be the switch when you have it up its working and when you bring it down looses contact
Feb 16, 2011 | Bissell ProHeat Turbo Deep Cleaner Upright...
My sebo keeps cutting out while I use it the turns back on when I move the lead about. Its over 5 half years old?
Sounds like the flex is damaged. This happens most often either right near the plug or where the flex enters the handle. There may be no damage visible externally, but still the copper wire inside can be broken. You say that moving the flex about makes a difference, so you will know where the problem is. If the damage is indeed at one end, then you can simply cut the flex and re-wire it. If you need to have someone do it for you, get a firm quote as it may be cheaper to fit a complete new handle (there's no labour cost involved because the handle just slides in). I hope this helps!
Jan 31, 2010 | Sebo X4 Bagged Upright Vacuum
The rotator brush stopped turning. it turns fine
The brush roll will only spin when your handle is not in the locked upright position, once the handle goes upright - the brushroll de-activates
Dec 22, 2009 | Kenmore Progressive Bagless Upright with...
Kirby g6 will not pic up dirt. Belt is on and bag
check for blockage or impeller if vacum makes loud noise the impeller is the part that gives it suction
Oct 15, 2009 | Kirby G6 Bagged Upright Vacuum
The vacuum drive makes a wining sound
Does It make the noise all the time or only when the machine is moving. If it does it only when you push the vacuum that noise is normal. The older Kirby transmissions make a whining noise when pushed.
Mar 24, 2009 | Kirby G6 Bagged Upright Vacuum
Just stopped running while vacuuming
When a vacuum cuts out while working, it usually indicates overheating. Most have a thermal cut-out, which will reset itself if given time to cool. The cause is usually a blockage of some sort.
Feb 15, 2009 | Kirby G6 Bagged Upright Vacuum
Bissell Healthy Home Won't turn on
I found the solution for my vaccum!!
The top handle connects to the lower half of the handle with one phiilips head screw. The screw is halfway between the cord holder on the back. The screw had come loose and the handle has slid back away making it not make contact to send the power down to the motor.
Hope this helps someone else!
Feb 13, 2009 | Bissell Healthy Home HEPA Bagless Upright...
Kirby G6 Bagged Upright Vacuum Logo
252 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Gerry Harvey
Gerry Harvey
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
