Question about Linksys BEFW11S4 Wireless-B Broadband Router (12503024)
My password is "wrong' whenever I try to connect on my laptop
I recently purchased a new HP laptop. I had a BEFW11S4 that I had purchased several years ago, but never used. I set it up, it seems to be set up correctly. I have internet connectivity on my desktop (not a wireless computer). I wanted my network to be secured, so I enabled the security and created a password to access the network. Everytime I try to connect with my laptop I get a message telling me that my password is wrong, even though I KNOW it's right. The only way I've discovered to fix this is by going back to my desktop, accessing 192.168.1.1 and re-saving my password for my secure network. After I do that, I can back to the laptop and connect manually. This is very annoying. I hope that someone out there knows how to fix this!!
    Genius:
  • 1,269 Answers
That's firmware problem on your router. Try to download the latest firmware for you router from www.linksys.com/download then load the latest firmware. After successfully updated the firmware, you need to hard reset the router by pressing the reset button for 20 seconds then unplug the power for 10 seconds and plug it back in. You will need to reconfigure the wireless settings.
Posted on Apr 15, 2009
I already have several items--phone,tablet, IPad, Kindle--hooked to router we purchased in March. Now I cannot connect new products.
They do get changed sometimes, you have have to get into the router or call the manufacturer of the product you are trying to log into, to reconfigure it.
Dec 12, 2015 | Samsung Tablets & eReaders
I have a linksys befw11s4 router, and a verizon 6100G modem. I'm so confused I did what i had to do to get the router and modem activated and logged on to my router "192.168.1.1" then...
You will need to get the right User ID and Password before proceeding.
Also make your Verizon 6100G LAN port is connected to your BEFW11S4 WAN port.
May 09, 2011 | Linksys BEFW11S4 802.11b Wireless...
Hello, I recently purchased a new laptop (Sony Vaio, E-Series, VPCEB36FA). Whenever I try to connect this laptop to my home wireless network provided by a 6200 ADSL2+ 4-Port Zhone Router, it never gets...
Seems you forgot everything.
1. You could try the default username : admin with password : admin or username : user with password : user
2. if those not working you can reset your ADSL modem to the factory reset by push the "reset to default button" in the back panel, this will bring your modem to the very first time condition. Use the method 1 to login.
cheers
Feb 10, 2011 | Zhone (6218-I2-200) Router
Printer always says "Remove and check color cartridge"
It must be your ruined catridge. Some times the wire connections are burned at the side of the catridge and you must thaw away it and buy a new color catridge.
Oct 28, 2009 | HP PSC 750 All-In-One InkJet Printer
Unable to connect to Linksys BEFW11S4 router from new Toshiba lap
this sounds like security problems , other people have experienced problems with vista but most have been able to resolve them.
whilst connected to your router using an ethernet cable open a browser windows and type in the rounter address these
are usually one of 2 most likely yours is
192.168.1.1
and typing password as "admin" and no user name. Use your password if you have changed it earlier 2
Go to wireless tab. 3. Go to wireless security sub-tab 4. If security mode is wpa or wpa2 note down passphrase/shared key, if security mode is WEP note down wep key number 1. This will be your network key
also check other.
On the Vista laptop with the connection
Start --> Network
Click on Network and Sharing Center
if It shows a red X between my network and the Internet.
click on the Customize link (below and right of the red X)
Under location type if it was set to Public. change it
to Private. Hit Next
At that point my whole network might go down,  and
reset the router. (turned off and turned on)
After that my red X under network and sharing center
was gone. And my internet connection problem was gone.
I forgot to mention that before you shoul have turned
off all software firewalls and virus scanners. prior.
if that does not work when you are logged into the router page 192.168.1.1 check to see if their is an option to update the router software/firmware ,if their is no option then you  may have to manually downlaod the firmware from linksys and update that way .
Hope this helps if not ask for clarification on anything your unsure of.
May 14, 2009 | Linksys BEFW11S4 Wireless-B Broadband...
HP laptop not recognizing Linksys Wireless B Security Key..
The WEP encryption is consist of 10 characters for 64 bit hex, 128 bit hex is 24 characters and WPA is 8 to 63 characters. So it seems that you have a vista computer? The compatible encryption for vista is WPA, sometime using WEP it is not working properly. So I might advise you to access the configuration of your router (192.168.1.1) and change the wireless settings of your router to WPA-Personal.
Mar 09, 2009 | Linksys BEFW11S4 Wireless-B Broadband...
ENET Port issue on BEFW11S4 Wireless Router
Hi!
Try these steps:
1. Make sure the wireless is disabled when you're doing that. It might cause a confusion between the wired and wireless connection.
2. Try to plug it at other ports (1-4)
3. Try another known working ethernet or CAT-5 cable.
4. Set the laptop's LAN card's speed to 10-hald duplex.
Try these and hope it will help you ;-)
Apr 02, 2008 | Linksys BEFW11S4 Wireless-B Broadband...
Network problem
Be sure that you only enter the password admin - in small letters. The user name shuld be left blank (empty space).
This should work UNLESS you (or someonhe else) previously changed the password. Is this a brand new unit? If someone changed the password, you'll have to use the new password.
What Version is the the router? Did you buy it from a store?
Mar 10, 2008 | Linksys BEFW11S4 802.11b Wireless...
My Router is out of warranty how do I troubleshoot it?
Hi, the BEFW11s4 sometimes is just a plug and play router. If your internet is working when your pc is connected to the modem, just do this steps.
1:Lets reset the BEFW11s4. with the power on, push the reset button at the back of the router for 30seconds, unplug the power of the BEFW11s4 for 10 seconds.
2:Disconnect the pc from your Comcast modem. Connect the ethernet cable from your modem to the INTERNET PORT of the BEFW11s4. Connect the pc to the BEFW11s4. NOTE; MAKE SURE THE PHYSICAL CONNECTION IS CORRECT.
3.Open INTERNET EXPLORER. ONLINE OR NOT?
A. IF ONLINE, clear the address field then type 192.168.1.1, if it ask you for a username and password, then we are ok. THE ROUTER IS ALREADY WORKING.
B. IF NOT ONLINE, TURN OFF PC, TURN OFF BEFW11S4, TURN OFF THE COMCAST MODEM. WAIT FOR 3 MINUTES
TURN ON MODEM, WAIT FOR 3 MINUTES, TURN ON BEFW11s4, WAIT FOR 3 MINUTES, TURN ON COMPUTER
IF STILL NOT ONLINE. Open internet explorer, type on the address field 192.168.1.1, username(nothing, as in blank), password(admin), click ok.
It will take you to the Linksys configuration page(Purple and white screen. On the screen you can see tabs
SETUP WIRELESS APPLICATIONS AND GAMING
MAC CLONE
CLICK THE MAC CLONE TAB, then click on Clone or Clone your pc mac, the save settings at the buttom. After this try the internet. If still offline, unplug the power of the BEFW11s4 for 10 seconds, try the internet again. It should be working now.
If still offline, do STEP 3B AGAIN. IT SHOULD BE WORKING ALREADY. IF THIS DOES NOT WORK, you really have to buy a new router.
I have solved this exact problem more than a thousand times. It always work if the router is still ok.
Good Luck
Mar 08, 2008 | Linksys BEFW11S4 Wireless-B Broadband...
Linksys BEFW11S4 Wireless-B Broadband Router connection trouble
You will need to logon the router via the computer, and create a PPPOE internet connection. If you cannot connect to the router wirelessly my may need to use a cat5 cable between the computer and the router. The user manual that came with the router will show you how to do this. If you do not have the manual. Do the following: open internet explorer, in the address window type the IP of the router "example" http://192.168.2.1 your router IP should be on the bottom of the router. If not click start/run, type ipconfig at the > the router ip is listed at "default gateway".once you get to the routers logon page enter one of the following: username "leave blank" – username " admin " -or- username "admin" - password 1234 –or- leave password field blank.once logged on the router go to internet connections and select PPPOE enter the username and password provided by your ISP save the settings and you should make the internet
connection now. BPCS
Dec 26, 2007 | Linksys BEFW11S4 Wireless-B Broadband...
Computers & Internet Logo
123 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
