Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
I have totally no sound i have many sound codecs installed
But there is still no sound plus it shows that there is no sound devices installed what should i do and what is the proper program to be installed?
  • 700 Answers
Install the driver for your soundcard if it is a built-in one or add-on card. K-lite codec pack is a good application for many audio format. And under sound/speaker setting you should set the speaker on, not mute. And your speaker is totally working.
Posted on Apr 15, 2009
Divx plus player can't produce sound of a .mkv file saying that I should install additional codecs (directshow). But how to do this?
The KLite codec pack contains most of the codecs you'll ever need including the audio for .mkv files.
It's free from here If you use the advanced option on install you can select the codecs you require.
Oct 08, 2010 | DivX Plus Software
Tip
Use REVO to totally Uninstall a Program folder and its Registry keys
Many program upgrades have their own old version uninstall prior to the upgrade install often times with a PC restart in the middle. For example Elecard MPG Player v4.6 to v5.6.
I have been looking for a way to do this for programs that don't adopt this technique for months now there are a few FREEWARE programs that are available like JV Powertools and Total Uninstaller but the Daddy of all has got to be REVO Uninstaller Pro.
Join them on RevoUninstaller@Facebook for a 20% discount on the FULL version its well worth the money I had major problems upgrading DivX Pro v7.0 to DivX Plus v8.0 it did OK on most of the install but left behind the old v7.1 DivX Convertor folder and registry keys and hid the serial codes on the new DivX Control Panel for all the older registered serials except the upgrade v8.0 serial.
Using this program I could locate the correct uninstall string even after the DivX own installer it leaves behind 198 registry items under the {7B63B....} key and 12 folders shown in red below using Total Commander with a total of 11.5 MB
Using REVO you can find where DivX is located in the registry and create a unique registration file just for my serials to un-hide them. Prior to the upgrade if you check DivX Pro v7.0 for updates it will tell you this as shown below it includes the H.264 Decoder v1.1.0
Sometimes after the upgrade you will not see the serial numbers like above or you may just see the DivX Plus Convertor 8.0 serial on the control panel it will just say registered if you want this to show you need to create a reg file replace the "" with your 20 digit serial that you purchased and all will now SHOW on the control panel the latest version of the pro codec is v6.9.2 you can check this using regedit and goto this reg key you will also see the other codecs that are loaded
You may see and extra line that has the same code as the procodec this is for the older professional version of the convertor before they rolled out the plus versionand can be removed from the DivX v8.0 Plus registry key
"converter67"=""
If you check for updates in the new control panel it does not tell you which versions that you have installed you will need to check the Product Registration page
This is what it will look like before you edit the registry key to show the serial numbers, NOTE these are stored unencrypted in your registry so make sure that no-one has access to them.
on Apr 29, 2010 | Microsoft Windows XP Professional
Sound device will not working for playback of songs....it may work for other kins of sound like clicking
You probably have not install the require "codec" to play the sound format.
Download the codec from : http://www.free-codecs.com/index.htm and install them.
You probably need to install the K-Lite Codec Pack or K-Lite Mega Codec Pack
Jun 30, 2010 | Computers & Internet
Sound driver problem in compaq presario cq40 with winXP
update to service pack 3, then go to update driver in device manager and allow it to search the internet it will find the HD audio codecs from microsoft and install them.
Jul 02, 2009 | Compaq Computers & Internet
No Audio
Here is the link to the page for the driver for your audio. once you install this you should be up and running again. Hope this helps!!
Jun 28, 2009 | Intel Computers & Internet
Sound problem in hp pavilion dv2000 with window xp
well u need to tell me which series of pavilion dv2000 Note it's located on the label as in this example: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&lc=en&cc=us
Jun 06, 2009 | HP Pavilion dv2000t Notebook
Sound program
is it movie or music?
if it is movie use g-spot to find out which codec is missing
http://www.free-codecs.com/download/GSpot.htm
if it is music check your soundcard and the options in windows media player
Jan 22, 2009 | Intel Premier Resources 4-Channel 32-Bit...
Installed XP SP3. audio not working
I need driver sound card for PCI\VEN_13F6&DEV_0111&SUBSYS_80E21043&REV_10
Oct 05, 2008 | ASUS M2N-MX Motherboard
No audio device installed on my laptop
I'm not sure whether this is the exact same problem, as I was having, but mine just randomly quit while I was listening to music this morning. I got messages saying "No audio device installed", but when I went to device manager, all my audio devices said they were working properly. If this is the case with you, simply restart your computer. It may take a couple restarts, but this should work. My sound was back even before it finished shutting down.
If it helps anyone trying to get to the root of this problem, I am running XP on a Dell B130 laptop, with the following devices listed in Device Manager:
Audio Codecs
Legacy Audio Drivers
Legacy Video Capture Devices
Media Control Devices
SigmaTel High Definition Audio CODEC
Video Codecs
Hope this helps!
Jan 22, 2008 | Creative Labs Sound Blaster Audigy LS...
No sound
The drivers you mention are related to your sound drivers to they are installed. Run this programme to see if there is a driver problem, click Start>Run then type 'dxdiag' and hit enter. It could be the motherboard sound chip thats failed.
Jan 27, 2007 | Dell Inspiron 6000 Notebook
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
47 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
