Dell Inspiron? 1501 PC Notebook
Problem for Dell Inspiron? 1501 PC Notebook
Slow laptop
By adepas on Apr 15, 2009
my wifes laptop is very slow. I know that I can go to run run.msconfig'start up. But I do not know what I can delete. If I delete progam files wit it hurt the computer? Is there away to know what I can and can not delete? Thanks
Best Solution
posted on Apr 15, 2009
Very Helpful)
laxmenp
Rank: Guru
Rating: 90%, 60 votes
hi,
i would tell general steps to make windows faster.
  1. Click on Start, then Run, and type "msconfig". Wait for a new window to pop up.
  2. Look under the "BOOT.INI" tab. You will see a box labeled "Timeout:", and a numerical value. By default, it's 30, which means 30 seconds of wait time before boot. This can be changed, using 3 seconds. (Note: if you have more than one operating system, this means the wait time to startup to the highlighted OS. you might want a bit more than 3 seconds)
  3. Delete the temporary files periodically from your computer to make the applications run faster. Type %Temp% in the run dialog box by clicking on Start -> Run, and click on "OK". You will see an open folder with many files. Click on the Edit menu and click on Select all and then click on the File menu and select Delete. Note: Always confirm that the folder which is opened has a temp on the top of menu bar and the folder indicates that it is a temporary folder.
  4. Perform a scandisk to see that your computer hard drive is in healthy condition and it helps your computer run faster.
  5. Always perform a disk defragmentation at least once in a month. start the disk defragmentation from the system tools available in the accessories from the start menu. it takes a longer time and it is advised not to run any applications in the computer including the screen savers, while running disk defragmentation.
Hibernation After you have done all this, another method you can do is to allow the computer to hibernate. Hibernation closes and opens Windows faster than normally.
  1. Go to Start->Control Panel->Power Options. Click on the Hibernate tab.
  2. Click on the box that says "Enable hibernation" to check it.
  3. Click on the Advanced tab and change the Power buttons options if you want to hibernate by pressing the sleep button or the power button. Otherwise, holding the Shift key while in the Turn Off Computer menu will give you the option to hibernate.
  4. Restart your computer every week or so to clear your computer.
The power can then be completely turned off, even at the socket so that no power is wasted.
Prefetch
  1. Simply browse to the windows folder (Ex: C:\Windows) and under there you should see the prefetch folder. Go into the prefetch folder and delete all the files (Careful! It should look like this c:\windows\prefetch). We need to edit a registry key to tweak it. Open regedit and browse to this key:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Memory Management\PrefetchParameters
Under this key you should see a value named: EnablePrefetcher
It has 4 possible values:
0 - Disabled : The prefetch system is turned off.
1 - Application : The prefetch only caches applications.
2 - Boot : The prefetch only caches boot system files.
3 - All : The prefetch caches boot, and application files.
We don't want to disable it entirely. This would actually make boot times *longer*. This is because this feature is also used to speed up the loading of boot files. That is why we are going to pick the number 2 option. It allows us to keep the advantage of caching system files, without continually clogging the system up with applications.
Set the value to 2 and reboot.
The 2nd time you boot it should boot much faster. Remember that the side effect is that launching individual applications once windows has loaded will now be slightly slower.
TIPS
  • When installing new software choose not to add the program to the startup folder.
  • Regularly check to see what programs are running from your startup folder as malicious programs such as spyware may have installed itself without your knowledge.
  • If you accidentally uncheck a program, just retrace the steps above and recheck the program and restart your computer.
  • Adding more RAM to a Windows XP computer helps it boot faster, and since RAM prices are very low these days, it's an easy way to boot faster.
  • Visit http://www.Sysinfo.org and look up the program and its details you don't know what one of the listed programs do.
  • uncheck system startup unneccessary startup programs*
here is another website link to handle msconfig utility
http://www.harry-inc.com/three-easy-steps-to-make-windows-faster
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #2
Not Rated)
jassji
Rank: Guru
Rating: 86%, 56 votes
the only factor here is not the msconfig all the rest of the things also matter. You have not mentioned that which Operating system are you using. You must also check with the system specifications is the memory is less even then the system will work slow, As fas as MSconfig is concerned you just come to the services tab and select the option hide all microsoft services and then uncheck the one which which you do not need. and regarding the tasks do not remove anything related to your security software and wireless or internet services. It will not damage your machine
Was this helpful?
Yes
No
Solution #3
Not Rated)
satchi2k2
Rank: Wiz  Dell Computer Hardware  Expert
Rating: 84%, 466 votes
you can delete the entries that are not required...if u delete wrong entry..then you can change it in safe made...(Pressing F8 while booting to enter into safe mode) ..so don't waorry...
Was this helpful?
Yes
No
Popular Solutions for Dell Inspiron? 1501 PC
Questions and Unsolved Problems for Dell Inspiron? 1501 PC
Do you recommend Dell Inspiron? 1501 PC Notebook?
Answer
Answer
web cam shows up but will not let me cam with other people using messenger
Answer
when i turn on the laptop all three locks flash then he numlock and scroll lock turn on and there is... (More)
Answer
i downloaded the drivers for my laptop the dell site and when my system restarts to complete the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Laptop Experts
Top Computer & Laptop Repairmen
in , CA
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
