Pending printing printing always pending like 1 documents in queue cable usb and power light on, please how I can solve this troubleshooting epson stylus C58
  • 72 Answers
Printers and faxes then highlight printer then go to file and select set default printer. Then open printers and faxes go to file select restart
Posted on Apr 15, 2009
My hp jeskjet 1560 is not working because the green light is blinking when i am on my printer it is continue blinking.pls.... some one help me
Your printer is keeps on blinking maybe because theirs a lot of pending documents pending in queue. Please follow these instructions on how to clear it.
Please check the following before you go and proceed to the troubleshooting:
  • Make sure that the computer is on.
  • Make sure that the USB cable is connected to both device (your printer & computer)
  • Close any open applications on your computer. (Microsoft word, power point excel & etc.,)
Solution #1 Clear the print jobs
  1. Download the "HP print diagnostic utility" click here to download.
  2. After downloading the tool, (print diagnostic utility) save it to your computer.
  3. Run the tool, then select the printer that your using, then start scanning the problems on the printer.
  4. It will tells you if theirs a problem with the connectivity, ports, print jobs stuck in queue and etc.,
  5. If the problem appears, theirs should be a "Fix" button available or "uninstall the driver".
  6. If theirs a fix button, clink on it to fix the issue, now if its telling you to uninstall the driver.
  7. Restart the computer, then if you have to computer boot up and running again. Install the driver for the printer. To get the latest driver that suites to your computer click here.
  8. It will ask you to select your operating system, (win xp, vista or 7) then click on next. Now it will ask you what software do you wish to download, click on "Drivers" then look for "HP Deskjet full feature software and drivers" click on it.
  9. Download the software and save it.
  10. Run the software and install it.
If you have the printer working, you don't need to troubleshoot further. If you are still having problem, continue to the next solution. Solution #2 Power cycle both devices (printer and computer)
  1. Turn off the printer by pressing the power button
  2. Unplug or disconnect the power chord at the back of the printer.
  3. Completely shut down your computer.
  4. Wait for 1min.
  5. Plug the power cable back in to the printer, then turn it on.
  6. Try to print something on your computer. It should be working fine now.
If your still having same issue, you now need to service the printer. contact HP's printer support department to have your printer trade in @ 1-800-474-6836.
Good Luck :)
Feb 04, 2011 | HP D1560 Deskjet Printer InkJet
My printer refuses to print. The Red Status light came on so I checked and found there was a paper jam - cleared that. Can get green light to come on if I press the job cancel button but still cannot get...
Perform a Factory Reset
Turn the printer power switch OFF on the right side of the printer. Check that the front cover is closed.
Turn the printer power switch ON while holding down the GO button until the Toner, Drum, and Paper LEDs are lit.
Release the GO button. All LEDs will be off.
Press the GO button 8 times. The Ready LED will flash briefly while the printer is reset. After the printer is reset the Ready LED will be lit.
Print a Test Print Page
Print the Print Settings by pressing the GO button three times.
- If the Print Settings pages do not print, check for alarm lights on the printer. Clear the printer error before trying to print again.
- If the Print Settings pages print, the problem is isolated to printing from your computer. Verify the printer cable connects from the back of the computer directly to the printer. If the cable has become disconnected, loose, or connects through another device, the printer may not be able to print.
Check the Printer Driver Properties
Follow the instructions below based on the operating system installed on your computer.
Windows 7:
Click on the Windows icon => Control Panel => View Devices and Printers.
Right mouse click the Brother printer. Left click See What's Printing. The print queue will open. If print jobs are listed in the printer queue, click Printer (at the top of the window) and click Cancel All Documents to delete the pending print jobs. Click Yes to confirm deleting the print jobs.
Click Printer at the top of the window again. Make sure that Pause Printing and Use Printer Offline are not check marked. If either setting is marked, click on the check mark to remove it.
Click Properties from this Printer menu list.
Click the Ports tab. Verify the correct port is selected (LPT1 is using a parallel cable and USB is using a USB cable). Remember to click Apply if you select another port.
Click the General tab and Print Test Page button. The Windows test page should now print.
- If the Windows test page prints, try printing from a program.
Windows Vista:
Click on the Windows icon => Control Panel => Printers or under Hardware and Sound click Printer.
Right mouse click the Brother printer. Select Run as administrator and left click Open. The print queue will open. If print jobs are listed in the printer queue, click Printer (at the top of the window) and click Cancel All Documents to delete the pending print jobs. Click Yes to confirm deleting the print jobs.
Windows XP and 2000:
1. For Windows XP Professional, click on Start => Printers and Faxes.
For Windows XP Home Edition, click on Start => Control Panel =>Printers and other hardware => Printer and Faxes.
For Windows 2000, click Start => Settings => Printers.
2. Double-click the Brother printer to open the print queue. If print jobs are listed in the printer queue, click Printer (at the top of the window) and click Cancel All Documents to delete the pending print jobs. Click Yes to confirm deleting the print jobs.
3. Click Printer at the top of the window again. Make sure that Pause Printing and Use Printer Offline are not check marked. If either setting is marked, click on the check mark to remove it.
4. Click Properties from this Printer menu list.
5. Click the Ports tab. Verify the correct port is selected (LPT1 is using a parallel cable and USB is using a USB cable). Remember to click Apply if you select another port.
6. Click the General tab and Print Test Page button. The Windows test page should now print.
Nov 01, 2010 | Brother HL-5240 Laser Printer
I have an ip3500 canon printer that is about 3 years old. I was printing an article this morning and when I went to print another the printer would not respond. The on light is not on. I have unplugged...
Check the printer job queue by clicking on the printer icon in your system tray. Most probably your previous document is still pending or something.
Right click or in the main menu, select delete all print jobs and then try printing... this should solve the problem.
You could also clear all pending jobs through start... control panel... your printer...
Another thing to check for is if your default printer is still the same and if it is showing as online.
Please mark this solved if it is.
Jul 31, 2010 | Canon Office Equipment & Supplies
Will not print all conections are good every thing sits ,but does not print have 9 documents pending
Hi. You will need to clear the queue first as it will just accumulate in it if the pending documents remain. There are articles in the Lexmark website to help you remedy the problem. Just click on the links. This first link: http://bit.ly/agrrFg will help you remove or cancel print jobs in Microsoft windows. If the print jobs are still stuck in the queue, click on this link: http://bit.ly/aVuCwm and follow the instructions carefully. Once the queue is cleared, unplug the printer usb connection from the computer and plug it back in after 5 seconds. Try printing again. Good luck!
Mar 24, 2010 | Lexmark X4270 All-In-One InkJet Printer
I am trying to print and the computer is saying my documents are pending in the queue how do I print!?
Thants means some pending peinted or pronting documents in que in printer,Please follw the given instructins,,
choose start button
go to setting --> printer and fex option
you see the connected printer,
choose the printer and Right click of the mouse on that icon.
choose open option
you see many pending documents in screen,select all documents and right click of the mouse -->cancel -->Ok
Queue is nil
than you will ready to print.
Thanks
Dec 19, 2009 | Office Equipment & Supplies
Won't print- communication error
Hi
The first thing we can try here is checking the status of the printer in the control panel in the Printers and faxes.
Go to start->control panel-->printers and faxes
now check if you see the Epson printer
If its greyed out,its the prob with the connectivity, check the status ,if it says offline
bring it online by doing a right click on the printer icon and selecting Use Printer Online
also check if there are any pending documents in the queue,cancel the pending documents by right clicking and choosing the Cancel All Documents.
to check the driver status
Goto->start->run->(type in the box) devmgmt.msc
this should open up the device manager
check the printer entry,
if it has a yellow exclamation mark
do a right click on the entry and try updating the drivers
else
unplug the usb cable from the rear of the computer
and uninstall/reinstall the drivers by following the instructions on the cd
Thanks and Good luck
Techbuddy247
Aug 07, 2009 | Epson Stylus CX4800 All-In-One InkJet...
Cant print, pending has no status.
Please check printer cable both end otherwise please replace the data cable.This is the only data cable faulty/ lose connection problem.
Jun 01, 2009 | Epson Stylus CX3810 All-In-One InkJet...
Epson cx3200
If it can print from the printers stand alone function....
1.) check on cable connections > transfer usb cable to a diff usb port > use a diff usb cable
2.) check on printer driver >
cancel pending documents > Control Panel / Printer and Fax ( for windows systems )
Whats the OS on your Computer?
Mar 20, 2009 | Epson Stylus CX3200 All-In-One InkJet...
I have (4) documents to print, but it won't print. It says: 4 document(s) pending owner
To cancel a print job in Windows you can use one of the following two methods:
CANCELLING A PRINT JOB WITH THE PROGRESS METER:
When you send a print job to the printer, the Status Monitor will appear in the bottom right corner of your screen. Another printer icon for the PROGRESS METER will also appear in the taskbar while printing is taking place. This PROGRESS METER is there so you can manage print priorities or cancel print jobs.
1. Highlight the print job in the PROGRESS METER box.
2. Click on DOCUMENT and CANCEL, or, right click on the job name and left click CANCEL or DELETE.
3. Confirm cancelling the print job.
CANCELLING A PRINT JOB FROM THE PRINTERS WINDOW:
If no PROGRESS METER appears, you can access the document queue in this fashion:
1. Open START, SETTINGS, CONTROL PANEL, PRINTERS (START, CONTROL PANEL, PRINTERS and FAXES in Windows XP).
2. Right click on your Epson printer name, left click PURGE PRINT JOBS (98,ME), or CANCEL ALL DOCUMENTS (2000,XP). (Or, double-click on the printer name to see and modify the status of documents in queue.)
3. Confirm cancelling all documents.
Keep in mind that once information has been sent to the printer it resides in the spooling folders within Windows. It may a while for printing to stop as this data clears the system.
If the printer continues to print (ie multiple copies of a cancelled job, or garbled print) remove the rest of the paper from the printer and allow it to run out. Once an "out of paper" type error appears on your screen, cancel the documents. Once all print job information has deleted, reload the paper and press the paper feed button once to clear the red light and return the printer to a ready state.
Jul 16, 2008 | Epson Printer
332 people viewed this question
k24674
jasbo
jasbo
