Question about Aiptek Pocket DV5900 Digital Camera
Broken Power Button
The power button is missing and i was wondering what i can do to turn it on
  • 752 Answers
There's usually some sort of contact (often a button or just a little bubble looking thing) under it. Can you reach it with something like a Q-tip?
Posted on Sep 14, 2007
  • Mitch
    Mitch Sep 15, 2007
    The actual "button" is usually within 5mm of the "button" that is designed to be pressed, but it can be in any direction.
Power button missing
Usually there is a pc. of plastic that appears to be a power button but inside of the case there will be an actual button connected to wires that is pushed when you push the button outside of the case. Should be able to use a toothpick to push in on the little circle u see inside of the case. If not you can remove the cover and order the part that is broken. this person dropped theirs and the wires came loose inside of the case.
Jun 14, 2014 | ZEEPAD MID Android Tablet 7 Inch WiFi
Tv power button broken
I think the problem is not only in power button. This symptom is like microprocessors or horizontal output section faults.
Sep 29, 2013 | Hitachi Televison & Video
I can't turn the monitor on. The light continuosly flashes
I would go ahead and get a new monitor. It sounds to me as if the button is broken were it connects on the inside
Feb 23, 2010 | Acer Value Line AL1717B Monitor
We have power but the front brush does not turn?
Your belt is probably broken, stretched or worn. You can get a replacement belt here:
Bissell Healthy Home Replacement Belt
Nov 25, 2009 | Bissell 5770 Healthy Home Bagless Upright...
Broken mitsubishi 62525
The tv will not come on at all with either the door in the back (with filter) or the door covering the lamp (in front) missing. Each of these doors has a small microswitch that must be engaged (door must be on) for the tv to work at all.
May 01, 2009 | Mitsubishi WD-62525 62" Rear Projection...
If the power button is under the screen you can check easily. You will be able to see little slots. They make tools that will help you open them. Once you open it,it should be there
Mar 12, 2009 | Acer Aspire 5315 Notebook
Unable to turn on my labtop (gateway 7326GZ) computer.
The real button is under the button you see. You might be able to get the keyboard cover off. If it's not broken broken you could try to reseat it. The part unless you find a cheaper source is 149.00 (which frankly is ridiculous)
Dec 31, 2008 | Gateway 7320GZ Notebook
My power button is broken is there a way i can still turn it on?
you will need to take the phone to a mobile repair center and have them repair it for you
Dec 11, 2008 | Motorola Mobility RAZR V3
Dremel moto tool 270
you have to hold down the little metal button near the nut and just tighten away with the wrench. that button locks the rotor and keeps it from rotating. if that doesn't work, i would suggest a part is broken.
Jul 13, 2008 | Electrical Supplies
Orange spv c 500
No. Use a sharp pointed object to depress the metal under the missing or broken button. Remove button if necessary, or disassemble phone to get to printed circuit power button interface and press and hold it there.
Nov 13, 2007 | Orange SPV C500 Pocket PC
Aiptek Pocket DV5900 Digital Camera Logo
37 people viewed this question
Top Aiptek Cameras Experts
mohamed salim shaikh
Are you an Aiptek Camera Expert? Answer questions, earn points and help others
