Question about Plumbing
Can't remove broken PVC pipe from bathroom wall...need to install new faucet
My bathtub faucet fell off. It was connected with a plastic pvc pipe which of course is broken. I was advised to purchase a NIPPLE EXTRACTOR to remove the pipe remaining in the wall before I can install a new faucet. Well, that doesn't work...and I am tired of taking a shower in my son's not-so-clean shower. HELP.
    Genius:
  • 1,055 Answers
There should be an acess pannel there somewhere too get too it ,if not then you will have too cut the wall and replace the pipeing
Posted on Apr 15, 2009
Fix broken graywater valve and pipe 2002 r vision 5th wheel trail bay
find a caravan shop and they will probably have a range of valves that will fit. Most of the piping will be PVC piping that can be replaced and joined using a PVC glue available at the caravan shop or from a good hardware shop.
Feb 19, 2015 | Cars & Trucks
Can you fix a broken pvc pipe
more specific please. so your saying that the actual faucet sticking outta the wall is PVC and not a Brass for plated brass pipe? Also what type of valve do you have. Is it a single knob valve that you rotate to turn on as well as adjust your water temperature, or is there 2 knobs one for hot and one for cold?
A picture would help me answer your question a lot easier
Jul 01, 2014 | Delta Faucet Delta RP17453 Pull-Down...
I have a Lasco whirlpool spa SG72ACSK that is new and never used. I would like to add a heater to this unit, is it possible to do so? How?
It is always possible to add a heater to any jetted bathtub at any time.
What you need to find out that is if the tub is plumbed to each jet with rigid PVC pipe or flexible PVC pipe.
If it is plumbed in flex pipe then the Tee heater will be easier to install however if it is plumbed in rigid PVC then I would suggest a inline pressure heater that you will install in the water line any place after the discharge of the pump.
Here is a link to a installation instructions so you can see how all heaters are installed.
US Parts Center
Oct 26, 2013 | Whirlpool Lasco 7460621R Dossi-32 , White
I have a 3" pvc pipe that has a nail hole in it inside the wall of my family room. We have opened made a whole in the drywall and found the pipe and hole but now we need to know the best method to repair...
Get a rubber splice joiner for that size of PVC Pipe. Just cut the pipe with a hacksaw and maybe another inch for clearance to put the joiner over both pieces of pipe and apply clamps. If you forget to put the clamps on then just unscrew them completely and wrap around the sleeve and tighten. Got mine at a plumbing supply, Lowes should have them.
Aug 29, 2013 | Home
I broke the pvc pipes that transport the water to the jets. I need replacement pipes. Where do I get those?
the PVC pipes used to plumb bathtubs can be either rigid PVC pipe or flex PVC pipe. You may use either kind and is usually available at your local Home Center.
Jan 10, 2011 | American Standard Colony Hydro Massage...
I have two bathrooms directly under each other. The hinges on both cabinets (under the sink) are rusted and the pipes going from the wall to under the sink are also rusted. There are NO LEAKS ANYWHERE in...
You can't stop condensation or humidity in the house, especially in the bathrooms. A few choices: replace the hinges, or oil the hinges with WD-40. Install a vent fan (even though you have a window) and replace the pipes with PVC pipes. Metal drain pipes will always rust, because they drain water. Replace all under sink drain pipes with PVC
Mar 13, 2010 | Home
Bathroom sink needs new drain, leaks under counter
Is it a new sink? Most of the time if it's new you'll have to get more pvc pipe because the new tail piece that comes with the new faucets usually is either longer than before or shorter. Yes you can get another tail piece or you may be able to by a longer pvc piece to to hook up the the metal tail piece. Make sure you have the plastic seals inside the pipe where they attach together or it will leak. Once you have it all together close your stopper and fill the sink with water and then pull the sink stopper and watch for leaks if it dont leak then it wont leak.
Dec 30, 2009 | American Standard Cambridge 5' Americast...
Bathroom drain pipe has no threads
I 'am having a hard time visualizing this problem ? is your drain line a PVC pipe or is it the old style brass that was once used?
Jul 26, 2009 | Plumbing
Bathroom plumbing parts list supply line connections cracked (frozen). I have opened the wall behind the bathtub faucet, and can see the problem, but I don't have a clue as to how to repair them. I am...
if you don't know how to sweat copper the best way is cut out the split,and replace with compression couplings and the rite size and length of copper. or you can use sharkbite couplings and pex pipe or copper. sharkbite is the easiest way to go,you just push them together. home depo or lowes carry both
Jul 16, 2009 | 2000 Cadillac Seville
Broken pvc plumbing for bathtub faucet.
if you have tiles in the bathroom wall, the answer is yes!
it is better to go fromthe back, where there is drywall.
since PVC is glue on, you have to cut out the pipe and reconnect.
make sure the bathtub faucet is not broken, and can be reuse.
Nov 11, 2008 | Plumbing
Plumbing Logo
996 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
