Question about HP Compaq Presario SR2150NX PC Desktop
Need a manual for password reset jumpers - HP Compaq Presario SR2150NX PC Desktop
    President:
  • 623 Answers
Here you go!
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00864922&cc=us&lc=en&dlc=en&product=3339274#N836
If you scroll down a bit you can find detailed instructions.
(I wish all manufacturers had support pages like this...)
If you have any other questions, come back here and leave a post - I'm happy to help if I can.
Posted on Apr 15, 2009
Dell d340. need to enter admin password in bios to reorder boot sequence to accept usb first - its locked and i cant remember password. tried removing cmos battery and replacing but no good. help!
Try the backdoor password Dell
With a PSWD Reset Jumper Step 1Open the access panel to the password reset jumper if your Dell laptop has one. Consult your manual for the access panel's location. Some access panels have a tab you slide, while others are held in place with a screw.
Step 2Pry the plastic cover off the reset jumper with your fingernail. The reset jumper is a small pin port labeled "PSWD" with three pins. Put the plastic back onto the jumper over pin 1 and 2 instead of 2 and 3. Wait 90 seconds.
Step 3Pry the plastic off the reset jumper again and place it back onto the number 2 and 3 pins. Turn the laptop on. Repeat step 2 if the password is still present. Leave the plastic clip on pins 1 and 2 for a longer duration than last time.
Without a PSWD Reset Jumper Step 1Locate the reserve battery, also known as the CMOS battery, if your Dell laptop is not equipped with a password reset jumper. The CMOS battery's location varies among Dell laptop models. Consult your manual for the battery's location on your specific Dell laptop model. Many Dell reserve batteries are located underneath the main laptop battery. Remove the main battery and look for a sticker under it with instructions on removing the secondary CMOS battery.
Step 2Remove your Dell's reserve battery per the instruction manual or sticker located under the main battery. Removing the reserve battery resets the laptop's BIOS password. Wait 90 seconds, then replace the reserve battery. Reconnect the main battery.
Step 3Press the "Power" button to turn the laptop on.
Here is some youtube video with your problem:
http://www.youtube.com/results?search_query=dell+bios+password+reset+laptop&oq=dell+bios+password+reset+laptop&gs_l=youtube.12...2937.2937.0.5179.1.1.0.0.0.0.44.44.1.1.0...0.0...1ac.2.rXrXigbVpXM
Try also to call dell support in your country
They will be glad to help you out.
Good luck
Nov 08, 2012 | Dell Computers & Internet
Sirs I have not made any password for entering bios setup for compaq presario x1370 us, but when try to enter bios setup by pressing F10, display for administrtor password appears. What password could i...
But there is no need to worry. There are many known ways to reset / remove / bypass the password: Almost all motherboards use a small coin sized CMOS battery to store all BIOS settings along with the password. To reset the password, unplug the PC, open the cabinet and remove the CMOS battery for approx. 15-30 minutes and then put it back. It'll reset all BIOS settings as well as the password and you'll need to re-enter all settings. If it fails, then try to remove the battery for at least one hour. B. By Using the Motherboard Jumper: Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc. When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin. Make sure to turn the PC off before opening the cabinet and resetting the jumper.
Feb 25, 2011 | Compaq Presario X1370 Series Laptop...
How to reset or clear a system bios password
The general categories of solutions to reset a BIOS password are:
  • Using a Backdoor BIOS Password
  • Resetting the BIOS Password using Software
  • Resetting the BIOS Password using Hardware
  • Vendor Specific Solutions for resetting the BIOS Password
  • or with a simple one is taking out the cmos battery then place it back 5-10 minutes after..so use the simple one if you don't have the other mentioned above..
  • Goodluck!!!!
Feb 20, 2011 | Toshiba Satellite M35X-S161 Notebook
Need to change mouse settings on bios but i forgot my password
Jan 24, 2011 | ASUS M51Ta-X1 NoteBook
Reset bios password
please give me lenovo sl400 bios reset password thanks
Oct 12, 2010 | Matsonic MS9158EP (DSMTSMS9158EP)...
How do i reset bios password on a used dell 710m inspiron?
For you to reset the bios all you need to do is to take it out, but before you do that you'll need to power off your laptop.
Regards
Oct 13, 2009 | Dell Inspiron 710m Notebook
How do i fixt it. it has crash and now asking for a pass word and i dont have it the screen is black
here are 2 password type first 1 is bios password if tell me about your bios password it prompt when u powerup follow procedure below
For that you need to reset factory defaults settings for bios.
For reset bios u have to open back side of your laptop then u find motherbord circuit there.
pull cmos cell on motherbord for 15 minute then it reset to defaults.
Also u can reset with jumper settigns read carefully on mother bord there is 1 jumper near cmos cell u read there " bios reset or clear"
It is on 1-2 position right now set it in 2-3 position then power up then all bios settings are reset.
then again set it in 1-2 its original position.
Then it not want password.
And if u tell about windows password
Then when you power up the computer press F8 key then enter in safe mode then wait until it prompt for user password
then enter in administrator then if u able to enter then reset your password.
But if u set and forgot default administrator password then u should need win xp recovery disk.
Jul 28, 2009 | Dell Dimension 3100 PC Desktop
How to get toshiba bios password remover toos
ok what you will need to do is reset the bios. just take out the bios battery for a couple ofseconds then putit back in this normaly resets the password Regards Slitwrists
Jun 08, 2009 | Toshiba Portege S100-S1133 Notebook
Forgotten the password , without it coputer wont boot
Sounds like you have set a password in the BIOS. If you have forgotten the password then you will need to reset the BIOS settings to their default. This is usually done by setting a jumper on the motherboard. You are going to need to get your motherboard's manual and find the BIOS Reset jumper switch. Once you set this jumper properly, the settings in the BIOS will be reset to their default values.
Oct 05, 2008 | Packard Bell Computers & Internet
HP Compaq Presario SR2150NX PC Desktop Logo
48 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
