Coleman 6000w 2006or 2007 model Where would fuses be to check or what else could be the problem
You need to remove the cover where the outlets are at and measure the voltage before the breaker. There are no fuses on the output side of the genset only breakers. If breaker is fine but still no output, try flashing the fields with a 12 volt battery. If voltage increases then your voltage regulator is bad.
