Question about Norelco 8894 XL Electric Shaver
Norelco 8894XL will not take a charge
I've had this razor for about 6 years. Suddenly it went from its normal ~100 minute battery life to nothing. After charging it for a while, it says 100 minutes, FULL. But it only runs for a few seconds to maybe a minute before suddenly shutting off and saying zero minutes again. It does the same thing if I try to use it plugged in. Plugged in, It will run for a few seconds and then die. If I unplug it and plug it back in, it will run for a few seconds again before dying. That makes for a *very* slow shave!
Is this a battery problem? Can it be restored or replaced?
  • 276 Answers
Sounds like you're getting to the end of your natural battery life. As for replacing the batteries, it's not an easy job. You need to have a special Torx screwdriver to undo the screws.
The batteries are soldered onto the Control Board (it's unfortunately not just a case of cracking open the case and putting in batteries in an instant)
It may be worth speaking to your local Philips Service Center (refer to www.philips.com)
Not being at work, I can't check whether your shaver is a mains/rechargeable, but if you plug it in and it works full power immediately you've got a workaround. I usually recommend if you're replacing a shaver to spend a little more $$'s to get one that is mains and rechargeable so that when the batteries die, the shaver is still useable.
Posted on Apr 16, 2009
2 Suggested Answers
brector3
  • 1624 Answers
SOURCE: Norelco Spectra 8 Model 8894XL: Need a new Razor Head Assembly
It sounds like you need a new "head holder". These often wear out over time and fall apart. You will find a replacement at shaveroutlet.com. See link below.
http://shaveroutlet.com/norelco-philips-spectra-sensotec-head-frame-with-hinge-p-329.html
Posted on Feb 04, 2010
HQ8 or HQ6? What is the correct head replacement?
These Philips Norelco Replacement Shaving Heads HQ8/52 are compatible with the following series: 7100 series, 7200 series, 7300 series, 7700 series, 7800 series, 8800 series, PT/AT700 series and PT/AT800 series. They are sturdy and durable and provide for a smooth finish. The Norelco razor heads keep your shaves close and comfortable and are easy to replace.
Norelco HQ6The Norelco HQ6 is men's replacement heads. The Norelco HQ6 is made up of stainless steel and contains 3 cutters. The Norelco HQ6 works with all Quadra Action razors. HQ6 Features:Replacement Heads Stainless Steel 3 Cutters / Combs
Norelco HQ6
Oct 14, 2015 | Head Health & Beauty
Norelco Spectra 8865 XL Razor running slowly
there is whiskers under the heads,you need a small brush to clean them or your owners manual tells you how to remove heads which you can probable figure out yourself.
May 27, 2012 | Norelco Spectra 8865 XL Electric Shaver
Norelco 8894XL is charging to over 100 minutes. According to manual, it supposed to charge only to 100 minuyes. What is causing it overcharge?
I have owned a Norelco 8894xl for over 10 years. My battery meter will show 127 minutes after the razor is fully charged. The battery is not over charged. This is normal and does not indicate a problem. Hope this helps.
Jan 07, 2011 | Norelco 8894 XL Electric Shaver
Norelco shaver sudden power loss
I hope you are observing the following:- Recharging only when the batteries are almost completely empty. Continuously recharging or continuously using as a corded razor will reduce life of batteries Charge only when the indicator in charge meter starts blinking. It appears that your batteries are gone. Hope you have replaced the batteries with the new ones. Use a good brand
May 14, 2010 | Norelco Quadra 7885 XL Electric Shaver
Norelco SmartTouch-XL razor, stopped working won't charge
It is doubtful that the battery is bad because they dont normally go bad suddenly. Usually, they will degrade slowly and hold a charge less and less before they stop working.
It sounds like you may have a loose connection somewhere. Check the leads from the circuit board to the moto and also the tabs that connect the battery to the circuit board. These sometimes break.
May 03, 2010 | Health & Beauty
Feb 03, 2010 | Norelco Health & Beauty
I no longer have the owners manual. What does it
According to the manual, the red light comes on while charging when the battery does not yet have enough charge to sustain a 3-5 minute shave. The green light stays on steady while the razor is charging, and blinks when it is fully charged. If your battery life is short, they might need to be changed.
Jul 14, 2009 | Norelco Rechargeable Cordless Men's Razor...
I have a Norelco 6885XL electric razor that won't hold a charge. It will "recharge" to 44 minutes, but once below 39 minutes left it goes to 0 when turned on.
It's easy - I replaced mine (Norelco 6885XL) with a soldering iron & batteries I found online. Here's one place that sells them:
http://www.electricshaverstore.com/get_list_145.htm
As these are NiCd, I always drain them totally dead, then recharge, as this type of battery does suffer from the "memory effect".
Dave
Dec 16, 2008 | Norelco 7886XL Electric Shaver
Norelco Advantage red light meaning and source of manual
the steady red light showing when in charger shows that
it is charging. the blinking red light when taken out of
charger or turned on and off means it is not fully charged.
leave it in charger till red light turns green.
Mar 04, 2008 | Norelco Advantage 6705 X Electric Shaver
Norelco 8894 XL Electric Shaver Logo
1,020 people viewed this question
Top Norelco Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Bruce Foote
Level 1 Expert
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
